camcorder batteries
Clive Hartland | 10/01/2019 22:58:56 |
![]() 2929 forum posts 41 photos | I have neglected my camcorder batteries and have now found they will not charge. They are Sony NP-FM50's and are charged in camera. They sre Li-ion type. Has anyone any idea if I can resurrect them. I have ordered a new one but the originals I bekieve have a sensing circuit in them. Clive |
John McNamara | 11/01/2019 00:48:16 |
![]() 1377 forum posts 133 photos | Hi Clive Regards |
I.M. OUTAHERE | 11/01/2019 04:33:53 |
1468 forum posts 3 photos | I think Johns link was trying to show a video but for some reason i cant upload a working link to it and all i got were ads . I would hook up a variable power supply running to the positive and negative terminals and run it at the battery voltage via a 10 ohm 25 w resistor and give it a tickle - do it outside though just incase something goes belly up ! If things start getting hot turn it off ! The sensing circuit inside the camcorder is reading a voltage below its cut off threshold and won't recognise the battery until its voltage is above this .
Edited By XD 351 on 11/01/2019 04:36:49 Edited By XD 351 on 11/01/2019 04:39:23 Edited By XD 351 on 11/01/2019 04:41:08 Edited By XD 351 on 11/01/2019 04:43:20 |
Paul Lousick | 11/01/2019 04:43:48 |
2276 forum posts 801 photos | ebay sell replacement batteries and chargers for Sony NP-FM50. They are not expensive. Paul. |
John McNamara | 11/01/2019 07:27:02 |
![]() 1377 forum posts 133 photos | The link to a Google search worked fine here, anyway try these: One UK one state side. I had read of this problem with Sony before. Yes Youtube puts an adv in front of many videos, not a bug just a pain in the a...s Edited By John McNamara on 11/01/2019 07:29:41 |
Clive Hartland | 11/01/2019 08:07:56 |
![]() 2929 forum posts 41 photos | Thank you for the prompt replies about these sensing batteries. I will buy one of those chargers in the video I think. I will report back how it goes. Clive |
Howi | 11/01/2019 09:42:38 |
![]() 442 forum posts 19 photos | Li-ion batteries should not be discharged below a certain voltage otherwise permanent damage will result. I used to work in IT and had lots of Li-ion phone batteries that would not charge, simple slution was to apply pulses of 12v to the battery by repeatedly tapping the 12v pos to the Li-ion pos.Once you get the battery above it's minimum, the original charger would take over. you do this at your own risk of course. I would get a replacement battery myself if it is for camera use, plenty of batteries on ebay. never had a problem with 3rd party batteries on any of my cameras. Brand I use is EXPRO, not the cheapest but good capacity and fully compatable.
Ian Parkin | 11/01/2019 09:43:15 |
![]() 1174 forum posts 303 photos | I saw a video on YouTube about someone with the same problem He discharged them (if not already) then put them in the freezer for 24 hours then let them defrost well then recharge in the normal way Then all was good (apparently) |
Neil Wyatt | 11/01/2019 09:49:33 |
![]() 19226 forum posts 749 photos 86 articles | If you can access the cells directly there are inexpensive charger modules that can safely bring them up to a voltage where the built in charger will work. Another approach is repeatedly trying to charge, as if each time a small test charge is applied the battery may eventually recover. Neil |
john fletcher 1 | 11/01/2019 10:18:39 |
893 forum posts | Neil please tell me details about that module and from where it can be obtained. I usually follow an idea from ETI magazine (remember it) and ZAP my cells for the cordless power tools, it usually works but do get failures. John |
peak4 | 11/01/2019 12:23:38 |
![]() 2207 forum posts 210 photos | Posted by john fletcher 1 on 11/01/2019 10:18:39:
Neil please tell me details about that module and from where it can be obtained. I usually follow an idea from ETI magazine (remember it) and ZAP my cells for the cordless power tools, it usually works but do get failures. John John, how old was the article and was it for Li-ion or Nicad/Nimh. Apologies if you are already aware of the following, which isn't applicable to Li-ion; My way for the latter was to charge up a capacitor bank and flash discharge/zap across the cell terminals, having established which one(s) in the battery pack were faulty. This is for a different reason though; it's to fuse out the whiskers that can develop internally in each individual cell. When charging, the charge current passes through the whisker, which effectively shorts out that NiCad cell. The surrounding cells charge up, but not that one. Zapping the cell with a short high current blast burns out the whisker, just like blowing a fuse, and the cell can once again accept charge.
Bill |
Neil Wyatt | 11/01/2019 12:48:13 |
![]() 19226 forum posts 749 photos 86 articles | Posted by john fletcher 1 on 11/01/2019 10:18:39:
Neil please tell me details about that module and from where it can be obtained. I usually follow an idea from ETI magazine (remember it) and ZAP my cells for the cordless power tools, it usually works but do get failures. John Anything based on a TP4056 chip should work, expect to pay about 20p each (normally sold in batches of 10 boards). They have a connection for the thermistor to monitor the temperature of batteries and have some excellent features. The downside is they are strictly for 4.2V packs only:
Clive Hartland | 11/01/2019 14:28:52 |
![]() 2929 forum posts 41 photos | A replacement NP-FM50 battery has just arrived, I put it in the camera and it works OK. Now charging until the light goes out. The battery casing is identical in everyway to the original Sony battery casing ! No mark of origin/maker but obviously a clone battery. The output is slightly lower at 1700 ma instead of 1800ma. That does not bother me as if I can get the other two batteries up all will be well. I will have a quick look at other suppliers to see if their batteries have higher capacity. Thank you for the clear and concise details of charging, I will be careful. Clive Edited By Clive Hartland on 11/01/2019 14:30:07 |
Neil Wyatt | 11/01/2019 16:10:41 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Clive Hartland on 11/01/2019 14:28:52:
The battery casing is identical in everyway to the original Sony battery casing ! No mark of origin/maker but obviously a clone battery. The output is slightly lower at 1700 ma instead of 1800ma. T I have found that it is possible to get clone batteries for Canon cameras with much higher capacity, but a shorter lifetime, from the USA. N. |
Clive Hartland | 14/01/2019 17:01:25 |
![]() 2929 forum posts 41 photos | The battery charger arrived today and I put the first battery on charge, after 4 hours charge I tested the voltage and it is no good. The battery was slightly warm. Have now put the 2nd battery on charge and will test later this evening. Checking the life of the NEW battery i bought it has, after a full carge 123 minutes of service.Camera is working fine. Clive |
Clive Hartland | 14/01/2019 18:39:02 |
![]() 2929 forum posts 41 photos | 1840 hrs, the 2nd battery has been on charge for a while and I have measured 8.6 v between the terminals so I assume that one is OK. The camera will now be able to charge it as it above the threshold voltage to charge. Clive PS. the 2nd battery did not get warm ! the chager is giving 500 mA Edited By Clive Hartland on 14/01/2019 18:47:41 |
