Can I machine Silver Steel OK with HSS End Mills?
Men Ifr24/11/2017 20:49:56
119 forum posts
10 photos
I'm struggling to get a good answer on this.
I need to make some boring head tools ( I can't buy what I need off the shelf) so silver steel would seem best as it can be hardened.
At the minute I'm just planning to machine alu with the tools I make but at some point would probably want to machine mild steel.
I have a hobby sieg X2 type milling machine and standard HSS end mills.
Bizibilder24/11/2017 20:57:15
173 forum posts
8 photos
In its soft state (as bought) silver steel can be machined with HSS.
Roderick Jenkins24/11/2017 21:13:02
2376 forum posts
800 photos
You will need to be very cautious about cutting speeds when you use them though. But, it's the best the Victorians had and they managed so go for it.
Rod
Neil Wyatt24/11/2017 21:17:55
19226 forum posts
749 photos
86 articles
Yes, but it likes sharp tools. Get the best finish you can. It will typically expand slightly on heat treatment, enough to allow you to finish with a stone after hardening.
mark smith 2024/11/2017 21:18:26
682 forum posts
337 photos
What sort of boring tools are you making. I got a load of excellent HSS ones off ebay that were made by Deckel and mostly unused,they work brilliantly. Many people make similar using silver steel and then hardened.
Edited By mark smith 20 on 24/11/2017 21:20:08
Edited By mark smith 20 on 24/11/2017 21:20:54
Anna 124/11/2017 22:11:46
72 forum posts
Hello Mark.
I make my boring tools shanks from silver steel, turned down to the appropriate diameters, then cross drilling at the end at a suitable angle, normally circa 45 degrees to then fit and silver solder an old hss centre drill protruding through the hole. finally grind down the hss centre drill to the form you need. Silver soldering will not affect the hardness of the hss.
regards Anna
David George 124/11/2017 22:26:02
2110 forum posts
565 photos
Some boring tools all are made by myself. Some are silver steel, some are high speed steel with grub screws, some have carbide tips silver soldered in place and some are made from solid high speed steel.
David
Chris Trice24/11/2017 23:02:05
1376 forum posts
10 photos
Cutting oil makes a big difference on silver steel. Neat works well.
