David Canham | 31/01/2018 21:13:43 |
![]() 50 forum posts 15 photos | Hi People, I have been reading up on boiler making and testing and something crossed my mind about the boiler water gauge. Am I right to assume that the full boiler pressure will at times be applied to the little glass tube. Can they really take up to 100 psi? David. |
FMES | 31/01/2018 21:18:15 |
608 forum posts 2 photos | Certainly, and a lot more. Its a special Borosilicate glass which is incrdibly strong, although having broke one once when I was steaming up (acciently smacked it with the shovel) it is a good idea to fit a guard around it. Regards Lofty |
David Canham | 31/01/2018 21:23:06 |
![]() 50 forum posts 15 photos | Thanks for that Lofty. David. |
Jeff Dayman | 31/01/2018 21:27:29 |
2356 forum posts 47 photos | Full boiler pressure is applied to the glass tube. Thick walled glass as intended for gauge glass use, from a model engineering or industrial supplier, will take the pressure. I like the stuff with the blue stripe, it helps to see the level. Never had one burst on its' own. It's also important to have the glass touching only the rubber seals, and not have the metal gland nuts or fittings contacting the glass applying stress to it at a small area. Best to follow a proven design for your gauge glass and fittings arrangement, preferably with shutoff valves above and below the glass, and a blowdown valve for the glass, with a drain below the cab. Cheap glass tube trinkets from the dollar store or ex neon sign glass tube or any other glass tube not specifically rated for gauge glass use likely will not take the pressure. As usual, I expect 15 people on the forum will disagree. The above is just my $0.02 worth based on my own experience. |
Hopper | 01/02/2018 04:32:47 |
![]() 7881 forum posts 397 photos | Posted by Jeff Dayman on 31/01/2018 21:27:29:...
...As usual, I expect 15 people on the forum will disagree. No, I don't think they will. |
FMES | 01/02/2018 06:15:09 |
608 forum posts 2 photos | Posted by Jeff Dayman on 31/01/2018 21:27:29:
Excellent point Jeff, its also worth noting that the gauge glass nuts are only tightened finger tight. Regards Lofty |
Clive India | 01/02/2018 09:08:52 |
![]() 277 forum posts | It does raise a point - the irony that we go through all the rigorous actions of boiler design and testing and then stick on a vulnerable glass tube with iffy seals on it. There's probably no other way though? |
Clive Brown 1 | 01/02/2018 10:39:17 |
1050 forum posts 56 photos | In the past, I've bought gauge glass with a blue line embedded in it, Schellbach I think Reeves listed it IIRC. However, I found that it wasn't truly round, at least the pieces that I received, which made sealing difficult. I found that the plain borosilicate tube was better in this respect. Some folk also reckon that lined tube is also more easily broken. Just looked, Reeves don't seem to list the lined tube any more, just the plain. Edited By Clive Brown 1 on 01/02/2018 10:42:28 |
FMES | 01/02/2018 14:26:44 |
608 forum posts 2 photos | Posted by Clive India on 01/02/2018 09:08:52:
It does raise a point - the irony that we go through all the rigorous actions of boiler design and testing and then stick on a vulnerable glass tube with iffy seals on it. There's probably no other way though? Could go back to ye olde method of 'try cocks'
Neil Wyatt | 01/02/2018 17:26:50 |
![]() 19226 forum posts 749 photos 86 articles | I looked up some numbers Ordinary glass has a tensile strength of about 30-40 MPa, but toughened glass is more like 200Mpa
Annealed copper has a tensile strength of about 200 MPa but a yield stress of only about 70 MPa. So you could argue a toughened glass tube is stronger than the boiler shell... but obviously a bit more fragile! Neil |
David Canham | 01/02/2018 18:54:32 |
![]() 50 forum posts 15 photos | Great stuff chaps, thank you. Just a little side question, I have never driven a 5" loco, or any model come to that so how easy is it to see the water level in the gauge glasses. David.
fizzy | 01/02/2018 19:23:25 |
![]() 1860 forum posts 121 photos | It all depends on the gauge location/aspect, loco, track and experience, but all said I have never had any problems. There are usually a lot of things to think about and do 'on the hoof' but you will soon get the hang of things. Probably! |
julian atkins | 01/02/2018 21:02:38 |
![]() 1285 forum posts 353 photos | Hi David, Not sure why you raised this issue. If properly made and fitted, a miniature water gauge is as easy to read as in fullsize. I have never used a commercial fitting, making all of mine. In 35 years I have never had a gauge glass break, and on the 4 yearly boiler hydraulic test they withstand a pressure of 1.5 x working pressure. I have followed a series of articles for many of mine from EIM many years ago. Some miniature locos give a poor reading in the glass because of restricted water legs in the backhead and protrusion of the lower bushes and water gauge fitting. There is much turbulance of the water and foaming in this area of the boiler. Reading the gauge itself is simplified by sticking a bit of white card behind with diagonal parallel lines written upon it in black ball point. A gauge glass against a black painted backhead is not easy to read. I have never used schellbach glass (though I have a stock of it) because it is more brittle. Discard any ordinary gauge glass that shows greenish ends. Cheers, Julian Edited By julian atkins on 01/02/2018 21:04:05 |
DMB | 01/02/2018 21:41:20 |
1585 forum posts 1 photos | Hi Julian, You say discard ordinary gauge glass with greenish ends. May I ask why and what does the greenish colour indicate? John |
julian atkins | 01/02/2018 22:44:04 |
![]() 1285 forum posts 353 photos | Hi John, It was told to me by Don Young after his Eastleigh apprentice days, and also related in his writings. Try greenish ended water gauge glass if you dare! I haven't tested it myself, as I have a large tin of gauge glass of various sizes, and I am quite happy with non- greenish glass ends that have never caused a problem! Cheers, Julian |
julian atkins | 01/02/2018 22:47:36 |
![]() 1285 forum posts 353 photos | I don't actually agree with Jeff re separate shut off cocks top and bottom of the gauge as in 3.5"g and 5"g these restrict the passageways, and in any event I have never found them necessary. Cheers, Julian (first of Jeff's 1 in 15) |
Martin Johnson 1 | 02/02/2018 08:41:55 |
320 forum posts 1 photos | If you are working in larger scales with a 3 cock gauge glass set, I was taught to do the hydraulic test with the glass isolated and the glass drain cock open so it cannot be pressurised. Obviously not an option with only drain cock. I have 2 full size glasses break in service, one when I was in the cab. Not much fun, fumbling around to find the isolating cocks in a cloud of steam. At the time we couldn't get (afford) the proper glass seals so were "improvising" - hence the breakages. Martin |
Clive India | 02/02/2018 08:46:59 |
![]() 277 forum posts | Posted by julian atkins on 01/02/2018 22:47:36:
I don't actually agree with Jeff re separate shut off cocks top and bottom of the gauge as in 3.5"g and 5"g these restrict the passageways, and in any event I have never found them necessary. Cheers, Julian (first of Jeff's 1 in 15) Agree, and there is another reason.... Good maintenance in this area pays off - I change the glass and seals each season - actually over the top but i feel better. |
ChrisH | 02/02/2018 09:55:39 |
1023 forum posts 30 photos | I agree Julian has a good point re fitting of shut-off cocks to model steam boilers, as they are seldom in steam for long periods and size and space can be a restriction in model use and glass failure is unlikely to result in a major drama. The fitting of shut-off cocks comes from full size boiler use of course. It allows the passage ways through to the boiler to be rodded through even with the boiler in use should their ways between boiler and gauge become blocked in use while the boiler remains in steam, with the help of a blanking plug opposite and in-line with the shut-off cock fitted to the gauge of course, and allows for the renewal of the gauge glass to be renewed also while the boiler remains in steam too, both important considerations where boilers remain in steam for considerabl periods at a time like on ships. Chris |
SillyOldDuffer | 02/02/2018 11:00:21 |
10668 forum posts 2415 photos | Posted by julian atkins on 01/02/2018 22:44:04:
Hi John, It was told to me by Don Young after his Eastleigh apprentice days, and also related in his writings. Try greenish ended water gauge glass if you dare! I haven't tested it myself, as I have a large tin of gauge glass of various sizes, and I am quite happy with non- greenish glass ends that have never caused a problem! Cheers, Julian Dimly remembered from School Chemistry, I believe a greenish tint at the ends is a strong hint that a tube is made of soda glass. This is the stuff that melts in a bunsen flame. It's inexpensive, easily worked, and very handy for making simple glassware in a lab. Whilst brittle, it withstands high pressures provided they are applied slowly. It expands and contracts more than other glasses when heated. Not ideal in a locomotive sight gauge, where the temperature goes up and down and a tap might shatter the glass. Although soda glass tubing could used at a pinch there are better alternatives. Dave |
