Naerok 350 mill
manual and or drivebelt sizes.
dave le feuvre13/06/2019 21:56:33
10 forum posts
I am refurbishing a naerok 350 but need a manual and the belt sizes, I think there may be some belt tensioning bits missing. Help please
duncan webster13/06/2019 23:52:51
5307 forum posts
83 photos
I've got a manual, send me a pm with your email address and I'll send it along
Martin Hamilton 114/06/2019 11:46:18
188 forum posts
The 2 v belts on my Naerok 350 mill are marked A32 & A25, these are easy available belts.
john fletcher 114/06/2019 13:31:59
893 forum posts
I have a 350 for 25/30 years and have carried out lots of mods which George turner published in ME back in the 1980/90. I fitted a 3ph motor and inverter several years ago, plus home brew power table feed. If you send me a PM I'll forward the mods onto you. John
Lynne14/06/2019 23:26:20
117 forum posts
32 photos
John, I have sent you a PM. Lynne
Ian S C15/06/2019 12:39:54
7468 forum posts
230 photos
If you put Naerok in the search window just above your name at the top of the page you will find a manual there that you can save or down load. I found it handy as I have the same mill although here in New Zealand it is called Rexon, still made in Korea.
Ian S C
Craig Brown08/05/2021 22:35:37
110 forum posts
57 photos
Sorry to drag this thread back up but no sense in starting a new one. Would someone be able to confirm the belt sizes for the Naerok RDM350?
Many thanks, Craig
Craig Brown09/05/2021 09:28:27
110 forum posts
57 photos
The reason for asking is that mine came fitted with an A32 and an A23 but these appeared too tight to select all speeds. On seeing this thread I ordered an A25 (the A25 size can also be confirmed from a picture on lathes.co.uk) but that seems too loose. Mine has had a replacement motor fitted so that may be cocking up the centres for the smaller belt so maybe I will try an A24
john halfpenny09/05/2021 09:38:10
314 forum posts
28 photos
I use newish A31 and A23. Its difficult at the extremes, but you will soon have enough variety to suit all combinations.
