Mark Gould 1 | 08/11/2018 12:59:11 |
231 forum posts 131 photos | Gents, Our gearbox is leaking and I have a feeling its leaking at the drain plug. I have a rubber o-ring on it now but that hasn't really helped. According to the parts list, this part is called a Dowty Seal I have contacted Myford and they don't have them. Does anybody here know where I could order one of these?
Mark |
Michael Gilligan | 08/11/2018 13:04:02 |
![]() 23121 forum posts 1360 photos | Mark, A quick search on Google revealed many suppliers: This is one with good documentation: **LINK** http://www.barnwell.co.uk/products/bonded-seals/ MichaelG. . This is also worth a look: http://www.potterassoc.com/pdf/bonded_seal_information_and_sizing_chart.pdf Edited By Michael Gilligan on 08/11/2018 13:12:43 |
Mark Gould 1 | 08/11/2018 13:16:31 |
231 forum posts 131 photos | Michael, Many thanks, I should have turned to my Google fu before asking! I have asked Myford for the appropriate size and will order 1 or 2 from Barnwell. Thanks again, Mark |
David George 1 | 08/11/2018 13:21:42 |
![]() 2110 forum posts 565 photos | Hi Mark you can pick these up from any hydraulic hose repair shop "phone a hose" or similar cost very little. Just take the plug with you and they will give you corect washer. David
Edited By David George 1 on 08/11/2018 13:22:13 |
Mark Gould 1 | 08/11/2018 14:14:53 |
231 forum posts 131 photos | Ok thanks David
Mike Poole | 08/11/2018 15:11:15 |
![]() 3676 forum posts 82 photos |
Goodridge have them. Mike |
Fergus Stirling | 08/11/2018 15:53:27 |
![]() 15 forum posts | Mine leaks so much i assumed it was supposed to... what size does it take?
not done it yet | 08/11/2018 16:54:20 |
7517 forum posts 20 photos | If an agri repair shop is nearby, they would likely stock them. Not as cheap as a belt/bearing supplier, perhaps, but might save you more in fuel... I use ABC for most of my bits and pieces like that. |
Mark Gould 1 | 08/11/2018 17:48:37 |
The part where the seal sits measures 7/16 so I had to guess a metric equivalent as I am in the Netherlands. |
Mark Gould 1 | 08/11/2018 19:52:53 |
Are you sure that's the correct size, Mike?
Dave Halford | 08/11/2018 20:44:43 |
2536 forum posts 24 photos | Make a soft alu or annealed copper washer either should stop it. |
Howard Lewis | 08/11/2018 21:56:09 |
7227 forum posts 21 photos | A Dowty seal (washer) is a steel washer with a double sided elastomeric rubber seal bonded to the I D. Rather like a lip seal on both sides of the washer. Should be available from all sorts of sources. (Agricultural, hydraulic hose suppliers etc) Howard |
Mike Poole | 08/11/2018 22:15:38 |
![]() 3676 forum posts 82 photos | Posted by Mark Gould 1 on 08/11/2018 19:52:53:
There is a dropdown box on the link to select the size required. Mike |
Hopper | 08/11/2018 23:34:33 |
![]() 7881 forum posts 397 photos | Copper or aluminium sump plug washer from your local car parts shop will do the job. |
Flywheel | 09/11/2018 08:56:30 |
34 forum posts 1 photos | Mark, are you sure it is leaking from the drain plug? I had a leak on my gearbox which came from the hidden captive screw which is inside the box, this hidden screw has a rubber washer between the box and the lathe bed and that was where my leak came from, looking at the front of the g/box at the bottom left hand side there is a screw plug which has to be removed to let you get to the hidden screw, but sadly the g/box has to be removed to replace the rubber washer, on Myfords drawing of the g/box the drawing numbers of the parts are 136, 137 and 138 (hope this is of some help) Peter Edited By Flywheel on 09/11/2018 08:57:17 |
Mark Gould 1 | 09/11/2018 09:48:19 |
231 forum posts 131 photos | Peter, No, I am not sure and that is also a possibility, many thanks! As a precaution I have ordered 5 of those rubber 0-rings (BS / USA size 11 which is a 7.65mm ID, a 11.21mm OD and has a material thickness of 1.78mm). I am going to try and seat the washer without removing the 'box |
Brian Wood | 09/11/2018 15:24:05 |
2742 forum posts 39 photos | Mark, It is a lot of work to take the gearbox off to fit a pesky new 'o' ring in such an awkward position. From the Myford gearbox drawing, screw # 136 is said to be captive and looks to be waisted down the length below the head to the thread. It also has a 1/4 inch spring washer to help lock it in place Two possibilities occur to me
You might save a lot of time and refitting nausea by trying those suggestions. Regards Brian |
Mark Gould 1 | 09/11/2018 21:01:48 |
231 forum posts 131 photos | Brian, good idea. I was under the impression that the o-ring fit on the inside of the ‘box. The drawing shows otherwise as I see now. Bugger, I will try your suggestion. I ordered the o-rings anyway so will try and wangle a solution using them. Thanks again, Mark |
Brian Wood | 10/11/2018 11:18:22 |
2742 forum posts 39 photos | Hello Mark, I suggested a thick neoprene washer in particular as that will have better resilience and gap filling properties than an 'o' ring in a open situation between a washer and the gearbox housing inner surface. It may not even be machined at that point as the sealing is intended to be done by the 'o' ring sandwiched between the outer of the gearbox and what was once the mounting face for the leadscrew bracket. The spring washer locking the bolt on the inside may also have left a rough surface to seal against, another challenge for an 'o' ring to try and overcome and a further good reason for something more rugged This is just the approach I would try in your situation Regards Brian |
Mark Gould 1 | 10/11/2018 15:10:05 |
231 forum posts 131 photos | Brian, Understood. I’ll give that a try and report back. Thanks, Mark |
