Matt Harrington | 01/11/2018 11:14:10 |
![]() 212 forum posts 16 photos | I need to rebuild part of a mchine that has some telescopic driveshafts (about 18mm in dia) Each end is fitted to a uk and is locked in place with a c shaped spring (10mm width) to which is fitted a cross pin. So in cross section the clip looks like a circular letter E. I don't have the originals and I'm trying to source something similar - any idea what they are called? Matt |
Brian Wood | 01/11/2018 11:17:29 |
2742 forum posts 39 photos | Matt, Look for either C clips or E clips, you will recognise the ones that look right Brian |
wheeltapper | 01/11/2018 11:18:32 |
![]() 424 forum posts 98 photos | not surprisingly they are called E clips. look on E bay. Roy. |
David Standing 1 | 01/11/2018 11:20:21 |
1297 forum posts 50 photos | Do you mean lynch (or linch) pins? |
Matt Harrington | 01/11/2018 11:26:27 |
![]() 212 forum posts 16 photos | I have searched for ages and C Clips or E clips are not what I am after. Linch pin is along the principle but the spring is fixed to the end of the pin. I might need to do a sketch!!
Matt |
John Haine | 01/11/2018 11:31:14 |
5563 forum posts 322 photos | What's "a uk" |
ASF | 01/11/2018 11:32:16 |
131 forum posts 12 photos |
Is this the type of clip? Used on scaffold towers |
Tony Pratt 1 | 01/11/2018 11:33:47 |
2319 forum posts 13 photos | Posted by John Haine on 01/11/2018 11:31:14:
What's "a uk" At a guess it's a Universal joint. Tony |
Matt Harrington | 01/11/2018 11:37:24 |
![]() 212 forum posts 16 photos | John - sorry, yes UJ ASF - that's the fella but I need them to be about 18mm internal dia? Any idea what they are called? Matt Edited By Matt Harrington on 01/11/2018 11:47:45 |
wheeltapper | 01/11/2018 11:50:54 |
![]() 424 forum posts 98 photos | if you right click on the above picture and choose "search google for image" there are loads of them.
Roy. |
ASF | 01/11/2018 11:53:01 |
131 forum posts 12 photos | try searching scaffolding interlock clip |
Matt Harrington | 01/11/2018 12:23:57 |
![]() 212 forum posts 16 photos | Posted by wheeltapper on 01/11/2018 11:50:54:
Roy. Roy, All I get is Boss scaffolding and these are waaaay too big for me. The type is what I am after but I am struggling (no matter what I search for) to find smaller versions. Hence my quest to find out what they are called. Matt Edited By Matt Harrington on 01/11/2018 12:51:46 |
Neil Wyatt | 01/11/2018 13:34:35 |
![]() 19226 forum posts 749 photos 86 articles | Try sprong loaded retaining pin, these may do the job: |
Neil Wyatt | 01/11/2018 13:35:27 |
![]() 19226 forum posts 749 photos 86 articles | Or shaft locking pin... |
Matt Harrington | 01/11/2018 14:17:13 |
![]() 212 forum posts 16 photos | Neil, I have seen these ones. I'm not sure I have the space for the bit that sticks out. In addition, these see mto start at around 28mm dia which is too large for my application. Matt |
Robbo | 01/11/2018 14:29:33 |
1504 forum posts 142 photos | This type of spring clip and pin is widely used in the disability aid market, for securing adjustable legs on stools etc.by the pin going through corresponding holes in an internal and external tube They usually consist of a plastic horseshoe with a steel pin. In this context they are known as a "push-on pin clip" |
Mick B1 | 01/11/2018 14:36:34 |
2444 forum posts 139 photos | Try here:- Ah, no - didn't see any in 10mm. spring diameter. My missus has a Soari loom with adjustable-height legs that use these, but they're about 25mm/1in diameter. Edited By Mick B1 on 01/11/2018 14:39:29 |
JohnF | 01/11/2018 16:54:36 |
![]() 1243 forum posts 202 photos | Not quite what you describe but a similar device look on this link for "spring pins" **LINK** I searched for "spring clip clevis pin" and came upon this site, hope it helps [didn't look at sizes ] John
Matt Harrington | 01/11/2018 17:04:03 |
![]() 212 forum posts 16 photos | Thanks John - These are going to work one end but not the other as the clip had to sit on the end of the universal joint and not obstruct the sliding part. At this rate I will end up making some from clock spring steel and riveting a pin in. Search goes on.... Matt |
