Super 7 spindle crank handle
C J06/07/2018 20:25:30
113 forum posts
86 photos
My take on a spindle crank handle for my Super 7 lathe who's bore was more like 16mm than 19/32". I made the main shaft from bar so had to push a 6mm drill bit through 210mm which took a bit a bit of clearing!
Edited By C J on 06/07/2018 20:26:39
Edited By C J on 06/07/2018 20:29:44
DMB06/07/2018 21:32:48
1585 forum posts
CJ,
I made something similar a long time ago but was always fearful of forgetting to remove it after use. I bought a spoked wheel off an exhibition junk stand and fitted it to a spindle like yours but shorter so easier to drill out. I still have to remove it before turning but at least I feel safer, should my sieve like brain let me down. There is a small lever handle on the rim and I think that it causes a small out of balance load resulting in chatter when turning. That is why I still remove it.
C J06/07/2018 21:45:41
113 forum posts
86 photos
Hi John,
I get distracted very easily so I'll have make a big "Check for handle" sign next.
I made the handle for cutting short threads instead of playing Russian roulette with the clutch!
Colin
Edited By C J on 06/07/2018 21:46:00
Jeff Dayman06/07/2018 22:06:13
2356 forum posts
47 photos
Hi Colin,
Maybe you need a "REMOVE BEFORE FLIGHT" streamer as used on aircraft, for your handle!
http://www.aircraftspruce.ca/catalog/pspages/ljrstreamers4604.php?gclid=Cj0KCQjwpvzZBRCbARIsACe8vyLfFzqBbdaRUpiwMQ2TTefltfxdFzgxoOSA4MDwVspvnZnc1XtXQssaAp08EALw_wcB
Great job on the handle BTW.
C J06/07/2018 22:23:49
113 forum posts
86 photos
Ha ha
And I cut the slots with a hacksaw too.
Edited By C J on 06/07/2018 22:26:00
David George 106/07/2018 22:55:00
2110 forum posts
565 photos
Why does it need to be so long it would drive the spindle from the end without having to be so difficult to make?
David
C J07/07/2018 00:11:17
113 forum posts
86 photos
The bore of my spindle tapers slightly towards the middle so I thought to position the expanding part at the point but as an aside I suppose a longer shaft helps the he handle to run true.
Edited By C J on 07/07/2018 00:12:08
Simon Collier07/07/2018 00:39:55
525 forum posts
65 photos
There was a beautiful one with balanced ball handle in probably MEW, 10 or so years back. I just had a quick flick through looking at covers but it might not have been on the cover. The lathe ran smoothly with the handle attached, just for testing and not recommended. Might have been David Piddington ??
Speedy Builder507/07/2018 06:59:46
2878 forum posts
248 photos
if you had a DEWHURST type reversing switch, you could remove the lever handle from the switch and use that as the handle for the crank.
BobH
David T07/07/2018 08:51:49
76 forum posts
14 photos
That's a nice looking handle. I made mine from the Hemingway kit, I wonder how I ever got on without it.
Posted by Speedy Builder5 on 07/07/2018 06:59:46:
BobH
Now that's a clever idea...
Ady107/07/2018 09:07:36
6137 forum posts
893 photos
One with a sprag bearing might be safer
The the handle only turns when the operator turns it
Like a motor boat starter
Brian Wood07/07/2018 09:26:00
2742 forum posts
39 photos
The proper solution is to find or create a universal form of safety interlock that positively prevents a motor start when the handle is in position
Speedy Builder offered an ingenious idea on just the right lines but it would only work of course on lathes equipped with Dewhurst switches.
SillyOldDuffer07/07/2018 09:37:34
10668 forum posts
2415 photos
I made one for my mini-lathe and very useful it was too. For some reason I've not felt the need to make one for my bigger lathe, probably because it can do 30rpm rather than the mini-lathes minimum 150.
Anyway, rather than attach a permanent handle, I put an nut of the end and drove it with a ratchet spanner handle.
(My version gripped the spindle with sliding angled blocks tightened by a threaded rod. (Wish I had a photo - it was based on the way handlebars are fixed to a bike if that helps.)
The advantage of a detachable handle is being able to safely leave the gripping part fitted inside the spindle when doing other work. The disadvantage is it's easy to power up the lathe after forgetting to remove the handle. Quite scary!
KWIL07/07/2018 10:16:11
3681 forum posts
70 photos
You could always make a stowing receptable, that makes an interlock that only allows motor start when handle is in its righful place.
JohnF07/07/2018 11:39:15
1243 forum posts
202 photos
One of my “to do” jobs but have managed for 40 years without one ! However I always had in mind to make spring loaded dog clutch for the drive, just 2 pegs on the handle and 2 slots on the spindle part, similar to the ones on the knee/table on milling machines. Thus you need to push in and engage the handle when in use, when you let go it disengages . Not a get out of jail free card but if the machine was inadvertently started with the handle in place it’s only friction that could drive it and that’s unlikely I think?
The sprag clutch is a good idea but it will drive only one way.
Simon Collier07/07/2018 23:57:08
525 forum posts
65 photos
The article I referred to above was in ME
https://www.haythornthwaite.com/4341%20Mandrel%20Handle.pdf
Sorry, I don't know how to make the link live
Michael Gilligan08/07/2018 00:02:20
23121 forum posts
1360 photos
Thanks for the reference, Simon
... Here's your **LINK**
