New to metal lathes - bore sizes?
Spindle bore sizes
Bill Pilkington14/02/2019 15:03:32
10 forum posts
What lathes have a spindle bore size of 35mm to 40mm.
Jeff Dayman14/02/2019 15:35:13
2356 forum posts
47 photos
You might look in lathes.co.uk website for comparative info.
SillyOldDuffer14/02/2019 16:19:19
10668 forum posts
2415 photos
Bigger ones!
To get an idea of the relationship between size and bore in Far Eastern lathes have a look at Warco's website. If you click on a lathe's photo it will take you to its specification including the spindle bore. (Scroll down to the table at bottom of each lathe's blurb.)
I think the first Warco machine to meet your criteria is the WM290. At 230kg it's the largest of the 'Variable Speed Lathes'. After that, look at the Gear Head machines which go up to 80mm but weigh about 2500kg.
John Rudd14/02/2019 16:36:03
1479 forum posts
Chester's Craftsman is 35, the Crusader is 38, but after that the money goes up lots.....
Edited By John Rudd on 14/02/2019 16:37:36
Bazyle14/02/2019 18:06:47
6956 forum posts
229 photos
A lot of the 12x?? advertised 37mm but there were reports some time back that they could be on or more mm shy of that. However owners have been known to correct that without detriment. Some sellers may be knocking off a bit from the manufacturer's 'spec' to avoid comeback.
In the USA they advertise 'gunsmith' models which usually means a larger bore on a basic model.
Edited By Bazyle on 14/02/2019 18:10:05
Chris Evans 614/02/2019 18:24:32
2156 forum posts
My Taiwanese copy of a 14"x40" Harisson M300 has a 40mm bore. A necessity for me doing mainly motorcycle work and needing to hold fork stanchions. Lathe brand name is Excel.
Vic14/02/2019 18:47:09
3453 forum posts
23 photos
Big bore on this one!
Richard -14/02/2019 19:21:23
62 forum posts
7 photos
Harrison M250 35mm
Harrison M300 38mm
David George 114/02/2019 22:45:49
2110 forum posts
565 photos
Hi Bill in the past I had to turn long pieces and to prevent wobble of the piece sticking out of the rear we made a tube which fastened on the rear of the spindle like an extension and a ring cam closed down three jaws on to the long piece to hold and prevent run out.
David
Howard Lewis15/02/2019 10:55:16
7227 forum posts
21 photos
My Engineers ToolRoom BL12-24 (similar to Warco BH600, Chester Craftsman and their clones ) has a 5MT mandrel with a 38mm through bore.
So you are looking for a fairly large machine., bigger than, say a Seig SC4 which is 4MT, I think.
Pete Rimmer15/02/2019 16:49:07
1486 forum posts
105 photos
The smallest lathe I know of which qualifies is a South Bend Heavy 10 which passes 1-3/8" (34.925mm) through the spindle.
Edited By Pete Rimmer on 15/02/2019 16:49:22
Chris Evans 615/02/2019 20:03:23
2156 forum posts
Posted by Pete Rimmer on 15/02/2019 16:49:07:
That may depend on the year of the "Heavy Ten" my 1942 model sold about 6 years ago was only around 1 1/8"
Pete Rimmer15/02/2019 20:57:59
1486 forum posts
105 photos
Posted by Chris Evans 6 on 15/02/2019 20:03:23:
Good point. It's not the year, but the spec but yes there were some heavy 10's with the smaller bore just like there were some other sizes with the larger. The larger bore are by far the more common and identified by the 2-1/4" spindle thread.
Chris Evans 615/02/2019 21:31:40
2156 forum posts
Thanks for the knowledge Pete, I thought all where the same and I had mine 45 years ! Great lathe only sold to make way for a bigger machine.
