jimmy b | 27/10/2018 16:58:11 |
![]() 857 forum posts 45 photos |
Not seen one like this before! Jim |
mechman48 | 27/10/2018 17:10:51 |
![]() 2947 forum posts 468 photos | Oddball !, no good for 4 - 5 & 8 -10 mm blind holes methinks, doesn't show HSS so take them to be carbon steel. Anyone used one ? |
Brian Wood | 27/10/2018 17:24:21 |
2742 forum posts 39 photos | Only applicable to a limited material thickness as well before fouling on the next size increment A rather silly gimmick in my view Brian |
SillyOldDuffer | 27/10/2018 17:27:54 |
10668 forum posts 2415 photos | Not sure about these particular examples but the type is used in production to reduce the number of tool changes needed on an automatic. Job is done faster because one tap can cut 3 different threads without having to reset the machine. Obviously only worth using when a job requires several short threads of different diameters to be cut, like making metal boxes or radio chassis perhaps. I doubt they'd get much use in my workshop. |
larry phelan 1 | 27/10/2018 17:39:14 |
1346 forum posts 15 photos | I think I,ll pass on this one. |
Neil Wyatt | 27/10/2018 18:41:34 |
![]() 19226 forum posts 749 photos 86 articles | Clearly for sheet/thin materials. My guess is a specialist production system as has been said to reduce toolchanging. At that price I expect there was an oversupply or more left at the end of the job when expected and chronos snapped them up cheap. Probably worth having for hand tapping things like garden gateposts or roof trusses when you don't want to risk your best set. For about £4 keep it in your toolbox for emergencies. Neil |
Andrew Johnston | 27/10/2018 18:59:12 |
![]() 7061 forum posts 719 photos | They look to be quite poorly ground. I can't imagine any self-respecting machine shop using them. Generally sheet/thin metal isn't tapped in the conventional sense. One either uses self-tappers or inserts. I've never seen anything like them and I've spent many a happy hour poring over professional catalogues! I definitely won't be buying a set. Andrew |
Bazyle | 27/10/2018 19:10:09 |
![]() 6956 forum posts 229 photos | I guess you can get a stepped drill to go along with it |
SillyOldDuffer | 27/10/2018 20:09:14 |
10668 forum posts 2415 photos | Combination drill-taps are also used to speed up production:
Jeff Dayman | 27/10/2018 20:39:40 |
2356 forum posts 47 photos | They might be handy for electricians or control panel builders / service guys to tap or chase the odd thread as required in sheetmetal up to about 1.6 mm thick max. I don't think they are intended as a production tool, or for model engineers particularly. Vote with your wallet, or not..... |
Enough! | 27/10/2018 23:29:42 |
1719 forum posts 1 photos | Posted by Jeff Dayman on 27/10/2018 20:39:40:
I have one of these which is handy the odd time. Not a big-use item though |
John Reese | 28/10/2018 03:08:13 |
![]() 1071 forum posts | I have seen the multiple tap setup before. Many years ago I had a similar tap except it was on a screwdriver handle. It was primarily an electrician's tool. I used it for cleaning up cross threaded holes on electrical boxes. I would sometimes drill out the mangled threads and use the next larger tap. A screwdriver handle on the tap is much more convenient than having to use a t-handle tap wrench. |
