Andy Carruthers | 18/09/2018 22:30:56 |
![]() 317 forum posts 23 photos | Can anyone recommend a supplier of M5 x 0.5 pitch threaded bar and nuts? brass or stainless steel, to repair a 3D printer, ideally up to 500mm long |
charadam | 18/09/2018 23:13:49 |
185 forum posts 6 photos | A search for stainless 5mm studding on Ebay brings over 3000 hits.
Bill Phinn | 18/09/2018 23:14:52 |
1076 forum posts 129 photos | I get threaded bar here: https://www.toolstation.com/shop/Screws+%26+Fixings/d90/Stainless+Range/sd1030/Stainless+Steel+Threaded+Bar/p61139
peak4 | 18/09/2018 23:17:20 |
![]() 2207 forum posts 210 photos | Posted by Bill Phinn on 18/09/2018 23:14:52:
So do I, but unfortunately M5 x0.5mm pitch is metric fine. Assuming you have a lathe, how about a slightly off-beat method of making some. Two obvious issues with threading long bar are, manually threading- the die can easily run off, and for many lathe's there's no through hole in the tailstock. How about quickly knocking up a die holder for use in the 3/4 jaw chuck and feeding the 5mm bar in from the tailstock direction, rather than vice versa, as normal practice. To hold the 5mm bar, maybe use a small boring bar holder on the cross slide toolpost; that way you could have just a bit protruding in the direction of the headstock, and keep re-positioning the toolpost along the bar as the job progresses. Bill Edited By peak4 on 18/09/2018 23:33:47 |
Frances IoM | 18/09/2018 23:23:31 |
1395 forum posts 30 photos | 0.5mm thread is ISO M5 fine - the usual Tool station etc threads are ISO coarse 0.8mm thread - I can't recall any fine threads in their collection. Suspect you need a more specialised supplier. Edited By Frances IoM on 18/09/2018 23:24:17 |
Bill Phinn | 18/09/2018 23:40:26 |
Yes, Bill, it was sloppy of me not to read things more carefully. How about this? (It doesn't give the pitch though.) https://www.ebay.co.uk/itm/3D-Printer-5mm-Threaded-Steel-Rod-Cut-to-Custom-Lengths-M5-Bar-Shaft/191065265336?hash=item2c7c6094b8%3Am%3Am4_BexbsCwa281GHDcTGaAQ&var=490261409733 |
Andy Carruthers | 18/09/2018 23:40:57 |
![]() 317 forum posts 23 photos | Thanks to all for the suggestions - I've spent hours looking for a supplier and called a few To your point Bill, I have ordered a couple of M5 x 0.5 dies to thread my own bar as a last resort - I do like your idea too! |
Andy Carruthers | 18/09/2018 23:42:58 |
![]() 317 forum posts 23 photos | @Bill - you posted just before my response I know Darren @WeDo3DPrinting and he is on my list of contacts to call tomorrow |
duncan webster | 19/09/2018 00:43:09 |
5307 forum posts 83 photos | make a die holder to go in the toolpost and then you can power feed the die at the right pitch. Relying on the die self feeding will guarantee pitch error which might or might not matter. If you have a travelling steady you could screwcut it down to say 3/4 depth then finish with die Edited By duncan webster on 19/09/2018 00:43:29 |
Adam Stevenson | 19/09/2018 01:13:45 |
35 forum posts 1 photos | Had to buy some M6 ISO fine bar 300mm long in brass about a year back and used GWR Precision Limited they don't list M5x0.5 but they will make it. Cost about £7 for each piece but I couldn't buy the brass for that. |
not done it yet | 19/09/2018 07:06:06 |
7517 forum posts 20 photos | Duncan’s suggestion of travelling steady followed by a die to clean up the cut to size would be my favoured method. I would expect that Sterling Bolt and Nut Co Ltd in Peterborough could source it. Not the cheapest option, mind. |
John Haine | 19/09/2018 09:29:56 |
5563 forum posts 322 photos | If you are looking for m5 studding and nuts, why don't you just use standard M5? Or is this for a feed screw? |
peak4 | 19/09/2018 10:44:02 |
![]() 2207 forum posts 210 photos | Just re-read my reply and seem to have a grocer's apostrophe
Re Bill's post previously about the ebay studding; on the page, the vendor refers to nuts also being available, and on the nuts page he has the following comment High quality M5 Nuts Standard thread as used in many 3D printers Bill Edited By peak4 on 19/09/2018 10:48:12 Edited By peak4 on 19/09/2018 10:48:51 |
Juddy | 19/09/2018 12:26:11 |
![]() 131 forum posts | This place supplies up to 300mm lengths could be worth asking if they can supply longer:
Clive Hartland | 19/09/2018 15:31:08 |
![]() 2929 forum posts 41 photos | I would think a thread die cut rod would be a bit sharp for a lead screw application, a rolled thread would be preferable. |
Andy Carruthers | 20/09/2018 09:00:41 |
![]() 317 forum posts 23 photos | Juddy has the right answer Thanks again to all |
