Here is a list of all the postings John Penfold has made in our forums. Click on a thread name to jump to the thread.
Thread: Unimat 3 motor diode |
25/02/2022 15:27:05 |
The side view. J |
25/02/2022 15:25:28 |
Here are the pictures - rather big I think. J |
23/02/2022 18:19:05 |
Hi Gary From R/S Components - KEMET PZB300 Paper Capacitor, 275V ac, ±20%, 100nF, Through Hole It is a little too big to fit inside the motor so I added extra lengths of wire to take outside the motor cover. I will try to add a picture of what I have done. The motor is running fine and back on the lathe. J
Thread: Metal Cleaning Using Vinegar? |
30/01/2022 06:16:07 |
Golly mate, we go to the supermarket here. |
31/12/2021 17:23:08 |
Thanks for the prompt response. Having read the supporting technical sheets, I have found a capacitor. Super, thanks for that. I had to strip apart the motor to get to the capacitor and found a rough bearing. So I will change the bearings as well. I rather dread putting it back together as small hands and some craftiness required to get the wires in the proper places. I will try putting it back together to confirm the capacitor failed. J |
31/12/2021 14:59:29 |
Old subject, but my little SL Unimat has, after all these years, stopped. The issue is that the 1A plug fuse is blowing. I have tested the safety capacitor resistance and that is nil between terminals. Reading the messages about, the SillyOldDuffer thought that a replacement can still be found! I am sitting here in front of this PC for some time and cannot find a 3 wire “safety capacitor” or “suppressor” in F-arnells or “RS” or all the other b/s on Google. I am looking for an axial capacitor rated as 0.01uF 2x 2500pF - I cannot read the makers’ name as that is not legible. Some help needed please. J
Thread: DRO Question |
28/05/2021 18:28:47 |
Hi Peter, I use pad and pencil with my calculator so I can always refer to it. Never used the fancy functions on the DRO system. |
Thread: Hello everyone; Engineering equipment for sale |
30/03/2021 15:35:58 |
Hi Jonathan, welcome. |
Thread: Looking to pay for someone to finish an engine |
24/02/2021 18:05:22 |
Hi Simon Did you get the help you were looking for? |
Thread: A finished project - at last! |
05/01/2021 04:49:19 |
A good feeling then. Nice |
Thread: Warco WM 250 problem? |
15/11/2019 11:49:42 |
The cabinets and drip tray are fairly flimsy. I put a thick piece of plyboard inside the top of the cabinets and bolted through. That has solved the floppiness. I also had to add a piece of rubber (I used some inner tube) to seal off the bolt holes in the drip tray. Warco do not supply any seals saying that this was user solvable(?). I haven't bolted the lathe down as my floor wasn't level. I used the bolt holes to level the lathe. John |
Thread: Painting! There one day, gone the next! |
09/11/2019 07:43:27 |
Oh dear, lots more practice - or use a brush
J |
Thread: ww2 jeeps |
23/10/2019 08:30:21 |
Hi Jerry Some way to go then ;~}
J |
Thread: Steam fittings |
13/02/2019 10:27:10 |
Hi Peter I recently bought a 1/4 x 40 syphon and banjo fitting for a steam pressure gauge - If it works have a look here on page 38 of 60. https://www.pollymodelengineering.co.uk/sections/bruce-engineering/docs/Catalogue-Jan-2019-1.pdf J |
Thread: Completed Twin Inline IC Engine |
02/01/2019 08:07:50 |
Fab. John |
Thread: Electrolux vacuum - Need to make a missing wheel |
05/11/2018 17:24:44 |
I bet you didn't ask the indoor manager if she wanted it fixed. Most likely would have asked for a more efficient, more powerful, lighter and cordless. I'm sure that Mr Grumpy bragging about his repair got a lot of muttering John |
Thread: I finished a project! |
07/09/2018 22:16:07 |
I am sure that felt good. Well done. J |
Thread: Mystery lathe on eBay |
04/09/2018 20:29:00 |
Good one ☝️ John |
Thread: Really hope this finds a home.... |
03/07/2018 15:05:18 |
Looks a bit time expired to me. J |
Thread: LBSC "Dot" |
02/05/2018 07:31:09 |
