Flycutter help
Dished surface
ChrisB06/06/2018 09:37:26
671 forum posts
212 photos
Hello,
Need some help flycutters in particular on how to make one cut an acceptable flat surface.
I built my own cutter based on pictures I saw of a Suburban tools cutter. I had read that the mill head must be precisely adjusted to be able to get a good flat surface so I had a go at it and after what I believe was a sufficiently close adjustment of the head I proceeded with a face cut on a piece of aluminium.
Unfortunately the result was not what I was expecting...feeding the work right to left, initially the cutter cut the workpiece with the cutter tip travelling towards me, as I continued feeding the workpiece it came to where the cutter is travelling away from me, but it did not touch the work piece.
Then I tried feeding from left to right, the cutter travelling away from me cut the workpiece a first pass but as I continued feeding the cutter took a second cut (as it was travelling towards me) which I think was quite deep.
Something must be wrong but I cant figure out what...the mill tilt seems to be in alignment left to right. dont know if the flycutter itself could be the cause, it's just a cutter no? there's no adjustments in it involved right?
Not sure I'm explaining my self well as it's a bit difficult to explain myself with words - will try to post some pictures
Hopper06/06/2018 09:52:59
7881 forum posts
397 photos
Bit of detail on how you made the flycutter, size of flycutter, and what type and size of machine you are using would help. Pics of the set up and the resulting cut surface would be invaluable as well.
Did you "tram" the mill head using a dial indicator, to within .001"?
Have you double checked this reading to make sure the mill head has not moved under load? Sometimes they do that if there is not a dowel pin to ensure positive location.
Also, did you lock all slides except the one in use while making the cut? And are all gibs adjusted correctly so no excess table movement?
Edited By Hopper on 06/06/2018 09:54:23
pgk pgk06/06/2018 09:53:37
2661 forum posts
294 photos
As I understand your description - Your mill head is tilted to the right or the work is canted to the left. A second pass would eliminated workpiece tilt as the cause.
I must admit that soemtimes the visual appearnace of finish is better on my flycut pieces when mill is slightly tilted so one doesn't get the cross hatch of a level mill..particulalrly on ally and I get my best finish using a home made flycutter with a round insert on mild steel. But then there's folk here who have fly-cut a lot more stock than myself.
pgk
geoff adams06/06/2018 09:53:56
214 forum posts
207 photos
Hi Chris your head is not square to the table you need to clock the head up use two paralles and a bar in the chuck as long as possible with a clock attached swing from one end of your table to the other adjust the head so the clock reads zero both ends there is videos on utube look under tramming
Geoff
Neil Wyatt06/06/2018 10:15:34
19226 forum posts
749 photos
86 articles
Because of the large diameter of the cut, nothing is as sensitive to misalignment as flycutting.
With a sharp tool you only need to be 0.01mm out over the diameter of the cutting circle to see a problem.
This error would be undetectable with a normal end mill.
Some people prefer a double cut, always cutting in the direction that gives on, saying it give the best finish.
To be acceptable the error needs to be tiny so that the surface is still acceptably flat.
You don't say the radius of you cutter or how far from flat the resulting surface is. I suspect that unless you used an indicator the mill may not be as well aligned as you think.
If you don't have an indicator, you can use a shim (such as a spark plug feeler gauge - any thin metal of consistent thickness will do) between the end of the flycutter and the mill table.
Mick B106/06/2018 10:38:22
2444 forum posts
139 photos
The effect described means simply that the movement of the table is not truly parallel to the plane of the circle defined by the tip of the flycutter.
I do quite a bit of flycutting in the vertical slide on the lathe, and I just use a boring bar with a 45 deg square section toolbit ground to a vee of about 70 deg to give side and face clearances.
I think the problem you have relates purely to tramming of the head in the direction of feed, so that the trailing edge of the swept circle is closer to the table than the leading. Sorry if I'm stating the obvious.
Edited By Mick B1 on 06/06/2018 10:39:40
ChrisB06/06/2018 10:39:59
671 forum posts
212 photos
Yes I know, should have added more details I'm sorry.
So the mill is a WM18, have had it for the past year and a half, with no issues.
As for the fly cutter its this pictured below, the head mounts on to an R8 arbor - direct fit into the WM18 spindle,
the bar is 7inches long adjustable (I was facing at about 5" swing approx) The insert is a Seco TNMA 160408 CBM050C I want to change this to a different material, but that is what I had at the moment.
The insert is angled back 7deg for clearance.
This is how I set up for milling, the workpiece held on parallels on a precision vice
Checked for head tilt by means of a dti on a 6mm R8 collet directly in the spindle. Left 0mm; right 0mm; fwd -0.06mm; aft +0.06mm
Cant adjust the head nod, fwd to aft but dont think it affects the surface being dished or not.
Surface finish, feeding right to left - initial face, and continued feeding ....
......continued feeding right to left same pass, second cut (should not have happened I think)
I checked again the alignment after facing the workpiece and got exactly the same readings.
ChrisB06/06/2018 10:45:36
671 forum posts
212 photos
the work piece is 3" wide, I could slip a 0.06mm feeler in the middle. I set the speed at 250rpm, did not dare to go any faster because it would start vibrating above 300rpm ( It does not help to have the mill mounted on a bench on wheels - I have to sort that out)
Feed I cant tell, as I'm manually feeding the table but I would say I was pretty slow, maybe 1mm per 2 seconds
Edited By ChrisB on 06/06/2018 10:51:45
Mick Henshall06/06/2018 10:50:09
562 forum posts
34 photos
Just a thought Chris, turn the workpiece 90 degrees and shorten the overhang of the cutter
Mick
Vic06/06/2018 11:15:46
3453 forum posts
23 photos
Posted by Mick Henshall on 06/06/2018 10:50:09:
Mick
Good idea. That’s what I would have done anyway.
Martin Kyte06/06/2018 11:26:54
3445 forum posts
62 photos
With a 10 inch cutting circle and the head 0.006 degrees out of perpendicular you get a 1 thou diferrence between the leading and trailing edge. With a 4 inch cutting circle the head only needs to be within 0.014 degrees for the same difference. So as Mick Henshall says reduce the swing. If the fly cutter is very out of balance that will not help either.
regards Martin
Edited By Martin Kyte on 06/06/2018 11:27:39
David Standing 106/06/2018 11:37:50
1297 forum posts
50 photos
Posted by ChrisB on 06/06/2018 10:45:36:
There's a clue there.
You don't have a fly cutter there, you have a NASA astronaut centrifuge! **LINK**
But seriously, I have a WM18, and it would just feel wrong to put a fly cutter with that swing on it, especially without a way of accurately counterbalancing it. That's a lot of rotational mass flying round in relation to the size of machine.
And to get it to cut accurately, with around a 10" swing, is a tall ask too.
Ian P06/06/2018 11:51:08
2747 forum posts
123 photos
I agree totally with Neil that flycutting is the highly critical indicator of tramming errors. It follows then that a flycutter is probably the best thing to use when you want to adjust the tram, however doing it really requires a very large workpiece in combination with the largest radius fly cutter.
If one could fasten a large sacrificial plate to the table say using countersunk fixings and then did test cuts using maximum X and Y travel then it could be trammed to near perfection. (sharp tools, spring cuts, table sag etc being taken into account). Bear in mind that even though the spindle is truly vertical, its only vertical with respect to the surface that has just been machined. That surface is the plane described by the X and Y dovetail slides, not the mill table surface which could theoretically be slightly tilted.
I spent quite a long time tramming my Emco mill using a micron DTI at the largest radius and the hardest part was getting a stable reading as the tip travelled over the table surface. I eventually interposed a platter out of a defunct hard disk drive as they are exceptionally flat and smooth. (BTW I'm in the group that likes to see a cross hatched pattern on the finished fly cut surface)
Ian P
David Standing 106/06/2018 11:57:07
1297 forum posts
50 photos
Posted by Ian P on 06/06/2018 11:51:08:
Ian P
Me too! yes
ChrisB06/06/2018 11:58:32
671 forum posts
212 photos
Posted by David Standing 1 on 06/06/2018 11:37:50
LOL! Yep, it's a bit on the larger side tbh, I sized it to be able to face over the whole width of the table if I needed...but still, I don't think you will need to spin it much faster over that swing. At 250rpm on steel the chips come out blue, so my guess is if I went any faster I'll get fireworks going. Still as mentioned, the mill bench is on wheels so I need to lift it off them to know it's real vibration speed limit.
It didn't occur to me that the larger the swing the more accurate tramming needs to be, and it's not so easy to adjust, a bit fiddly...at least there is an adjuster screw on the right side of the head! While on the subject, is it possible to adjust the nod of the WM18 and is it worth doing? I counted a total of 0.12mm over the width of the table (8" The column has 4 allen bolts, but I cant see any discontinuity between the column and the table, seems like a solid piece.
Will try as suggested, reduce the swing and rotate the work piece....will have to wait till tomorrow tho, working late shift today
JasonB06/06/2018 12:05:30
Stick the dti on your table and run it along in the x-x direction both without the vice on the table and also with the vice to one end as you have it in your photo.
Could be table is tilting/sagging or not running parallel even though it trams 0-0 with an empty table in the central position.
Martin Kyte06/06/2018 12:12:20
3445 forum posts
62 photos
Posted by ChrisB on 06/06/2018 11:58:32:
If you can be bothered you could take the column off the base and check that there are no paint flashes or burrs fouling the mating surfaces. Don't just assume that the column is at fault though. If the column is perfect the spindle also needs to be parallel with the column. It is a hobby mill after all and with a 10 inch measuring circle you are doing a very sensitive test. Mill up and down with a 6mm slot drill and you will not even notice. Don't go chasing negligible misalignments you will drive yourself crazy.
Mostly I flycut if I want a good finish rather than needing something very flat. If it has to be that flat, scrape it. Or lap it with a piece of emery on a surface plate.
regards Martin
ChrisB06/06/2018 12:17:20
671 forum posts
212 photos
Nah, I'm not going to take the thing apart, I'm not sending a rocket to the moon. I just want to know what's acceptable and what can be done to make it better within reason.
I'll check it out Jason and report what it's like...
Neil Lickfold06/06/2018 12:33:48
1025 forum posts
204 photos
Another issue is the radius of the tool is too large and requires too much tool pressure. So it flexes everything as it cuts, apart from the issue that the head/ column is not trammed to the run of the spindle. On some machines, it is not the column that needs correcting, but the work head may need shimming to get the run of the spindle true to the table. So if the head runs up and down the column, and the bottle square or you master square shows that it is within 0.02mm over 150mm or so than that is going to be OK. Then you know the error is in the assembly that is holding the spindle. It could be it needs a shim under the Pivot ring on the lower side. Looking at the numbers, it will most likely need a piece of 2 thou shim in this area for a start. It may need a 4 thou shim.
Neil L
Muzzer06/06/2018 13:21:50
2904 forum posts
448 photos
The general rule of thumb with adjustable radius flycutters is surely to set the diameter of sweep so that it only just exceeds the width of the work. The various reasons for minimising the sweep are expounded above. Looking at the pics, it is clear the tool radius is set way too big.
Sounds as if you got there in the end but I guess the missing part was the logic behind minimising the swing.
Murray
