L. H. Sparey Running Centre
James Jenkins 121/06/2018 19:25:22
162 forum posts
7 photos
Hi all,
I am looking at the running centre in L. H. Sparey's book The Amateur's Lathe (pg. 57 in my copy) and contemplating whether this would make a good first middling project. It seems fairly straight forward and would be a very helpful addition to my set up. Couple of questions that maybe you can help with:
1. What do you think of the design?
2. It seems unlikely that the specified Hoffman T.E XBY & S.K.F R7 bearings are going to be available, any suggestions on replacements?
3. Cast steel seems a bit tricky to get hold of too, would silver steel be an acceptable alternative?
Many thanks for your time and look forward to hearing your thoughts.
James
Jens Eirik Skogstad21/06/2018 19:52:57
400 forum posts
22 photos
I has made the L.C Sparey running centre from The amateur's lathe. The design is good and i am very satisfied to use the running centre in many year now.
The house is made of mild steel (no important to be cast iron, hard or high alloy) and the running cone is made of silver steel.
The bearing must be selected to nearest in all dimensions ,also change the dimension in the house and the running cone to fit the bearings.
Light press fit the bearing in the house and hand push fit the running cone into the bearing. Never light press fit the running cone into the bearing due the bearing will stuck!
Fill up grease into the house before the running cone is mounted.
James Jenkins 121/06/2018 21:38:36
162 forum posts
7 photos
Hi Jens,
Thank you that's really helpful. What bearings did you use?
Kind regards,
James
Jens Eirik Skogstad22/06/2018 00:18:52
400 forum posts
22 photos
The bearing size..
Single row angular contact bearing 12x32x10 SKF 7201BEP
Deep groove ball bearing 10x26x8 SKF 6000
smiley
James Jenkins 122/06/2018 07:54:22
162 forum posts
7 photos
Thank you!
bricky22/06/2018 08:11:22
627 forum posts
72 photos
Hi James, I made two rotating centres from his plans 40years ago and they are still going well today.Why two,at the time I was making clocks and I needed a fast speed for my flycutters which I mounted in a bar between the centres with a pulley on it and driven from a motor mounted behind this got me to over 3000 rev's and the centres stood this easily.
Frank
Robbo22/06/2018 09:44:49
1504 forum posts
142 photos
James
Like most of the designs in 'The Amateur's Lathe', Sparey first published this in 'The Model Mechanic' magazine, of which he was Editor. This one was in July 1948.
In the text he said that "As the centre revolves, it may be made of mild steel, but a steel of harder grade is preferable as this will withstand accidental damage much better. A cast steel or silver steel may be used- although the centre is not hardened...……."
For those with an interest in such things I have put a copy of the 2-page article in my albums as "Sparey Running Centre"
Michael Gilligan22/06/2018 10:06:39
23121 forum posts
1360 photos
Posted by Robbo on 22/06/2018 09:44:49:
... For those with an interest in such things I have put a copy of the 2-page article in my albums as "Sparey Running Centre"
And I have grabbed a copy for reference, Thank You
... an excellent, concise description of the work.
Ian S C22/06/2018 11:01:21
7468 forum posts
230 photos
When I first got my lathe, I made a number ( probably a dozen) of running centres of a similar design (I didn't know of Sparey's book), I used what bearings I had, and made the centre from a bit of old car axle. I sold them as suitable for a wood lathe, and made them with #1, and #2 MT. $NZ 25 each twenty five years ago, not too bad for a practice exercise.
Ian S C
Bob Stevenson22/06/2018 11:16:47
579 forum posts
7 photos
Sparey is still good for everything but a bit dated now. If you are going to make a live centre take a look at Steve Jordan's video here as his is a more modern take that gives greater facilities, especially on small lathes...
https://www.youtube.com/watch?v=L0ZTw5J8oTE
Michael Gilligan22/06/2018 11:20:34
23121 forum posts
1360 photos
That's neat, Bob yes
Alan Jackson22/06/2018 11:23:16
276 forum posts
149 photos
Hi James,
If you look at my photos you will see a simple design I made years ago and its still working very well.p1040869.jpg
Alan
John MC22/06/2018 11:34:39
464 forum posts
72 photos
Reading this thread makes me feel old! Made a Sparey running centre 40+ years ago when the imperial size bearings were cheap and readily available. I asked if I could make it at work during my apprenticeship, it was considered to be a good grinding exercise, so everything hardened and ground. Made it with a 2 Morse taper to suit the lathe I had at that time, sold with that lathe after about 15 years use, still going strong now.
duncan webster22/06/2018 11:45:07
5307 forum posts
83 photos
I lost the will to live part way through the You Tube, but the cross between an inside caliper and a DTI looked a useful bit of kit, anyone know it's proper name?
Of the 2 the Sparey design looks the better, the rotating part should be a tight fit in the bearings, the outers can be slip fit. Rather than the press fitted seal you can get shielded bearings
Bill Davies 222/06/2018 12:27:23
357 forum posts
13 photos
The bore gauge looks nice, Duncan. Here is a Mitutoyo version:
Just don't look at the price!
Bill
duncan webster22/06/2018 12:35:06
5307 forum posts
83 photos
I'm glad I was sitting down! However, knowing the name I searched on e-bay and found an ad for MEW99 which has an article on how to make one. Another job for the to-do list!
Edited By duncan webster on 22/06/2018 12:35:34
James Jenkins 102/11/2018 19:20:28
162 forum posts
7 photos
Hi all,
I have worked through L. H. Sparey's design and modified it for modern metric bearings. I have used slightly smaller ones than Jens Eirik, to maintain the same proportions as Sparey, but taken up the suggestion of an angular bearing at the front. This will be used on a 1MT lathe, so I didn't want it to become any bigger, already, sadly, some of the lovely proportions of Sparey's 2MT design have been lost.
One ideal I did have since doing the drawing is to put a small hole up the morse taper, so as to be able to knock the shaft out when it needs cleaning (obviously then re-turning the taper).
I would be interested in any thoughts you might have or suggestions.
Kind regards,
James
James Jenkins 102/11/2018 19:20:48
162 forum posts
7 photos
James Jenkins 102/11/2018 19:22:13
162 forum posts
7 photos
I should have said, if anyone would like a .pdf of this design please just let me know.
James
not done it yet02/11/2018 19:33:57
7517 forum posts
20 photos
James,
Metric in this century? I note the mixed units!
