Gary Wooding | 29/12/2018 12:08:54 |
1074 forum posts 290 photos | I've been bequeathed a Naerok bandsaw, which appears to be identical to the Clarke cbs355. The black rubber? drive-belt has a 1/4" circular cross-section and a length of 23" approx. It looks undamaged but slips under very light load. What's the best cure please?
not done it yet | 29/12/2018 12:51:10 |
7517 forum posts 20 photos | Hi Gary, Looks like they might use any one of three different lengths of 7mm diameter belt. Might yours need a smaller belt than the one currently fitted? |
Gary Wooding | 30/12/2018 07:53:19 |
1074 forum posts 290 photos | Thanks NDIY, but £30 a pop is somewhat extravagant. |
not done it yet | 30/12/2018 08:18:08 |
7517 forum posts 20 photos | Gary, If that is the case, you have a few options. 1) shorten your belt - glued or ‘welded together’? 2) Change one or the other of the pulleys, depending on whether you would prefer a faster or slower cut. 3) Wrap some good tape around one of the pulleys to ‘fill it out a bit’ and hope it wears well (probably only a temporary measure?) 4) Find a cheaper belt supplier. 5) Change to a narow section V belt system of some type (V, multi V...).
The single review on the Machinemart site amused me. The machine (no longer available) was constructed so flimsily that it broke, but the reviewer still gave it full marks! An insider review, methinks! |
I.M. OUTAHERE | 30/12/2018 08:45:25 |
1468 forum posts 3 photos | Check that there is no oil or the like on the pulleys . |
Paul Lousick | 30/12/2018 08:53:44 |
2276 forum posts 801 photos | Car accessory stores sell spray cans of belt grip solution that stops fan belts slipping. Clean belt and dive it a spray.
Edited By Paul Lousick on 30/12/2018 08:54:26 |
Michael Gilligan | 30/12/2018 11:38:17 |
![]() 23121 forum posts 1360 photos | Posted by Gary Wooding on 30/12/2018 07:53:19:
Thanks NDIY, but £30 a pop is somewhat extravagant. . As l have mentioned before; the Chinese equivalent seems to be of comparable quality to "Polycord" and is much cheaper. [caveat: I have only used the small diameters of the Chinese product] MichaelG. . Ref. my post on 03/12/201 https://www.model-engineer.co.uk/forums/postings.asp?th=139082&p=1 Edited By Michael Gilligan on 30/12/2018 11:39:41 |
BC Prof | 30/12/2018 13:40:21 |
182 forum posts 1 photos |
Looking at my 13yr old Clarke version the motor is foot mounted . The slots in the feet would be more than sufficient to allow both taking up the slack needed to stop the existing belt slipping or to accommodate a new belt . I purchased a spare from Machine Mart some 5 yrs a go . I can't remember the price but it certainly was not £30
Brian C |
Howard Lewis | 30/12/2018 15:42:12 |
7227 forum posts 21 photos | Working on the assumption that the belt is not bottoming out in the pulleys If it is, you need a larger section belt. If you choose to shorten the belt by cutting and rejoining, Cyanoacrylate ("Superglue" Howard |
not done it yet | 30/12/2018 15:47:31 |
7517 forum posts 20 photos | Howard, I think round belts should drive on the full half-circumference? Not like V belts?
Edited By not done it yet on 30/12/2018 15:48:39 |
Dalboy | 30/12/2018 17:21:18 |
![]() 1009 forum posts 305 photos | I have this machine as well that I was given but there was no belt tensioner on it so I constructed one with a spring to aid keeping the belt tight enough to run and not slip. I use it as a second bandsaw for smaller items |
