Dalboy | 26/07/2018 21:45:37 |
![]() 1009 forum posts 305 photos | Is there a guide at what sizes a bar has to be for engineering thread as well as drill hole sizes something like what is in the Zeus book. |
Chris Evans 6 | 26/07/2018 22:08:56 |
![]() 2156 forum posts | Most of this info is on the net. Have you tried Google ? |
Oldiron | 26/07/2018 22:21:47 |
1193 forum posts 59 photos | Its all out there on the net or in Engineers handbook etc etc. As Chris says GOOGLE is a wonderful thing. Many people have their own little tricks for jobs they do but when it boils down to it there is a set of published standards that industry uses. regards |
Dalboy | 26/07/2018 22:38:42 |
![]() 1009 forum posts 305 photos | Cheers guys why did I not do that in the first place now I feel such a fool. But then the wife says I am all of the time Edited By Derek Lane 2 on 26/07/2018 22:38:59 |
I.M. OUTAHERE | 27/07/2018 02:20:22 |
1468 forum posts 3 photos | There are also a few apps for your phone / tablet like FSWizard etc . If you are using metric you just subtract the thread pitch from the thread diameter and that will be the tappiing drill size required ( 6mm dia and 1mm pitch = 6 - 1 = 5 so use a 5 mm drill ) .
Gary Wooding | 27/07/2018 08:15:43 |
1074 forum posts 290 photos | Some years ago I created a "crib" card in PDF format for use in my workshop. It contains tapping and clearance drill sizes for Imperial, Metric, B.A., and BSP threads, as well as Imperial-Metric conversion tables. All the tapping drill sizes were computed to give 65% engagement for small taps, and 75% for larger taps as determined in the Model Engineer's Handbook by Tubal Cain. Unfortunately, PDFs are not allowed in the albums so I have converted them to 300dpi JPGs as follows. I hope you find them as useful as I do. (They're called Mecrib1a_b_crn in my album called Stuff) Edited By Gary Wooding on 27/07/2018 08:26:12 |
SillyOldDuffer | 27/07/2018 10:20:09 |
10668 forum posts 2415 photos | Posted by Derek Lane 2 on 26/07/2018 22:38:42:
Cheers guys why did I not do that in the first place now I feel such a fool. But then the wife says I am all of the time Edited By Derek Lane 2 on 26/07/2018 22:38:59 Don't feel a fool Derek, no-one is perfect. One advantage of asking on the forum is you get a range of answers, and the possibility of more information and - if necessary - an exchange of questions and answers. Gary's crib sheet (thanks Gary!) allows me to draw attention to a potential ambiguity. You asked about 'Model Engineering Threads', and I think that's exactly what you meant, i.e the range of British threads developed for amateur modelling purposes. They're in Gary's Imperial Thread table under 'ME32' and 'ME40'. May be of interest to others that these special threads exist. I'm not sure how popular or well-known they are. I suspect they're in the 'good idea, very few bother' category. All my models use metric fasteners, but then I shall never win any prizes at an exhibition... Dave |
Michael Gilligan | 27/07/2018 10:48:25 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 27/07/2018 10:20:09: ... i.e the range of British threads developed for amateur modelling purposes. They're in Gary's Imperial Thread table under 'ME32' and 'ME40'. May be of interest to others that these special threads exist. I'm not sure how popular or well-known they are. I suspect they're in the 'good idea, very few bother' category. ... . The logic underlying these 'constant pitch' series is, I believe, that it's then simple to set-up a screwcutting lathe to produce any size in the series. MichaelG.
Samsaranda | 27/07/2018 11:08:41 |
![]() 1688 forum posts 16 photos | A free app that I use frequently on my IPhone in the workshop is IEngineer useful for cross referencing between imperial and metric. Dave W
Hopper | 27/07/2018 11:28:10 |
![]() 7881 forum posts 397 photos | Model Engineer's Handbook by Tubal Cain has the best set of tapping drill hole size charts I've come across for model sized stuff. He uses a thread engagement factor that allows for a slightly larger hole than most charts, which makes it easier to tap with less likelihood of snapping a tap. Yet the threads maintain 95%+ shear strength of full depth threads. It's an inexpensive little book crammed full of useful stuff. Must have for every workshop, IMHO. Tubal Cain also authored a book on Drills, Taps and Dies which goes into more depth in those specific areas. Both books are available from Tee Publishing. |
Andrew Johnston | 27/07/2018 11:30:35 |
![]() 7061 forum posts 719 photos | Posted by Michael Gilligan on 27/07/2018 10:48:25:
The logic underlying these 'constant pitch' series is, I believe, that it's then simple to set-up a screwcutting lathe to produce any size in the series. I think the idea was also to provide fine pitch threads for parts bigger than catered for by BA, but where BSW/BSF/BSP threads are too coarse. The obvious application is boiler fittings and pipework in general. I never use the 40tpi series but I do use 32tpi series for oilers, glands and specials where I need a fine pitch thread. Andrew |
Andrew Johnston | 27/07/2018 11:32:27 |
![]() 7061 forum posts 719 photos | Posted by Hopper on 27/07/2018 11:28:10:
Tubal Cain also authored a book on Drills, Taps and Dies which goes into more depth in those specific areas +1 - probably my most refered to book, especially the tapping drill size charts Andrew |
Gary Wooding | 27/07/2018 11:59:48 |
1074 forum posts 290 photos | Posted by Hopper on 27/07/2018 11:28:10:
Model Engineer's Handbook by Tubal Cain has the best set of tapping drill hole size charts I've come across for model sized stuff. He uses a thread engagement factor that allows for a slightly larger hole than most charts, which makes it easier to tap with less likelihood of snapping a tap. Yet the threads maintain 95%+ shear strength of full depth threads. It's an inexpensive little book crammed full of useful stuff. Must have for every workshop, IMHO. Tubal Cain also authored a book on Drills, Taps and Dies which goes into more depth in those specific areas. Both books are available from Tee Publishing. That's the acknowledged source of the data in my crib sheet. |
Dalboy | 27/07/2018 18:29:03 |
Posted by SillyOldDuffer on 27/07/2018 10:20:09: Don't feel a fool Derek, no-one is perfect. One advantage of asking on the forum is you get a range of answers, and the possibility of more information and - if necessary - an exchange of questions and answers. Dave Thank you all for the comments and pointing me in the right direction. Yes but I should know better being on many forums and also being the moderator one of the sister site to this one |
Howard Lewis | 28/07/2018 14:03:20 |
7227 forum posts 21 photos | There are only daft answers, very few daft questions! We all had to learn to talk and to walk, and the many other things that we do in life. All the books mentioned (Zeus Charts, Tubal Cain's "Model Engineer's Handbook, The Amateur's Lathe, The Amateur's Workshop and the Workshop Practice series etc) are useful. Also folk like Chronos, Tracy Tools, and The Tap and Die Company produce charts for tapping giving drill sizes. Based on my experience, if you are using Model Engineer 40 tpi, (and 32 tpi) threads remember that the thread depth is small (only 0.016" for 40 tpi) so will not drag a Tap or a Die held in a Tailstock along the lathe bed without risk of stripping. Do use a sliding Tap or Die holder, (My sliding tap holder is a shop made ER25 holder sliding on the arbor for the proprietary sliding Die Holder for the Tailstock). Good Luck, and don't be afraid to ask advice. Howard |
