Involute, Circular Gear-Cutter on Eccentric Arbor...
Gear Cutting
Andre ROUSSEAU16/01/2019 03:20:04
90 forum posts
I am trying to find a comprehensive online web resource giving a full technical description of an (effectively) single-tooth, circular fly-cutter for cutting involute gears using an eccentric arbor. This seems to be a little-known method and is most intriguing. An excellent demonstration of this approach is shown on "myfordboy" YouTube video:- https://www.youtube.com/watch?v=7zMgJXMHcNs
The obvious advatages are the superior strength of the resulting cutter compared with a conventional straight shank HSS cutter and the avoidance of back clearance facets through the cunning eccentric mounting...
.... neat idea!
Edited By JasonB on 16/01/2019 07:28:55
Mike Crossfield16/01/2019 09:13:45
286 forum posts
36 photos
Andre
The method you describe is actually well established. I have used it a few times with good results. I use a similar method to make clock wheel and pinion cutters, though instead of using an offset arbor I turn the profile on the end of a bar of silver steel, then offset in the 4 jaw chuck before drilling the centre hole and parting off. Incidentally, it isn’t essential to make the two button tool. You can make a tool with a single button and cut the sides of the profile one at a time. You can also use an end mill of the right diameter to cut the profile - Graham Meek uses this method with excellent results.
I would recommend buying Ivan Law’s excellent little book on Gears and Gear Cutting, which describes the method for involute cutters. It’s in the Workshop Practice series, and inexpensive.
John Haine16/01/2019 09:27:19
5563 forum posts
322 photos
There's a refinement of the technique, which may be covered in Law's book, that can generate multi tooth cutters. My album **LINK** shows the manufacture of a cutter, using CNC to shape the profile but could also use buttons. An easily made machining fixture is needed. Also worth looking at Mike's Workshop site for info on designing and making cutters. **LINK**
John Haine16/01/2019 09:27:20
5563 forum posts
322 photos
Russell Eberhardt16/01/2019 10:09:05
2785 forum posts
87 photos
Some time ago the late John Stevenson described an easy method of making single point gear cutters using a tapered cutter to give the required clearance. I can't find the thread at present but it is somewhere on the forum.
Russell
not done it yet16/01/2019 10:17:59
7517 forum posts
20 photos
This link might help.
Roderick Jenkins16/01/2019 10:23:03
2376 forum posts
800 photos
John suggested using a Conecut **LINK** It's a neat solution to making a single point cutter but more difficult for a circular cutter.
Rod
John Haine16/01/2019 10:28:36
5563 forum posts
322 photos
The Mike's Workshop link above describes using cone cutters too.
Neil Wyatt16/01/2019 13:09:18
19226 forum posts
749 photos
86 articles
I make symmetrical cutters from silver steel disks, then cut out a T-shape piece. Mounted eccentrically on an arbor they work as single point cutters and can be reversed to use the second edge. A stop on the arbor makes sure they can't shift.
Andre ROUSSEAU23/01/2019 04:08:24
90 forum posts
Thanks everyone for the great spread of replies, liked Neil's interesting variation on the theme.
Yes, John Stevenson was a very prolific contributor to engineering topics but particularly because he seldom re-gurgitated old ideas, nearly new and original every time. I was well aware of his contribution to the topic before I placed my post but for all who are interested you can peruse these links:-
http://bbs.homeshopmachinist.net/threads/42051-A-form-tool-for-gearcutting
....and-
https://metalwebnews.com/howto/gear/gear1.html
Thanks again.
By the way, I suspect that most of you posters are in the UK (I'm in New Zealand). I can't resist relating an amusing anecdote to you. Some of you may well know that New Zealand has a mini cottage industry re-building de Havilland Mosquitoes (the production form-tooling/jigs are amazing, by the way). Having witnessed the first public display flight of the first-build I was mightily impressed.....
..... so there I was just about to walk into the local supermarket in Papakura last Wednesday when, what should I hear, but the familiar sound of two roaring R-R Merlins overhead? Yes, it was the latest new-build dH-M doing test-flights. A great sight and as I craned my head skyward I muttered to the guy standing next to me, words to the effect "I bet that'll frighten a few Germans!"
He said something like "Hmmm, Interesting" - but in a thick, German accent and "No", he wasn't having a joke with me!
"Ooops!"
Brian G23/01/2019 07:01:37
912 forum posts
40 photos
Circular cutters on an offset arbor are featured in Ivan Law's book (which has free shipping worldwide here **LINK** ). Incidentally the technique doesn't just work for gears, Colin Binnie wrote of using the same method of obtaining clearance with "roller" form tools for the lathe **LINK** .
Michael Gilligan23/01/2019 07:08:54
23121 forum posts
1360 photos
Posted by Brian G on 23/01/2019 07:01:37:
That's a great reference page, Brian ... Thanks for the link yes
... I also like the 'Privacy & GDPR' statement.
Edited By Michael Gilligan on 23/01/2019 07:16:20
Michael Gilligan23/01/2019 07:13:57
23121 forum posts
1360 photos
< double posting deleted >
Edited By Michael Gilligan on 23/01/2019 07:15:38
ega23/01/2019 11:05:56
2805 forum posts
219 photos
Thanks for the link: excellent illustrations and it made sense once I realized that you have to read across the columns of text.
Has anyone here used the static form? A photo would be welcome.
