martin perman | 22/11/2018 12:59:00 |
![]() 2095 forum posts 75 photos | Gentlemen, I collected my new saw blades this morning and whilst chatting to the saw company owners they asked what damping control my saw had, mine has an adjustable spring, they suggested that the spring method doesn't give a stable even load because as the blade drops down the weight of the carrier frame causes the load to change, its not linear. They suggested that several customers have modified their saws by fitting adjustable hydraulic dampers, I've had a quick look on the web and haven't seen anything small enough and adjustable, I could make my own but has anybody done this themselves. Martin P |
larry phelan 1 | 22/11/2018 13:24:05 |
1346 forum posts 15 photos | Martin, This very subject was covered in an article M,E.W a few years back. I still have the issue and will look it up later,if you wish.My intention was to make one for my own saw,but did I? not yet,anyway ! To date I have not had any problems with breaking blades,but there is no doubt that a damper would be a good idea. This might get me thinking again. |
martin perman | 22/11/2018 13:33:09 |
![]() 2095 forum posts 75 photos | Larry, It would be very good of you if you could copy it for me please, I've only been collecting MEW for the last couple of years. I will pm my email to you. Martin P |
larry phelan 1 | 22/11/2018 14:06:38 |
1346 forum posts 15 photos | Martin,Have just gone through a pile of my back numbers,without finding it,but do not give up yet ! I have mags all over the place and I did read it,so it,s there somewhere.I will dig up another pile and go through them [better than looking at TV ] What I need is a better filing system. No,what I need is a filing system ! Hang in there for another while. |
ega | 22/11/2018 14:11:06 |
2805 forum posts 219 photos | Lots of stuff on internet generally eg Yahoo 6x4 group. The CAHW.exe MEW index would probably help, too. eg MEW 50, page 51 Edited By ega on 22/11/2018 14:22:12 |
Brian Wood | 22/11/2018 14:32:40 |
2742 forum posts 39 photos | Larry, I maybe have a better filing system than you, all I will need is the issue number when you stumble across it !! Regards Brian |
larry phelan 1 | 22/11/2018 15:15:52 |
1346 forum posts 15 photos | Martin, For once the Gods are with me ! Why is it that it,s always the last mag you look at that,s the one you want ? Went through a pile of them plus many cups of tea and then----Bingo ! The issue in question is No 126 June 2007. Now,there are two ways of dealing with this; A I could try getting photo copies of the pages and post them to you B I could just post the whole mag to you and you could could send it back when you,re finished with it. I think this might be the better option since there,s other good stuff in there too. What do you think? Larry. |
larry phelan 1 | 22/11/2018 15:17:55 |
1346 forum posts 15 photos | Brian, That would not be hard ! Seems like we both hit pay dirt together ! |
martin perman | 22/11/2018 15:30:05 |
![]() 2095 forum posts 75 photos | Larry, Thank you, Have PM'd you. Martin P |
Gary Wooding | 22/11/2018 15:37:44 |
1074 forum posts 290 photos | See **THIS** |
martin perman | 22/11/2018 16:03:23 |
![]() 2095 forum posts 75 photos | Posted by Gary Wooding on 22/11/2018 15:37:44:
See **THIS** Gary, Interesting article, I've tried to join the group but even though I have a login I cant get access to the files. Martin P |
Clive Foster | 22/11/2018 16:03:48 |
3630 forum posts 128 photos | If considering DIY maybe a defunct car or, probably better as being smaller, motorcycle suspension damper might be a good source of most of the components needed. Will obviously need cutting down but taking metal off is easy. Drilling the rod for a concentric needle valve as per the link from Gary seems a hard way of going about things. In the absence of suitable tube for a concentric design it should be OK to use a separate valve assembly mounted off centre. This appears to be the common way of doing thinks on old school power hacksaws et al. The dashpot on my Rapidor saw is made that way. Alternatively the valve could be put at the bottom with an external oil return tube. Not seen that arrangement on simple dashpot dampers but I have seen it on rather more sophisticated systems so its known to work. Clive (who has about 8 old dampers lying around in the "bound to be useful material" store) |
martin perman | 22/11/2018 16:13:01 |
![]() 2095 forum posts 75 photos | Clive, You have just clicked a switch in my brain Martin P Edited By martin perman on 22/11/2018 16:13:36 |
Brian Wood | 22/11/2018 16:46:05 |
2742 forum posts 39 photos | Larry, Thank you, I have the copy in my hand [Smug so and so] I hear you say, what I don't have is a cross referenced index for all these potentially useful ideas that I might want to follow up. And yes I know we get that in MEW as well for each year. Regards Brian |
Clive Foster | 22/11/2018 16:47:18 |
3630 forum posts 128 photos | Martin Glad to be of service. Don't forget that you need a one way valve somewhere so the oil can return freely when the saw bow assembly is lifted ready for the next cut. Clive. |
Michael Cox 1 | 22/11/2018 16:59:22 |
555 forum posts 27 photos | Posted by martin perman on 22/11/2018 16:03:23:
See **THIS** Gary, Interesting article, I've tried to join the group but even though I have a login I cant get access to the files. Martin P The hydraulic downfeed and many other improvements to the bandsaw were described in detail, with full constructional drawings, in a series of articles in MEW 227, MEW 228 and MEW 229. Mike |
martin perman | 22/11/2018 17:03:49 |
![]() 2095 forum posts 75 photos | Mike, Sadly I didnt start MEW until after those numbers and dont have access to them. Martin P |
not done it yet | 22/11/2018 17:37:20 |
7517 forum posts 20 photos | Feb ‘65 ME has the dimensions of the dash pot used on the Edgar T Westbury hacksaw design/build. |
Martin Cargill | 22/11/2018 18:30:08 |
203 forum posts | Pneumatic cylinder idea has a downside in that the two ends of the cylinder don't have the same volumes ( because of the piston rod). I've seen machines using this idea but they have a second cylinder that the fluid uses as a reservoir when the capacity of the rod end of the main cylinder capacity isn't enough. Filling and bleeding the system can be a bugger to do though. |
Dave Halford | 22/11/2018 18:35:47 |
2536 forum posts 24 photos | The Kennedy 60 or 90 hacksaw has a very simple open system that works. |
