ian j | 27/10/2018 17:37:37 |
![]() 337 forum posts 371 photos | This PM I managed to break the screw on my Abwood milling machine vise (it sheared where the roll pin goes threw) . Measuring the thread it's 5/8" x 8 tpi acme. So has any one got an old ML7 lead screw (5/8" x 8 tpi acme.) if it's warn that's OK as I only need approx 10". Thank you Ian |
Mike Poole | 27/10/2018 19:53:26 |
![]() 3676 forum posts 82 photos | A Myford leadscrew is LH, is that what you want? Mike |
ian j | 27/10/2018 20:10:19 |
Aah, I never thought of that ! No it will not do the job. Will have to have a rethink. Thanks for that info Mike.
Ian Edited By ian j on 27/10/2018 20:16:48 Edited By ian j on 27/10/2018 20:17:59 |
Antony Price | 27/10/2018 20:45:54 |
36 forum posts 29 photos | Try http://www.kingston-engineering.co.uk/
Tony |
David George 1 | 27/10/2018 21:24:25 |
![]() 2110 forum posts 565 photos | Rotagrip have some new screws and nuts for Abwood but not cheap. David |
Clive Brown 1 | 27/10/2018 21:44:38 |
1050 forum posts 56 photos | Years ago I repaired an old 4" Abwood by turning a new screw, 8 tpi was very simple on my Boxford. Doesn't need to be particularly tight tolerance on thread form, esp. if the nut is a bit worn. I used an HSS tool, hand ground. I used mild steel which proved entirely serviceable for hobby use,although something like En8 might be a better material.
ian j | 02/11/2018 17:19:13 |
![]() 337 forum posts 371 photos | Just an update. Kingston engineering show the standard length is 5 feet but when I inquired they replied they could supply 6" for £7.50 + £10 p & p + VAT. But then following Clive's comment I thought yes I have a lathe, milling machine & Google so after a bit of research on the internet and a practice on aluminum I produced a new screw which I'm very happy with.
mark costello 1 | 02/11/2018 18:09:31 |
![]() 800 forum posts 16 photos | We knew You could do it, You just needed to find that out! |
Neil Wyatt | 02/11/2018 18:22:13 |
![]() 19226 forum posts 749 photos 86 articles | It was lurking inside that bar the whole time! Neil |
Clive Brown 1 | 02/11/2018 18:23:41 |
1050 forum posts 56 photos | That's smart, well done! I didn't put a square on mine, just cross-drilled 1/2" for a tommy bar |
not done it yet | 02/11/2018 18:43:37 |
7517 forum posts 20 photos | Posted by Clive Brown 1 on 02/11/2018 18:23:41:
The Abwood vise handle is a well designed item, so it would be a shame not to utilise it! |
roy entwistle | 02/11/2018 20:08:45 |
1716 forum posts | Is that left hand ? |
