John Rutzen | 21/07/2018 17:24:37 |
411 forum posts 22 photos | HI, I am looking for a supply of acid pickle for boiler making . Acetic acid has been suggested as easier to get than sulphuric. Does anyone know what concentration to use please?
SillyOldDuffer | 21/07/2018 18:46:04 |
10668 forum posts 2415 photos | Hot and strong. But rather than mess with a smelly slow acid, why not try dry pickling salts? This example is mainly Sodium Hydrogen Sulphate, sometimes called 'half-neutralised sulphuric acid'. Not as fast acting as Sulphuric Acid but quicker than any of the organic acids. Dave |
Roderick Jenkins | 21/07/2018 19:05:41 |
![]() 2376 forum posts 800 photos | This guy reckons you can use sodium hydrogen sulphate for anodising as well. **LINK** Rod |
Bazyle | 21/07/2018 19:26:07 |
![]() 6956 forum posts 229 photos | Citric acid is becoming popular. While acetic may be smelly, or make you hunger after chips, it has the advantage over sulphuric of being human friendly. I am using ex pickled onion vinegar for derusting and it is convenient to be able to stick your hand in and know you are not at risk. |
KWIL | 21/07/2018 20:03:43 |
3681 forum posts 70 photos | Buy drain cleaner, this one is 91% sulphuric acid. |
RRMBK | 21/07/2018 20:11:54 |
159 forum posts 18 photos | Citric acid is really good, safe and cheap. you can get 1 kg bags on flea bay for a few quid and I use about one large tablespoon in a mop bucket. cleans up copper easily and quickly and if you have a spill there are no nasty consequences particularly for pets For steel I use brick cleaner. again cheap, easy to buy and as I rarely silver solder large steel items I keep it in a large screw top jar and just drop the item in hot and put the lid back on loose to contain any fumes. |
Roderick Jenkins | 21/07/2018 20:22:43 |
![]() 2376 forum posts 800 photos | Posted by KWIL on 21/07/2018 20:03:43:
Buy drain cleaner, this one is 91% sulphuric acid. Where from? All sulphuric acid products in my local hardware store have been taken off the shelves and replaced by a notice explaining the recent changes in UK law. Rod |
Former Member | 21/07/2018 20:28:58 |
1329 forum posts | [This posting has been removed] |
Samsaranda | 21/07/2018 20:29:02 |
![]() 1688 forum posts 16 photos | Citric acid wins hands down no nasty fumes and benign to skin, ok doesn’t work as fast as the more aggressive acids but is all you need when using copper, and is cheap and readily available from the internet. As a bonus will descale coffee machines and kettles, perfectly safe. Dave W |
not done it yet | 21/07/2018 20:29:12 |
7517 forum posts 20 photos | Where from? South of the border? |
John Rutzen | 21/07/2018 20:39:28 |
411 forum posts 22 photos | HI thanks for all the input, bit confusing though, not sure what to try. I will see what is easiest to get . |
duncan webster | 21/07/2018 20:41:13 |
5307 forum posts 83 photos | I find that citric works a lot better if you heat it up. For small items I pour some into a glass jug and microwave it, before putting the brass bit in. You still ned to use scotchbrite, but just to wipe away the deposit. As others have said a lot safer than sulphuric |
Howard Lewis | 21/07/2018 21:24:56 |
7227 forum posts 21 photos | Concentrated acids, high potency ones such as Sulphuric, Hydrochloric, or Nitric must carry the risk of dissolving the parent material, plus the fumes generated. That should be reason to avoid them, in any form. Some of the organic acids such as Acetic, (Vinegar) or Citric may be slower acting, but will be less risky to operator and the material. Hydrogen salts of acids will be mildly acidic, and so rank with Acetic or Citric. Citric acid might be obtainable from a Home Brew store. Howard |
phil gardiner | 21/07/2018 23:38:27 |
18 forum posts | You can purchase citric acid from your supermarket, look in the cooking section. |
phil gardiner | 21/07/2018 23:47:10 |
18 forum posts | An easier way is just use lemon juice,it works better if you heat it up. |
David Wasson | 22/07/2018 02:52:42 |
![]() 149 forum posts 43 photos | Traditionally, the acid for cleaning copper has been sulfuric acid, which is basically battery acid like found in a car battery. Another acid, but much safer, is acetic acid. You can find it at a grocery store and is used for canning. It is a food product and is completely safe, that is to say, it won't eat holes in your clothes and the fumes will not rust your nearby tools. Sulfuric acid will though. You can also put your hands right in the solution without fear, if you have any cuts or abrasions on your hands, it will let you know about them! Acetic acid is probably not as aggressive as sulfuric acid, but, if you are willing to let a part soak overnight, or for a few hours, it works just as well and is so much safer. The cleaning on my copper boiler between soldering events, was done entirely with acetic acid.
I successfully built a 1" scale copper boiler, 5" barrel diameter and 19" long. All silver soldered and all parts cleaned with acetic acid. I bought two plastic bins large enough to totally immerse the boiler in. One bin had the acid, the other had fresh water. The stronger the solution, the quicker it will do the cleaning.
David
Keith Hale | 22/07/2018 07:35:21 |
![]() 334 forum posts 1 photos | Hi John. Answering the original question.. 10 gms per litre of water and Get it from cupalloys.co.uk Regards Keith |
not done it yet | 22/07/2018 08:09:12 |
7517 forum posts 20 photos | Posted by CuP Alloys 1 on 22/07/2018 07:35:21:
not done it yet | 22/07/2018 08:17:26 |
7517 forum posts 20 photos | Posted by not done it yet on 22/07/2018 08:09:12:
10g of ethanoic per litre of water? 1%w/v? Do you really mean that? Might just as well buy (proper) pickling vinegar. That should be about 9% v/v.! Avoid the usual supermarket stuff as that is only about 6%, these days. |
Russell Eberhardt | 22/07/2018 09:23:13 |
![]() 2785 forum posts 87 photos | Posted by Howard Lewis on 21/07/2018 21:24:56:
Concentrated acids, high potency ones such as Sulphuric, Hydrochloric, or Nitric must carry the risk of dissolving the parent material, plus the fumes generated. That should be reason to avoid them, in any form. Copper does react with concentrated sulphuric acid and with nitric acid in any concentration. It doesn't react with hydrochloric acid at all nor with dilute sulphuric acid. Hydrochloric acid produces corrosive fumes so isn't nice in the workshop hence the traditional recommendation for using dilute sulphuric acid for cleaning boilers of oxides and flux. Sulphuric acid isn't terribly dangerous when diluted to about 5% concentration (add the concentrated acid to the water not the other way round). Wear goggles to protect your eyes and if it is splashed on the skin wash it off with plenty of water. Russell |
