Red fibre gasket material
Suppliers?
Tim Stevens14/06/2018 18:44:25
1779 forum posts
I have a need to make up odd-shaped gaskets from the stuff that red fibre washers are made from. As often used for petrol fittings, and plumbing joint washers, etc. Lots of firms do the washers, but who, please sells the stuff in sheets? And what is the proper name for the stuff?
Thanks - Tim
John Reese14/06/2018 18:52:19
1071 forum posts
Try searching for vulcanized fiber. It is readily available in the US and I expect it should also be in the UK. Shops that rewind electric motors may have some scraps available.
Michael Gilligan14/06/2018 18:53:52
23121 forum posts
1360 photos
This looks a good place to start, Tim : **LINK**
https://direct-gaskets.co.uk/
alan-lloyd14/06/2018 19:40:27
183 forum posts
Try klinger statite from rs components
IanT14/06/2018 21:15:31
2147 forum posts
222 photos
Pretty sure I brought mine from Blackgates Tim - but I haven't checked their current catalogue...
IanT
IanT14/06/2018 21:34:24
2147 forum posts
222 photos
Mmnn - yes - page 135.
Three thicknesses of "Sheet Jointing (Gasket material)" available. Up to 400 degrees - 0.5mm, 0.75mm & 1.5mm thick - described as Hallite/Dixal or similar.... Not as thick as some plumbing fittings/washers probably but plenty fine for most model work.
IanT
daveb14/06/2018 21:41:20
631 forum posts
14 photos
It is called Red Fibreboard, appears to be made of compressed, chemically treated felt. I have some thick stuff, how much do you need?
peak415/06/2018 00:34:47
2207 forum posts
210 photos
Here you go, must order some myself as my stocks are getting low.
Hopper15/06/2018 10:05:18
7881 forum posts
397 photos
If you are making gaskets, why not use proper gasket material? Red fibre is not particularly flexible or easy to cut and probably won't seal that well without the kind of pressure applied to it that a washer gets in a screwed fitting application.
Tim Stevens15/06/2018 22:07:26
1779 forum posts
Hopper asks: If you are making gaskets, why not use proper gasket material?
Well, yes, I would, but I'm not, in this case. What I need is a plate of (electric-) insulating material which looks as though it was made in 1930. There are many better materials now, but for some jobs a 'period' appearance is preferred. And of course, for some jobs, red fibre is proper gasket material, still.
And now I know what to look for, I have found it on the interweb, and a couple of sheets are going to arrive next Wednesday. Or not.
Thanks, everyone, I think I am sorted now, but if not, there are several addresses for another try.
Regards, Tim
Ian S C16/06/2018 13:19:59
7468 forum posts
230 photos
If you have a bit of old circuit board with a section with no holes, strip off any copper, and there you go, old boards tend to be larger, with larger areas without components.
Ian S C
daveb16/06/2018 16:00:11
631 forum posts
14 photos
Posted by Ian S C on 16/06/2018 13:19:59:
Ian S C
This reminded me, when I first started assembling printed circuit boards they were made out of Paxolin (SRBP), after a few years the manufacturers changed to glass fibre sheet. Dave.
Ian S C17/06/2018 12:40:34
7468 forum posts
230 photos
Unless you want the strength of fibre glass, it's the old Paxolin board you want.
Ian S C
