Jens Eirik Skogstad | 19/01/2018 10:14:48 |
![]() 400 forum posts 22 photos | Hi folks, i has got the G. Boley watchmaker lathe yesterday. The lathe is without electric motor. Which revolution range from low rpm to max rpm is prefered for this lathe? Is sewingmachine motor usable? Edited By Jens Eirik Skogstad on 19/01/2018 10:15:11 |
Jens Eirik Skogstad | 19/01/2018 10:17:34 |
![]() 400 forum posts 22 photos | Ps, Bolette is not my fault due i am using smartphone.. |
David Standing 1 | 19/01/2018 10:33:22 |
1297 forum posts 50 photos | Posted by Jens Eirik Skogstad on 19/01/2018 10:17:34:
Well, it isn't that smart, it can't spell |
Oldiron | 19/01/2018 10:33:32 |
1193 forum posts 59 photos | Hi, Many people seem to use that kind of motor on these small lathes. As long as a motor is in the correct HP and speed range it should be OK. Sorry I have no personal experience with them so cannot give a definitive answer. May be a Moderator can alter the title to the correct spelling for you. regards |
Wout Moerman | 19/01/2018 12:04:52 |
57 forum posts 2 photos | I believe the plain bearings of watchmakers lathes can be used up to 4000 RPM if lubricated correctly. Using this figure you might work out what motor and pulley combination would be suitable.
Jens Eirik Skogstad | 19/01/2018 12:24:11 |
![]() 400 forum posts 22 photos | And i forgotten to ask which oil is recommended for this lathe? I can't see there is hole for lubricate the bearings. |
Michael Gilligan | 19/01/2018 13:23:02 |
![]() 23121 forum posts 1360 photos | Posted by Jens Eirik Skogstad on 19/01/2018 12:24:11:
And i forgotten to ask which oil is recommended for this lathe? I can't see there is hole for lubricate the bearings. . Any light 'high speed spindle' oil should be fine ... Many watchmakers, I suspect, just use a drop of whatever happens to be on the bench. The bearings are typically double-cone [one steep taper, one shallow] each end, and 'glass-hard' steel. The running-clearances are very small, so the lubrication can probably be considered hydrostatic. MichaelG. |
Thor 🇳🇴 | 19/01/2018 13:47:58 |
![]() 1766 forum posts 46 photos | Hi Jens Erik, Congratulations with your "new" lathe. As Michael says for lubricating the spindle use a "high speed spindle oil" - ISO viscosity 22 (like Mobile Velocite No.10) or may be even thinner if you intend to run your lathe very fast (over 6000 rpm). Thor |
Jens Eirik Skogstad | 19/01/2018 16:18:47 |
![]() 400 forum posts 22 photos | 6000 rpm sounds insane. Only there is no heat in the bearings of high speeds and the workpiece is being thrown away somewhere I never find. I'll try to get a motor from sewing machine with a foot pedal to adjust the speed at which it works best on the right diameter depending on the material. When I look at various tools and accessories for the G. Boley Lathe, I think they are so small that I had to be able to use tweezers and microscopes. |
Thor 🇳🇴 | 19/01/2018 17:34:14 |
![]() 1766 forum posts 46 photos | Hi Jens Erik, Yes, 6000 RPM is very fast to me, but for a 1mm drill in brass you need a high speed. I guess one of these might be useful for small work, and yes I use tweezers now and then. Thor |
JohnF | 19/01/2018 18:24:33 |
![]() 1243 forum posts 202 photos | HI Jens & Thor, This link may be of interest regarding speed, one pertinent point is that the original watch & clock makers turns were powered by a bow thus speeds were quite slow. Somewhat contrary to "modern" thinking where speeds for the small diameters would have very high recommended/suggested/theoretical speeds. John. PS found another link on same site--may be worth a search on this site ?
Edited By JohnF on 19/01/2018 18:38:51 |
Michael Gilligan | 19/01/2018 18:55:55 |
![]() 23121 forum posts 1360 photos | Posted by JohnF on 19/01/2018 18:24:33:
... one pertinent point is that the original watch & clock makers turns were powered by a bow thus speeds were quite slow. Somewhat contrary to "modern" thinking where speeds for the small diameters would have very high recommended/suggested/theoretical speeds. John. . Agreed, John !! I was intending to post a similar comment, but got distracted by the joys of submitting my tax return.
Bazyle | 19/01/2018 19:03:28 |
![]() 6956 forum posts 229 photos | Don't over think it. Just get a standard cheep sewing machine motor which will have a foot switch speed control off ebay. It you find you need more power later you can upgrade but as it sounds like you are not in the middle of building a watch already you will have a bit of learning at slower speeds anyway.
Jens Eirik Skogstad | 19/01/2018 19:57:16 |
![]() 400 forum posts 22 photos | Thor, i has microscope for industrial use Lathe powered by bow.. thinking about the watchmaker Peter Henlein (1485-1542) created the first portable watch, all parts was made of iron. Really hard life to be watchmaker without electrical equipments. Then it's said the japanese watchmaker created the lantern clock with saw and file only. Edited By Jens Eirik Skogstad on 19/01/2018 20:00:14 |
Meunier | 19/01/2018 20:34:47 |
448 forum posts 8 photos | Was familiar with monocular and binocular but when I followed Thor's link was surprised to see trinocular microscopes. Any concerns about the strange physiognomy of some microscope users were allayed when Google informed me that the third 'ocular' was for camera usage. |
Jens Eirik Skogstad | 19/01/2018 21:00:11 |
![]() 400 forum posts 22 photos | Posted by Thor on 19/01/2018 17:34:14:
Hi Jens Erik, Yes, 6000 RPM is very fast to me, but for a 1mm drill in brass you need a high speed. Thor 6000 rpm is not strictly necessary to drill into brass with 1 mm drill. A long time since when i was young, when i had the Sabb 5-9 semidiesel engine. I created the new nozzle for injector, the old nozzle was made of brass and the hole was enlarged by abration. I used 0,3 mm drill at 4000 rpm when i drilled into the new nozzle at Emco Unimat 3. |
Thor 🇳🇴 | 20/01/2018 05:04:31 |
![]() 1766 forum posts 46 photos | Yes Jens Erik, you can drill brass at much lower speeds, just takes a bit more time. John's "powered by a bow" seems more like the speeds I tend to use, my milling machine won't go faster than 2500 rpm and that speed works for small drills. Thor |
Speedy Builder5 | 20/01/2018 06:20:29 |
2878 forum posts 248 photos | I started off with a sewing m/c motor but found it didn't have sufficient power. Speed was not a problem though. I eventually found a 1/10 Hp motor which drives my watch maker's lathe fine. Also my motor can be reversed which I also find of benefit. |
Jens Eirik Skogstad | 20/01/2018 06:55:11 |
![]() 400 forum posts 22 photos | Posted by Speedy Builder5 on 20/01/2018 06:20:29:
I started off with a sewing m/c motor but found it didn't have sufficient power. Speed was not a problem though. I eventually found a 1/10 Hp motor which drives my watch maker's lathe fine. Also my motor can be reversed which I also find of benefit. 1/10 hp,..it will say 75 watt motor? |
Roger Hart | 21/01/2018 12:15:17 |
157 forum posts 31 photos | I use a 6mm lathe so a bit smaller. I found sewing machine motors have an annoying high pitch whine, so I use a small (1/20th HP) induction motor about 1500rpm. This has a 2 step pulley - about 75mm dia and 30mm dia. Add a bit of cotton string and the 3 pulley settings on the lathe and I find that works well without that awful noise. Motor sits on a heavy baseboard and lathe has a heavy iron base, so it is easy to adjust the maximum torque by pulling or pushing on the base. The same arrangement using a length of cotton and a clamp-on pulley works for my home-brew turns. |
