James Alford | 02/12/2018 11:06:36 |
501 forum posts 88 photos |
Can anybody identify this tool? It came in a box of old tools given to me recently. The button on top is part of a spring loaded plunger. There is a blade which travels to the end when the button is pressed. The blade travels in two slots to keep it steady. There is no evidence that as ever been hit with a hammer. It is well made, but there are no manufacturers' marks on it. James.
Edited By James Alford on 02/12/2018 11:19:39 Edited By James Alford on 02/12/2018 11:20:20 Edited By James Alford on 02/12/2018 11:21:43 |
roy entwistle | 02/12/2018 11:07:51 |
1716 forum posts | A photo would help |
James Alford | 02/12/2018 11:21:15 |
501 forum posts 88 photos | Posted by roy entwistle on 02/12/2018 11:07:51:
A photo would help I was posting from my phone and could not work out how to add the pictures............ Reverted to the laptop. |
Ian Parkin | 02/12/2018 11:26:28 |
![]() 1174 forum posts 303 photos | looks like a leather cutter you place the shoe on the work press with your palm on the knob and the blade comes down and just goes under the material and cuts as you glide the tool along your cutting line.. does that seem plausible as i’ve Not seen the blade |
Former Member | 02/12/2018 11:26:34 |
1329 forum posts | [This posting has been removed] |
Mick B1 | 02/12/2018 11:31:30 |
2444 forum posts 139 photos | Looks like some sort of a grooving tool to me - the blade looks a couple of mm wide and seems if it cuts square to the width? |
James Alford | 02/12/2018 11:33:21 |
501 forum posts 88 photos | . Edited By James Alford on 02/12/2018 11:33:35 |
James Alford | 02/12/2018 11:34:35 |
501 forum posts 88 photos | "A photo with the knob depressed showing the blade would be helpful. Thanks Bill" The third image down shows the plunger fully depressed. The blade is flush with the bottom of the tool and does not protrude. James. Edited By James Alford on 02/12/2018 11:37:38 |
Roderick Jenkins | 02/12/2018 12:03:43 |
![]() 2376 forum posts 800 photos | It looks a bit like a driver for holding a slot head screw. Is the "blade" slightly offset to provide a wedging action? Rod |
James Alford | 02/12/2018 12:18:18 |
501 forum posts 88 photos | Rod, No. The blade, assuming that it is a blade, is central to the tool and is in one piece. James |
Former Member | 02/12/2018 14:00:30 |
Martin Connelly | 02/12/2018 14:33:31 |
![]() 2549 forum posts 235 photos | Button remover. Martin C |
MichaelR | 02/12/2018 19:00:33 |
![]() 528 forum posts 79 photos | Could be a home made Punch Down Tool for phone/ethernet wiring Mike.
James Alford | 02/12/2018 21:11:43 |
501 forum posts 88 photos | Thank you for the suggestions. If I see the person who gave it to me again, I shall ask her whether she has any idea what it is. I believe that the tools were her husband's who has, I think, died. Knowing what he did for a living might give a clue. James. |
Bodger Brian | 03/12/2018 08:04:14 |
![]() 187 forum posts 40 photos | A few years ago, I visited Waterperry Gardens, where there is a small museum of rural items. In a cabinet there was a mystery item that was thought to be a tool used in the process of grafting plants. Although that one had a trigger mechanism, rather than a plunger, and was made of brass, I wonder if this is a variation on a theme. Brian |
Samsaranda | 03/12/2018 10:09:24 |
![]() 1688 forum posts 16 photos | Wife spent her working life as a tailoress and her opinion is that it could well be for removing buttons although she has never come across one, not to say that they don’t exist. Dave W |
John Reese | 04/12/2018 02:13:04 |
![]() 1071 forum posts | I would bet (a small amount) that it is a leather working tool for cutting a groove in leather shoe soles where the stitching goes. |
