Graham Meek | 15/01/2019 11:19:05 |
714 forum posts 414 photos | A little something I knocked up to make sand blasting the odd brass fabrication easier. Given the high air supply demands of commercial cabinets, I decided to make something a little less bulky and that would work off my shop compressor. Regards Gray, |
JasonB | 15/01/2019 11:29:49 |
![]() 25215 forum posts 3105 photos 1 articles | Graham, have you got a few more details of teh actual "gun" part that looks like it is powered by a standard blower nozzle? |
Ady1 | 15/01/2019 11:33:18 |
![]() 6137 forum posts 893 photos | Looks seriously handy Tell us more Graham, thx |
Dave Halford | 15/01/2019 11:38:50 |
2536 forum posts 24 photos | You covering the screen with plastic, like you get from cracker boxes? |
John Rudd | 15/01/2019 11:47:05 |
1479 forum posts 1 photos | Nicely done..! Great for small parts.. Let us know how well it works..please? What abrasive are you using? I use garnet or aluminium oxide, of course depends on what is being cleaned.. |
Vic | 15/01/2019 13:38:46 |
3453 forum posts 23 photos | Nice job. When I made my first sand blaster all the recommendations I could see said you need a massive compressor to run a blasting cabinet. I took a chance anyway and bought a small 2.5 hp 25 litre compressor and found it worked fine for doing small stuff at home. I got rid of my Heath Robinson "cabinet" when I moved house but luckily someone gave me one of the small Clarke blasting cabinets and that works fine. It does say in the instructions that you need a compressor at least double the size that I've got but for what I do the one I've got is ok. Machine Mart sell Aluminium Oxide abrasive in medium and coarse. I normally use the medium stuff in my cabinet. |
Vic | 15/01/2019 13:41:21 |
3453 forum posts 23 photos | The Tangential Tool in my album has been sand blasted. |
Grindstone Cowboy | 15/01/2019 13:59:08 |
1160 forum posts 73 photos | What a great idea! Would love to know more, particularly about the 'gun' part. |
Graham Meek | 15/01/2019 16:15:16 |
714 forum posts 414 photos | Here are a couple of examples of the work done with the unit. The nozzle is the heart of the matter and if Neil would like a write-up on how I went about making this unit I will oblige. Regards Gray, |
Matt Harrington | 15/01/2019 17:59:08 |
![]() 212 forum posts 16 photos | What a clever idea! Matt |
Vic | 15/01/2019 18:16:35 |
3453 forum posts 23 photos | There is a drawing of the commercial gun here: Both the Air nozzle (brass) and Abrasive nozzle (ceramic) are replaceable as they wear away with use. This is the grit I use, they also do several others.
Howard Lewis | 15/01/2019 22:00:59 |
7227 forum posts 21 photos | Very neat! Is the viewing panel sheet acrylic? Food for a lot of thought there. (And "Where do I store it"? ) A write up would be good. Howard |
duncan webster | 15/01/2019 22:31:44 |
5307 forum posts 83 photos | Definitely write up required, I want one! My compressor is not 3hp, Not sure what it is, it came from the tip. Can it work in short bursts from a smaller one with a reservoir |
Vic | 15/01/2019 23:30:46 |
3453 forum posts 23 photos | It may be worth pointing out that if you have the space (or need for bigger capacity) that there are bench top blasting cabinets on the auction site for under £70. |
I.M. OUTAHERE | 16/01/2019 01:44:35 |
1468 forum posts 3 photos |
If memory serves me correctly ( usually doesn't ) you can turn the other glove ( R/H one in the set ) inside out and it becomes a left hand glove . |
Graham Meek | 16/01/2019 10:23:36 |
714 forum posts 414 photos | This is the size of compressor that I use. Okay if you use it sensibly. Regards Gray, |
Les Jones 1 | 16/01/2019 11:00:12 |
2292 forum posts 159 photos | Hi Graham, Les. |
John P | 16/01/2019 12:42:34 |
451 forum posts 268 photos |
I built one of these sandblast cabinets 20 + years ago from It looks as if the vent on the back of the bin blaster has a My own cabinet is sealed and vented externally. Rubber gloves 24 inch in length are avalable from J&L John |
Graham Meek | 16/01/2019 14:40:24 |
714 forum posts 414 photos | Posted by Les Jones 1 on 16/01/2019 11:00:12:
Hi Graham, Les. Hi Les, Thanks for the welcome back, sometimes I wonder if I did the right thing, but we shall see. Regards Gray,
I keep my unit in an annex, it does not take up any real-estate in the workshop proper, (I cannot afford to waste the space) and is used mainly in this location. As regards costs, this unit cost no more than £20. Some of the items were ex-stores stock, others were salvage items. My first lash-up for the "blast box", a wooden box with a perspex lid, had no ventilation to the outside as such, but instead had a connection to the shop vacuum. In this design the need for the vacuum was felt unnecessary, but builders can fit one if they wish, using many of the domestic waste fittings. Two years on of occasional usage the filter is still clean. No doubt my internal baffle allows the heavier particles to fall before the air exits the filter. Regards Gray, |
Vic | 16/01/2019 15:42:42 |
3453 forum posts 23 photos | I use a shop vac hooked up to mine. It means the air in the workshop is cleaner and you can see what's going on in the cabinet better. |
