miniature 3 pin sockets
Speedy Builder527/03/2019 19:37:32
2878 forum posts
248 photos
I am a bit new to all this electronic ey stuff. I need to plug 5 off, 3 wire temperature sensors into a circuit board. Won't do it too often, but must be easily unplugged. Sensors draw little current at 3.3 volts.
I don't want them too big, perhaps 3.5 phono ?? Or what would you suggest ? Elsewhere to get them with a reasonable delivery schedule (Not China).
BobH
Frances IoM27/03/2019 20:15:39
1395 forum posts
30 photos
15pin header (pins at 0.1" spacing - you can buy small blocks in various sizes inc 3 wire that take wires held by a screw terminal with female socket for each wire that will plug onto the male terminal strip
try RS-components ? but mine were derived from USA built equipment tho I know Maplin used to do them
Neil Wyatt27/03/2019 20:35:49
19226 forum posts
749 photos
86 articles
Stereo jack plugs are reliable.
3-pin mini DIN plugs are bigger but look more professional.
Ian P27/03/2019 21:22:24
2747 forum posts
123 photos
If as you say these are plugging into a circuit board then is the board is already fitted with a connector?
If its is then
If say the board will have wires soldered to it that are then wired to connectors of your choice its just a matter of selecting parts that meet the electrical requirements, that can be panel? mounted, are wire-able with your skills and equipment, affordable and suit the type of wire fitted to the sensor. 3.5mm phono plugs are only two pole so no good for three wires sensors, 3.5mm stereo jacks would be OK but as one pole will be carrying supply volts you need to take care to wire them in such a manner that the sensor is not damaged whilst mating (the wrong contacts make connection as the plug is inserted).
There are hundreds of suitable connectors really, mostly its a matter of choosing the physical and mechnical features first.
Ian P
David George 127/03/2019 21:35:47
2110 forum posts
565 photos
Have a look at XLR connectors RS components or other supliers.
David
John Paton 127/03/2019 21:52:14
327 forum posts
20 photos
I recently bought 'Metal Screw Butt Joint Type Male Connector Aviation Plug XS8JK-4P/Y' from Amazon , £3.62 for a plug and socket. These sockets can also be bought 'panel mounting' rather than lead fitted. They have a nice snap on connection action so stay putt in use but disconnect easily when you need to unplug.
Also consider the servo plugs and sockets used by modelmakers for radio control, but these would need to be used with fly leads rather than panel mounted socket so wont look quite as professional. Get some lengths of small bore heat shrink tube to seal over soldered connections between flyleads and your wires if going that way.
Andrew Johnston27/03/2019 22:22:22
7061 forum posts
719 photos
There isn't enough information in the OP to be able to make an informed suggestion. For instance are the connectors wire to PCB, or do the connector(s) need to be panel mount? Is each sensor to have it's own connection or can they all be on one connector. Do the connector(s) need to be latching or not?
Having spent many hours searching for connectors I can safely say that connectors is the biggest section in the catalogue; and still no-one makes the connector that you really want. sad
Stuart Smith 527/03/2019 23:39:42
349 forum posts
61 photos
It sounds like Mini Din connectors would be a good choice if they are small enough for your application. Available from 3 pins upwards and with chassis or pcb mounting sockets. I buy connectors from CPC. They are local to me but do quick free delivery. **LINK**
duncan webster28/03/2019 00:48:37
5307 forum posts
83 photos
why not just headers and female header jumpers
aIAAOSwbbdbBx-b">header pins
jumpers
you need a solder join in the wires, bit of heatshrink over it is fine. Arrange to have your 3 pins next to each other on 0.1" spacing, the the set of three get a better grip if they are adjacent. Really cheap
Geoff Theasby28/03/2019 06:58:29
615 forum posts
21 photos
Basically, you need Molex connectors. If a panel plug/socket, do not use stereo jacks, as has been said, because the wrong contacts 'make' as they are connected. Microphone connectors, available in many 'ways' can be used, but not if there is danger of harmful, inappropriate connectors being mated, causing hazards.
Brian G28/03/2019 08:17:37
912 forum posts
40 photos
If you want to connect straight onto a board but want something keyed, JST connectors are useful from Amazon (and plenty of other places).
Former Member28/03/2019 08:43:05
Ian P28/03/2019 09:42:46
2747 forum posts
123 photos
I have 'here we go again' feeling!
A few days ago I brought up the subject of topics rambling on with irrelevant replies to the original question, I was and still am not, opposed to topic drift and admit that I do both partake and learn from some threads. In this particular thread the OP admitted he was not electronically knowledgeable but asked for some connector suggestions. Since there are thousands different connectors, without the OP supplying more information it is really quite pointless forum members suggesting particular devices ad infinitum.
Its not difficult to look at the beginning of a thread before posting a reply, I'm just baffled why a lot of people do not seem to bother.
An exaggeration really, but for all we know the OPs application might be part of diagnostic medical equipment and have an unlimited budget, or it might be a non critical hobby related project. Offering any specific connector without knowing its intended purpose does not really have any point.
Ian P
Andrew Johnston28/03/2019 10:04:08
7061 forum posts
719 photos
Posted by Ian P on 28/03/2019 09:42:46:
..........without the OP supplying more information it is really quite pointless forum members suggesting particular devices ad infinitum.
Which is why I didn't suggest one. smile
Ian P28/03/2019 10:24:23
2747 forum posts
123 photos
I know you didn't Andrew.
Ian P
Brian G28/03/2019 10:40:26
912 forum posts
40 photos
The OP's earlier question about adding three temperature probes to an Austin Seven led me to believe that this thread about attaching three temperature probes to a circuit board might be for the same purpose, hence my belief that JST connectors would be appropriate. I stand admonished.
Frances IoM28/03/2019 10:46:22
1395 forum posts
30 photos
actually he gave quite a bit of info
low voltage/current, easy but infrequent removal
onto a circuit board ie not a cased bit of equipment thus small self holding connectors that will not see many insertions
ok after this one can jump to a few assumptions - inexperience suggests that he might not have equipment for very fine soldering - hence my suggest of screwed terminal + the 0.1" strip that matches headerpins on several microprocessor boards
As many have said - there is no compulsion to either read or respond to all posts nor is this forum/message board a formal archive though if people place their photos along with their posts it will last longer as a useful mine of info than most others where the photos have dissapeared but the text has survived.
Former Member28/03/2019 11:15:05
Speedy Builder528/03/2019 11:19:16
2878 forum posts
248 photos
OK Guys and ladies, I have the information now - Thanks for all your help.
BobH - Speedy Builder 5
Former Member28/03/2019 11:34:12
1329 forum posts
