what is this tool for?
Tractor man07/04/2018 10:09:41
426 forum posts
img_1550.jpgimg_1549.jpgHi gents,
not got a bald clue as to the identity of this tool.
It is well made but has no markings at all, its not an accurate measuring tool but I did wonder if it was for setting something up.
the long end unscrews to open the centre slot which is sprung. it operates a bit like a tap wrench but its clearly not of that family.
Tractor man09/04/2018 10:35:27
426 forum posts
Wow over 300 views and not an opinion ventured. Must be a record.
I'm still in the dark as to it's possible use but I'm sure it will become clear.
SillyOldDuffer09/04/2018 11:04:54
10668 forum posts
2415 photos
You may have found the Holy Grail - a tool that no-one can identify!
Does the short end swivel at right angles to the long handle? It looks as if bits of the handle unscrew possibly so it can be used in a confined space. An adjuster of some kind? Could it be for adjusting the tension of wires used to brace wood frame aircraft? Or forming piano wire?
Baffled.
Martin King 209/04/2018 11:15:20
1129 forum posts
Well! Its certainly got me stumped! No idea at all.
martin
Gordon W09/04/2018 11:37:14
2011 forum posts
No idea at all. It does look as if something is missing- the "radius" on the two jaws looks to made to fit to something ?
TomK09/04/2018 11:49:49
83 forum posts
23 photos
The shape of the jaw looks like it could hold a woodruff key.
Fowlers Fury09/04/2018 11:54:19
446 forum posts
88 photos
Cropping a couple of the pics followed by a "reverse image search" on Google gives no clue either !
Martin Kyte09/04/2018 11:58:18
3445 forum posts
62 photos
Where did it come from and was it amongst other stuff. If so what.
regards Martin
roy entwistle09/04/2018 13:56:14
1716 forum posts
The upper tool in the photos, I think, is a measuring stick. Although it's got the proper numbers along the bottom
Roy face 1
Speedy Builder509/04/2018 15:35:37
2878 forum posts
248 photos
What is the "bruising" between the two knurled sections on the LH handle. With a Swiss file, test how hard the centre 'link' is.
Speedy Builder509/04/2018 15:53:50
2878 forum posts
248 photos
This doesn't help, but would give us a whole load more to think about.
Martin Cargill09/04/2018 16:03:18
203 forum posts
A bore gauge? Are the knurled bits removable in stages? do you measure between the two points?
John Penfold09/04/2018 17:41:05
33 forum posts
5 photos
A pensioner’s tool to use on a burglar?
paul rayner09/04/2018 20:34:25
187 forum posts
46 photos
Posted by John Penfold on 09/04/2018 17:41:05:
not sharp or long enough mate
Tractor man10/04/2018 07:07:11
426 forum posts
I can think of many a better implement to deal with that scumbag! Have you seen the shrine to him? Disgusting!
Still clueless on the tool so I will post more images and do some research.
David Colwill10/04/2018 08:36:40
782 forum posts
40 photos
It's an epilator for engineers.
Just hand it to a group of them and watch as they tear their hair out trying to figure out what it is. smile p
Edited By David Colwill on 10/04/2018 08:37:33
pgk pgk10/04/2018 09:52:12
2661 forum posts
294 photos
Put a replacable hooked blade in the centre and attach to the rim of an industral sized baked bean can and oscillate..
TomK10/04/2018 15:15:15
83 forum posts
23 photos
I think you have bits missing which would solve the mystery as to what this tool is. I think its a bore gauge. This link may help
Tom
Georgineer10/04/2018 15:15:58
652 forum posts
33 photos
It's a grostling iron.
George
Brian H10/04/2018 15:37:55
2312 forum posts
112 photos
Posted by TomK on 10/04/2018 15:15:15:
Tom
What a shame the label is damaged.
Maybe we could contact the people who've bid on it. Maybe someone knows what they've bid on.
Edited By BDH on 10/04/2018 15:41:39
