Member postings for Andy Sproule
Here is a list of all the postings Andy Sproule has made in our forums. Click on a thread name to jump to the thread.
Thread: Fly reel repair
29/06/2022 19:16:23
Hi I know there are a few on here who work at old fly reels and was wondering if it would be possible to get in contact.What I’m going to do is replace the agate on a Hardy perfect.
Thread: Inverted parting tool
28/02/2021 20:40:06
Thanks for all the replies tried to drill the underside of the tool holder drills including cobalt hardly marked it.
26/02/2021 18:43:44
Hi,I have a boxford 280 lathe with a Bison dickson type toolpost.I was going to try parting off with the blade upsidedown and the chuck running clockwise but the holders can't be risen to centre height any ideas how this could be done?download.jpg
Thread: Collet chuck
17/12/2020 19:36:40
Hi folks thank you for replies.I should have said it was er32 and the od was 100mm.
Edited By Andy Sproule on 17/12/2020 19:41:27
13/12/2020 17:01:40
Hi has anyone bought one of these and could tell this diameter marked on pic.Tried seller but no luck.
Edited By JasonB on 13/12/2020 17:20:15
Thread: Mounting a collet chuck.
25/09/2020 19:43:29
Thank you for all replies a great help.
24/09/2020 14:18:48
s-l1600.jpgwhatsapp image 2020-09-24 at 14.07.33.jpegHi,I have a spare D1-3 back plate which fits my boxford I want to mount an er32 collet chuck to it could anyone advise the best method.One of the pics is the er32 chuck which I've been looking at but haven't bought yet.whatsapp image 2020-09-24 at 14.07.18.jpeg
Thread: Welder buy
04/09/2020 09:57:05
Thanks for all the replies plenty of food for thought.So if I plump for mig only for now what machine do you recommend Clarke 135te turbo seems to be very popular.
03/09/2020 13:14:30
Hi,I'm thinking of buying a mig welder I can stick weld and have done a little tig.I have never done mig but it looks fairly straight forward.I have a large full bottle of argon and the hoses and so on to do tig.I have seen on the auction site that you can get a welder that does both mig and tig has anyone go one of these and are they any good,if not which mig would you recomment for infrequent hobby use?
Thread: Rotary phase converter
27/08/2020 19:13:30
mains
27/08/2020 19:12:47
Yes theSeimec is run by the inverter.No pilot motor.Which control gear?Everything on lathe,mill and bandsaw work just like if they plugged into mails three phase.
27/08/2020 14:34:10
Emgee all I do is flick the switch on the mill or bandsaw and it changes speed.
26/08/2020 20:05:19
Hi guys .w ell that generated a bit of discussion.I'm only a hobbist and built the rotary inverter myself.I run a bandsaw and a mill with two speed motors with the inverter.I was told at the time that a VFD would have problems running and two speed motor and would be expensive to buy.
25/08/2020 17:26:34
Thanks for all the replies I will get a power meter as well.So I hooked up a clamp on ammeter the inverter while idling is drawing 2.6 amps.When I turn the lathe on it draws 5.6amps and when I do a heavy cut its 6.4 amps
25/08/2020 16:29:03
Hi,I have a rotary phase converter with a three horse motor which I use to run a boxford 280 lathe which has a two horse motor can anyone tell me even roughly how much this set up costs to run?
Thread: Boxford 280
25/08/2020 09:53:05
Thanks for that Tim.
24/08/2020 15:41:45
Thanks for reply I have always stopped the machine but seen this guy doing it with the machine running and wondered what you guys thought?
23/08/2020 20:33:15
Hi.on a boxford 280 at the headstock the direction lever for the lead screw and the speed levers for the lead screw does the machine have to be turned off to change them?The powerfeed leavers on the apron does the motor have to be turned off to change them?
Thread: Starret 18c centre punch
13/02/2020 09:59:28
Will check that out thank you.
11/02/2020 19:14:22
Has anyone taken one of these apart unscrewed the top end took out spring but plunger wont come out though it slides up and down.
