Advice please
Tim Rowe | 21/05/2018 10:53:32 |
33 forum posts 4 photos | I am more a lurker on this forum but active on the sister model flying forum. The Proxxon PD 400 thread has been very interesting because I picked one up second-hand from Lancaster Model and Hobby World about two years ago with a job lot of associated tooling. It is noisy so I may have to look into that before I get stuck into any real project.
Neil Wyatt | 21/05/2018 11:22:12 |
![]() 19226 forum posts 749 photos 86 articles | I would not loctite the sleeve in place as you would then be relying on it to secure the prop and the forces are high and motor shafts are notoriously highly polished. A shock (like the prop hitting the ground when rotating) could break the bond without this being obvious. A snug split sleeve is better as then the full force of the collet will be transferred to the motor shaft. Neil |
Robert Butler | 21/05/2018 11:32:08 |
511 forum posts 6 photos | If the sleeve is secured to the shaft with adhesive it may also prevent a change of bearings. Robert Butler
not done it yet | 21/05/2018 13:04:00 |
7517 forum posts 20 photos | 3mm to 5mm shaft connectors for RC applications are available on epay. Not good enough? Other changes are available. You might need to buy one which is smaller and bore it out? Edited By not done it yet on 21/05/2018 13:06:08 |
JasonB | 21/05/2018 13:13:06 |
![]() 25215 forum posts 3105 photos 1 articles | If you can make a sleeve you should be able to make a new tapered collect with a 3.0mm bore which would be a lot better than having two parts |
Tim Rowe | 21/05/2018 14:31:57 |
33 forum posts 4 photos | Thank you everyone for the quick and useful comments.
Grizzly bear | 21/05/2018 17:36:56 |
337 forum posts 8 photos | Hi Tim, You could do four slits, with your trusty hacksaw. Regards, bear..
Tim Rowe | 21/05/2018 18:28:17 |
33 forum posts 4 photos | Hi Bear
Neil Wyatt | 21/05/2018 18:50:26 |
![]() 19226 forum posts 749 photos 86 articles | Or use a cut-off wheel in a toolpost-mounted dremel/rotary tool. Neil |
Ian S C | 22/05/2018 11:36:43 |
![]() 7468 forum posts 230 photos | A Junior hacksaw will give a nice narrow slit. Ian S C |
Russell Eberhardt | 22/05/2018 15:57:43 |
![]() 2785 forum posts 87 photos | Posted by Ian S C on 22/05/2018 11:36:43:
A Junior hacksaw will give a nice narrow slit. A piercing saw will give you even narrower slot. Blades are available down to 0.33 mm but you will need a steady hand! Russell |
Tim Rowe | 23/05/2018 15:24:54 |
33 forum posts 4 photos | Very helpful everyone but for the moment I have pushed the problem into the long grass. |
