Peter Fishwick 2 | 19/03/2018 12:06:52 |
1 forum posts | I'm looking for a small ball joint that I can attach to a flat fixed surface, with the rod attached to the ball so that the rod can move in all directions. The end result is the sort of thing you would have with the aerial of a old style transistor radio. I can find ball joints for attaching to the end of rods to act as linkages, but none which can be attached to a flat surface. Any suggestions? |
vintagengineer | 19/03/2018 12:55:52 |
![]() 469 forum posts 6 photos | |
not done it yet | 19/03/2018 15:01:20 |
7517 forum posts 20 photos | Camera? Dash cam? Sat nav? All, or most, use ball joints.
jimmy b | 19/03/2018 15:08:30 |
![]() 857 forum posts 45 photos | Is this the sort of thing you are thinking of?
Jim |
Mick B1 | 19/03/2018 15:46:15 |
2444 forum posts 139 photos | Posted by jimmy b on 19/03/2018 15:08:30:
Jim Thank you for that link. I'd wondered what'd happened to Woodside since the '80s when I last used 'em! :D |
Robert Dodds | 19/03/2018 18:56:52 |
324 forum posts 63 photos | Peter, Have a look at this Amazon product with a swivel ball joint. It may be the wrong scale for your application but the principle of a slot down the side of the ball cup to allow the "vice" (or your rod) to lean over should give you the flexibility you seek. 40231901 Aluminum Small Mini Table Clamp Hobby Jewlery Work Swivel 360 ViceI got one out of Aldi some time back and it's useful. Bob D
SteveW | 19/03/2018 19:01:58 |
![]() 140 forum posts 11 photos | May be worth looking into the model boat world. Many varieties for a limited angular displacement. Some very simple. |
Perko7 | 20/03/2018 10:47:28 |
452 forum posts 35 photos | Some camera tripods, the collapsible/compact ones, have a ball joint for the camera mounting plate. Also some go-pro and dashcam mounts. |
