Flat spring stainless steel ?
Searching for a supplier
Tim Stevens07/02/2018 13:37:36
1779 forum posts
I need a small amount of flat hard-rolled stainless to make a few spiral springs. Just like clock springs but not so many turns. Any ideas of a supplier, please?
I suppose I could roll some strip to harden it, but no-one handy has a set of capable rolls ...
Cheers, Tim
roy entwistle07/02/2018 14:04:18
1716 forum posts
What about sizes ? Piece of string comes to mind face 1
Roy
Tim Stevens07/02/2018 14:52:56
1779 forum posts
About the size of an alarm clock spring - say 4mm to 5mm wide, and 0.3mm to 0.4mm thick? And in pieces no shorter than about 150mm. Roughly.
Cheers, Tim
Brian H07/02/2018 15:06:03
2312 forum posts
112 photos
I've previously used a supplier of spring material to companies making false limbs. This was in Sheffield but they went out of business some years ago but there must be other suppliers.
Richard Marks07/02/2018 15:08:39
218 forum posts
8 photos
An old clock spring or the retractor spring from an old tape measure.
Neil Wyatt07/02/2018 15:34:12
19226 forum posts
749 photos
86 articles
Spring steel strapping? The problem is it's about 12.7mm wide, but it may be possible to cut it with a bench shear.
I could pop some in an envelope.
Speedy Builder507/02/2018 15:46:38
2878 forum posts
248 photos
How about "Tensator springs" for use in wet environments. - Do you have any friends that work for a food factory ?
BobH
Edited By Speedy Builder5 on 07/02/2018 15:47:24
Neil Wyatt07/02/2018 16:17:38
19226 forum posts
749 photos
86 articles
Ah. Missed the 'stainless'.
Ian P07/02/2018 17:06:14
2747 forum posts
123 photos
I have a supply of the SS flat rolled spring wire but its twice the width and thickness you say you need.
Its 2.5mm x 0.7mm round edged wire (as used in some windscreen wiper blades), if its of any use I could post some.
Ian P
Tim Stevens07/02/2018 17:07:13
1779 forum posts
Neil the Ed says - Missed the 'stainless'.
Indeed, and you are not alone. If I could find a stainless clock sprint, or stainless strapping, I would not need to ask here. Or even the spring out of a seat belt, but they all rust.
Cheers, Tim
Tim Stevens07/02/2018 17:27:59
1779 forum posts
Hello Ian P - this sounds like a possible answer. I will send you a Personal Message with details, and let's see how we get on.
A bit thicker and a bit narrower than my original guess, but certainly helpful.
Cheers, Tim
Richard S207/02/2018 17:34:01
237 forum posts
135 photos
If you have to go to a commercial supplier, then you could try these people for a small quantity. Look's like they may have what you need - Steelstrip
JohnF07/02/2018 17:40:06
1243 forum posts
202 photos
Tim, have look at this link it suggests that seat belt springs are made of stainless ?? **LINK**
A search around Redditch area may be good its the heart of spring and needle making -- or was !
Cheers John
Nathan Sharpe07/02/2018 18:40:07
175 forum posts
Tim, I'm not sure about their available sizes but we used to use " Bandit" ss strapping on commercial pump hoses. as far as I know they are still in business. Nathan.
Nathan Sharpe07/02/2018 18:44:57
175 forum posts
Tim, it's available from " Thorne and Derrick " in the uk. Sizes look useful ! Nathan.
Tim Stevens09/02/2018 17:15:05
1779 forum posts
Thanks to Ian P I now have enough stainless spring strip to keep me busy for hours. I now need to work out how best to wind a (shorter than usual) clock spring, so it works out neat and not wobbly.
Thanks to you all for comments and links - all helpful.
Tim
John Baron09/02/2018 17:50:50
520 forum posts
194 photos
Hi Tim,
Grab an old window screen wiper from a car. The metal backing strip is stainless and is quite hard. I've used them to make replacement return springs for door handles. Works a treat yes
