Andy Sproule | 05/02/2018 19:53:28 |
122 forum posts 35 photos |
Oldiron | 05/02/2018 20:04:48 |
1193 forum posts 59 photos | Hi Try this link.:- **LINK** regards |
Andy Sproule | 05/02/2018 20:11:30 |
122 forum posts 35 photos | Thanks for quick reply.My model isn't there. |
John Hinkley | 05/02/2018 20:20:43 |
![]() 1545 forum posts 484 photos | They look very much like these: I'd have said the AD.. suffix was a clue. Available in two sizes from JB - you'll have to get the tape measure out. John |
Andy Sproule | 06/02/2018 14:25:08 |
122 forum posts 35 photos | Rang cutwell they said only Iscar inserts fit.Are there any other companies I should try? |
Muzzer | 06/02/2018 15:32:04 |
![]() 2904 forum posts 448 photos | It looks old and obsolete so you would probably spend more on inserts than it's worth. The most popular modern cutters use inserts like the AP** style and you can get them from many outlets. Search for something like "BAP300R 50-22-4" which would be a 50mm diameter cutter with 22mm arbor hole and 4 inserts AP**1135 or the "BAP400R etc" which take the larger AP**1604 inserts. I believe these are based on a Mitsubishi design but I may be wrong. For steels you might go for coated APKT style and for loominum you might want uncoated APGT. You can get these on ebay, Aliexpress and other places closer to home such as APT Tools, who stock these and other modern types. Murray Edited By Muzzer on 06/02/2018 15:32:48 |
KWIL | 06/02/2018 15:44:33 |
3681 forum posts 70 photos | Looks like an early Iscar Helimill. Not in my catalogue and inserts listed all have chip breaker rather than flat faced inserts as on you example.What are the dimensions of the inserts as fitted? Edited By KWIL on 06/02/2018 15:45:14 |
Oldiron | 06/02/2018 17:49:31 |
1193 forum posts 59 photos | Andy Sproule, Thanks for quick reply.My model isn't there.
Hi Andy. I think you will find that your facemill takes the same tips as in the link I gave you. If you post the dimensions I may have something suitable you could try. (no promises tho ) regards |
Muzzer | 06/02/2018 18:29:40 |
![]() 2904 forum posts 448 photos | No, Oldiron, the inserts you linked to are modern, positive rake things which are much more advanced than the flat faced, zero rake inserts in the photos. They will generate lower cutting forces and produce a better finish under most conditions. Whether or not they fit is unclear but it seems unlikely. Unless you are nostalgic about old, inefficient tools, you'd be better putting that tool on the mantle piece - or possibly filing it. Murray |
JasonB | 06/02/2018 18:43:57 |
![]() 25215 forum posts 3105 photos 1 articles | These look more like whats in the holder. Why not contact Iscar and see if they can tell you the old number and then have a google to see if any crop up but as Murray says you can get a 50mm head, arbor and box of inserts for less than what a couple of iscar inserts will set you back. Edited By JasonB on 06/02/2018 18:44:32 |
norman royds 2 | 06/02/2018 19:29:47 |
48 forum posts | I Andy i just been looking through all the business card and found jb cutting tools.com email jenny@JBCuttingtools .com I hope this help you every time I wanted tip i been lucky I think she does most shows I hope you are lucky regards norm |
richardandtracy | 06/02/2018 21:28:00 |
![]() 943 forum posts 10 photos | I suspect you'll be really surprised at the price of the type of cutter Muzzer is suggesting. I am likely to order a BAP300R 50 22 with MT3 mandrel and 10 inserts, I don't expect to have to pay more than £28 inc postage from China. It makes looking for replacement, poor shape, inserts for my Warco face mill seem utterly pointless. Replacement inserts can be as low as £6.50 for 10. And, no, they are not a pile of horse manure - who do you think makes 90% of inserts worldwide? Same people as makes the iPhone, the Chinese. Regards Richard.
Chris Gunn | 07/02/2018 14:22:04 |
459 forum posts 28 photos | Andy, I used to buy my Iscar inserts from Cromwell tools, there may be a branch close to you who can help. Chris Gunn |
richardandtracy | 07/02/2018 15:20:22 |
![]() 943 forum posts 10 photos | Posted by richardandtracy on 06/02/2018 21:28:00:
... I am likely to order a BAP400R 50 22 with MT3 mandrel and 10 inserts,...
Have just ordered... Cost £28.82p, the exchange rate is fractionally worse today than yesterday. As a comparator pricewise, the face mill it'll replace is currently sold by Clarke (Part No. 7610322) and costs from £54. Regards, Richard.
Andy Sproule | 07/02/2018 17:15:27 |
122 forum posts 35 photos | Thanks again for all help. I will buy one of the cheap ones that Muzzer recommended? |
Jon | 08/02/2018 19:59:23 |
1001 forum posts 49 photos | 2 min check found plenty that will fit, last hell of a lot longer and far better than any cheap chinese tool not mentioning the inserts. Dont under estimate a quality tool usually in a different league to various links and names above, been there done it false economy wasting that £28. https://www.ebay.co.uk/itm/Ceratizit-ADKT-1505PDSR-29-CTP1235-tips-inserts-cutting-3-33-Each-VAT/253193746523?hash=item3af385f85b:g:4DMAAOSwj9dZ1z1~ Tips look wrong in that Iscar by fit still a quality tool and will take modern stuff. Its just the angle in this case, size, thickness and hole size. |
Andy Sproule | 12/02/2018 18:29:37 |
122 forum posts 35 photos | Jon just seeing this reply now how can I be sure these ones will fit? |
