Member postings for Andre ROUSSEAU
Here is a list of all the postings Andre ROUSSEAU has made in our forums. Click on a thread name to jump to the thread.
Thread: SCRAP - Seeking Unwanted Windscreen Wiper Motor
30/08/2023 07:39:26
Very few in fact, and they only do GREED.
30/08/2023 04:39:23
Hi, Does anyone in the Auckland region have a burnt-out BOSCH EFP windscreen wiper unit they no longer want that would otherwise be heading for the scrap-bin? This unit would typically off of a truck or bus, part numbers' 0 986 337 400 (...& 409, 410) refer. It needs to be intact, no butchery or mangling please. Thanks.
Thread: BOLT from the Blue!
13/05/2023 02:23:12
https://youtu.be/XLzTB4KLCxU
Thread: Adventures in Specialised Glass Machining
02/05/2023 05:11:37
https://youtu.be/A0bysBIj0FA
Thread: 'Out there' machining techniques.
26/04/2023 06:57:26
https://youtu.be/H4YZxb2E5PA
Thread: Keep a Tight Hold on your Nuts!
05/04/2023 09:37:56
https://youtu.be/kx-DyuIcGGc
Thread: Stress-Free Knurling...
05/04/2023 06:53:25
Cecil Green retrieves a triple-wheel Straddle-Knurling Attachment from the past:-
....inspiration for a DIY version, maybe??338233885_248803534251587_3491986319620202645_n.jpg
Edited By Andre ROUSSEAU on 05/04/2023 06:54:24
Thread: HOT Iron!
29/03/2023 06:05:37
More fodder for the OSH inspectors!
https://youtu.be/g8pUySWNoGQ
https://youtu.be/HdEcW01nlVg
Thread: Avoid an expensive trip to the Panel-Beater..
29/03/2023 06:03:38
https://youtu.be/FeIv4Fi2vOM
15/03/2023 08:35:20
The correct technical terminology is "straddle knurling"
https://youtu.be/FdsTONRV8fY
Edited By Andre ROUSSEAU on 15/03/2023 08:36:34
15/03/2023 05:15:26
...another easy-knurl head:-
https://www.yumpu.com/en/document/read/27114835/zeus-knurling-catalogue-floyd-automatic-tooling-ltd
Thread: RUBBER - ideas to bounce off!
15/03/2023 01:41:31
https://youtu.be/ljKKqtmJ9xQ
Handy Tip: On the few occasions I've had to machine Rubber-type materials like Neoprene, etc as a matter of routine I cold-soak them in the freezer overnight which results in a markedly harder material less prone to tearing and excessive deformation when cutting. If machining operations are to be protracted then periodic 'resting' the workpiece back in the freezer is advised.
Thread: Time for a rest; the Toolmaker's 'Chair'
15/03/2023 01:35:35
https://youtu.be/286O33fgwk4
https://youtu.be/HGOkwdJB6T0
Thread: In Search of the 'HOLEy' Grail...
15/03/2023 01:32:02
Holes by the Zillion:-
https://youtu.be/fsjW53JThU0
A useful dodge:-
https://youtu.be/kX8Te5ch1Z0
Thread: HOT Iron!
15/03/2023 01:25:34
The perfect cylinder material - how it's done:-
https://youtube.com/shorts/1QhJIZ33Ejo?feature=share
...and pit casting, more bare-knuckle tech [Attention: Is there a safety footwear manufacturer willing to sponsor this video?]:-
https://youtu.be/B8AqeSPJcHI
15/03/2023 01:20:17
The DIY 'economy' 2-wheel version (N.B. NOT the clamping-caliper type):-
https://youtu.be/Kaf-Rgk1ExU
Thread: JAP V-8
11/03/2023 06:46:39
https://youtu.be/Le_aUdqJ5WY
Thread: Tube-Drawing, "No, I don't mean CAD!"
08/03/2023 01:59:06
A little explored corner of engineering with much to teach....
https://youtu.be/8jN-a8nlBos
https://youtu.be/gRAjeNi1yqw
03/03/2023 11:37:18
Inside secrets of how those expensive little metal doughnuts are made:
https://youtu.be/rgJGh1nt_Mo
03/03/2023 11:32:56
More DIY:
https://youtu.be/L-onTIKfLQc
