3 Jaw self centering ER chuck
An unusual tool
John McNamara19/02/2019 14:59:09
1377 forum posts
133 photos
Hi All
I Stumbled on this web site
An Australian engineer living in Vietnam.
An unusual way of holding an ER collet.
Video Link
Edited By John McNamara on 19/02/2019 15:02:11
Michael Gilligan19/02/2019 19:16:50
23121 forum posts
1360 photos
Thanks for the link, John
An interesting idea !
mark costello 119/02/2019 20:58:50
800 forum posts
16 photos
EXCELLENT!
Nick Hulme19/02/2019 23:02:12
750 forum posts
37 photos
It's a significant geometrical compromise and not a very clever way to use a dual taper collet.
Michael Gilligan19/02/2019 23:44:34
23121 forum posts
1360 photos
Posted by Nick Hulme on 19/02/2019 23:02:12:
Admittedly, ignoring the front taper is a novel way to use a dual taper collet
... I wonder what the internal profile of the soft jaws might be.
It does, however, seem a neat way of holding thin tubes in a hefty 3-jaw.
John McNamara19/02/2019 23:50:10
1377 forum posts
133 photos
I beg to differ.
The workpiece is a thin wall tube, while it would be easy to make a special set of soft jaws to hold the part, using this method will allow an easy change to a wide range of sizes.
The chuck itself is fitted to a high end CNC machine, I am guessing that the the hydraulic chuck body is very high accuracy and that the soft jaws were bored in situ dead true.
I have always suspected the ER system's main flaw is that the front taper is centered by a screw cap. I have seen a number of experienced machinists videos that show the cap being given a smart tap with a soft hammer to improve the centering of the cap.
I think this is a good solution, Looking at the other videos on the site it appears the shop produces a lot of differing small parts.
Does it produce parts that are within spec efficiently? that is the only question that needs to be answered.
Michael Gilligan20/02/2019 00:08:52
23121 forum posts
1360 photos
Posted by John McNamara on 19/02/2019 23:50:10:
I beg to differ.
... hopefully from Nick, not me angel
John McNamara20/02/2019 00:25:39
1377 forum posts
133 photos
Yes Michael I was responding to Nick.
Paul Lousick20/02/2019 01:26:25
2276 forum posts
801 photos
Holding something in a collet has normally been more accurate than using a 3-jaw chuck.
This a 3-jaw holding a collet. How accurate is that ?
Paul.
Neil Lickfold20/02/2019 06:28:11
1025 forum posts
204 photos
Hey John, I like it. That is quite a trick setup , especially the fact that the chuck has a limit on the opening.
As for accuracy I am sure it is better than 0.01mm if the collet is a precision collet. For it's application with full contact engagement in the collet looks really good to me.
It would also lend itself to the use of distortion collets as well. Very interesting.
I might have to make up a set of jaws to allow this to happen.
JasonB20/02/2019 07:04:15
Michael if you follow John Mc's link to teh FB page you can see the jaws have a tapered cone turned into them and small lip to retain collet via it's groove.
Like Nick I wonder how that can apply an even force all around the collet rather than just give 3 points of contact which would be more so the further the collet was closed down. At best it spreads the load more than using standard 3-jaws and saves having to make dedicated soft jaws for each size.
Edited By JasonB on 20/02/2019 07:26:23
Michael Gilligan20/02/2019 07:53:19
23121 forum posts
1360 photos
Posted by JasonB on 20/02/2019 07:04:15:
I avoid FaceBook as much as possible ... but that ^^^ is exactly what I surmised when responding to Nick.
JasonB20/02/2019 08:05:57
I beg to differ.
Reading some of the comments and replies he says "it is important that the jaws are machined to the collets CLOSED size" so unless you are only holding work at the upper end of the collets range you would need a rebore of the jaws every time eg if holding 1/4" stock in a 7mm collet so can't see that being any quicker or easier than machining soft jaws.
Mike Poole20/02/2019 08:24:43
3676 forum posts
82 photos
It sounds as though this works but in very qualified situation for a very specific purpose. This is not an alternative ER chuck but a special purpose tool utilising an ER collet. Worth filing for reference and may be a seed for other applications. Interesting.
Martin Kyte20/02/2019 08:37:29
3445 forum posts
62 photos
Looks like it would be optimum for a fixed diameter only.
regards Martin
Martin Kyte20/02/2019 08:47:33
3445 forum posts
62 photos
Are the jaws air operated ?
Martin
Neil Wyatt20/02/2019 08:49:43
19226 forum posts
749 photos
86 articles
My thoughts are:
For small bore collets which are counterbored, ideally you need more compression at the front.
It prioritises convenience over accuracy. On my lathes changing chucks takes about as long as changing jaws, but that may not be the case for this hefty machine with six mounting screws.
JasonB20/02/2019 08:55:01
Again if you read the link he says changing the 3-jaw to a collet chuck takes a long time so quicker for him to swap jaws.
Martin Kyte20/02/2019 09:15:20
3445 forum posts
62 photos
I think if you have a cnc machine with an air operated 3 jaw chuck then with the addition of 3 special jaws you have an adaptor to take the full range of ER collets and can safely hold thin walled tube. Not a bad result for not much outlay.
regards Martin
jann west20/02/2019 09:40:44
106 forum posts
also worth noting that this setup would allow the easy integration of a depth stop through the back-end of the headstock spindle ... something typically considered an advantage of the 5c over the ER collet.
