Blue Heeler | 15/05/2019 02:02:16 |
![]() 342 forum posts | This is how I DIY Nicket Plate Brass, a quick and quite simple method. Always wear disposable gloves.
Edited By Jim Dobson on 15/05/2019 02:02:24 |
not done it yet | 15/05/2019 07:16:19 |
7517 forum posts 20 photos | Jim, I like the disposable gloves! Much more important if chromium plating. |
Michael Gilligan | 15/05/2019 07:45:32 |
![]() 23121 forum posts 1360 photos | Thanks for that, Jim ... Your plating tank looks rather classy Have you tried electroforming with Nickel ? If so ... I would be grateful for any advice you can give. MichaelG. |
Russell Eberhardt | 15/05/2019 11:55:32 |
![]() 2785 forum posts 87 photos | There's an interesting book available on line published by the Nickel Institute with all the information you need, including plating solutions: https://www.nickelinstitute.org/media/2323/nph_141015.pdf Russell
Roderick Jenkins | 15/05/2019 12:08:50 |
![]() 2376 forum posts 800 photos | I've had recent success using home made Nickel Acetate following Geoff Crokers method on Youtube Rod |
Michael Gilligan | 15/05/2019 12:28:37 |
![]() 23121 forum posts 1360 photos | Posted by Russell Eberhardt on 15/05/2019 11:55:32:
There's an interesting book available on line published by the Nickel Institute with all the information you need, including plating solutions: . Thanks a lot for that, Russell MichaelG. |
vintage engineer | 15/05/2019 16:55:34 |
![]() 293 forum posts 1 photos | Can you reverse this process? |
Blue Heeler | 16/05/2019 03:59:16 |
![]() 342 forum posts | Posted by Michael Gilligan on 15/05/2019 07:45:32:
Thanks for that, Jim ... Your plating tank looks rather classy Have you tried electroforming with Nickel ? If so ... I would be grateful for any advice you can give. MichaelG. Thanks Michael, needless to say my wife was very unimpressed! |
Blue Heeler | 16/05/2019 04:02:00 |
![]() 342 forum posts | Nickel welding rods are the easiest source of procuring virtually pure (99%) nickel. You just take a hammer and knock the flux off on some scrap steel with newspaper underneath and when the rods are pretty much clean just finish up with some steel wool and then wrap up the newspaper. |
Plasma | 16/05/2019 11:27:58 |
443 forum posts 1 photos | Would old nickel silver cutlery be a good source of nickel for plating? I'm fancying giving this a go, got to find the you tube video of how to make the basic solution. Mick |
Michael Gilligan | 16/05/2019 14:10:01 |
![]() 23121 forum posts 1360 photos | Posted by Plasma on 16/05/2019 11:27:58:
Would old nickel silver cutlery be a good source of nickel for plating? . That was my assumption ... which is why I've been stockpiling it. and de-plating EPNS should also provide a modest source of Silver MichaelG. Edited By Michael Gilligan on 16/05/2019 14:12:21 |
Fowlers Fury | 16/05/2019 16:10:03 |
![]() 446 forum posts 88 photos | Not so sure I'd want to risk Ni plated stuff.
Michael Gilligan | 16/05/2019 16:19:25 |
![]() 23121 forum posts 1360 photos | Posted by Fowlers Fury on 16/05/2019 16:10:03:
Not so sure I'd want to risk Ni plated stuff. . Not sure that I understand ^^^ EPNS is solid 'Nickel Silver' electroplated with Silver ... I had assumed that if NS was used as the electrode; the Copper and Zinc would just get deposited as sludge. Please correct me if I'm wrong. MichaelG. . https://www.smithmetal.com/nickel-silver.htm
Fowlers Fury | 16/05/2019 17:18:25 |
![]() 446 forum posts 88 photos | My understanding is that if Cu and Zn are present in either the electrolyte or anode they will also get deposited on the item to be Ni plated. The book cited by Russell is an interesting & comprehensive read. Therein the only statements relevant to anode purity I found on a quick scan were:-
Michael Gilligan | 16/05/2019 18:07:04 |
![]() 23121 forum posts 1360 photos | Thanks for that Looks like my stash of cheap NS cutlery will simply be raw material. MichaelG. |
Blue Heeler | 17/05/2019 02:52:53 |
![]() 342 forum posts | Posted by Plasma on 16/05/2019 11:27:58:
Would old nickel silver cutlery be a good source of nickel for plating? Mick I don't think it would be worth the bother. If you popped into a welding fabrication workshop and ask nicely they should sell you a couple of pure nickel welding rods. These are easy to use, 99% pure nickel and you can bend them easily to the shape(s) that you need. |
Paul H 1 | 17/05/2019 08:30:08 |
37 forum posts | Nickel strip is easy to get hold of on the two very popular on-line buy anything sites. Just search "nickel strip 18650". It is very popular for building LiPo 18650 battery packs. Not expensive at all. After watching the videos referenced on this thread that is the route I will be going rather than buying a plating kit. Paul |
Blue Heeler | 18/05/2019 00:50:22 |
![]() 342 forum posts | Posted by Paul H 1 on 17/05/2019 08:30:08:
Nickel strip is easy to get hold of on the two very popular on-line buy anything sites. Just search "nickel strip 18650". It is very popular for building LiPo 18650 battery packs. Not expensive at all. After watching the videos referenced on this thread that is the route I will be going rather than buying a plating kit. Paul Hi Paul Those strips are pretty thin material, you're going to eat through a helluva lot of that to make the nickel acetate solution. Again, the easiest way to procure pure nickel in thick round round material is by purchasing some nickel welding rods.
Also just a heads up to all, be careful of nickel acetate in regards to your person. Make sure you don't spill any anywhere and contaminate your work area and disposal of it should be down the sink or via normal home waste removal methods. |
Michael Gilligan | 18/05/2019 07:07:13 |
![]() 23121 forum posts 1360 photos | Youplate looks promising, as a source of materials: **LINK** http://www.youplate.co.uk/anodes.html MichaelG. |
Paul H 1 | 18/05/2019 10:36:20 |
37 forum posts | Mike, thanks for the link it's very promising. I'll have to look into delivery costs from UK. Jim, point taken. Welding rods here can be rather expensive, so the anode route may be better for me. Fleabay fr has quite a lot, though not as thick as on Mike's link. Paul
