Andy Beckett | 17/11/2017 08:15:48 |
21 forum posts | Hi All, I've found myself a nice little Myford Super 7 with the makers stand, however it appears to be missing its adjustment feet on the bottom of the stand. I'm aware of the importance of getting the lathe level and as a starting point want to ensure the stand is level, any suggestions please? |
John Haine | 17/11/2017 08:36:45 |
5563 forum posts 322 photos |
I just use some M10 (I think) bolts nuts and washers with a scrap of Ali to spread the load, like this. |
Andy Beckett | 17/11/2017 08:41:54 |
21 forum posts | Thanks John, that's just the sort of help I needed. I'm picking it up Sunday so I'll have to look at the hole size. |
Clive Hartland | 17/11/2017 09:28:33 |
![]() 2929 forum posts 41 photos | I bought anti vibration feet, rubber pads on a plate and these are working fine. |
Andy Beckett | 17/11/2017 09:32:21 |
21 forum posts | Hi Clive, Thanks for your reply. I've seen those yellow ones, I think they come direct from Myford? However at £70 a throw I was looking at other options especially as I've just splashed out on the lathe. |
Mark Rand | 17/11/2017 10:14:03 |
1505 forum posts 56 photos | Rather than having the stand level, it's better to arrange it so it slopes a little bit towards the drain that's at the tailstock end of the tray. that way you don't end up with puddles of oil in the tray (total loss lubrication, way oil and cutting oil). If you want the lathe bed level, adjust the riser blocks to counter the stand's tilt. |
Cornish Jack | 17/11/2017 10:22:56 |
1228 forum posts 172 photos | Andy - I have 4 different sets of machine feet on adjustable uprights but all too large for the Myford cabinet lugs. I decided that mobility and stability were a useful add-on so popped mine onto a pair of Lidl's finest 'Pensioner's Skateboards'!! The second shot was taken a couple of minutes ago - the camera setup is rubbish!! rgds Bill |
KWIL | 17/11/2017 10:34:09 |
3681 forum posts 70 photos | Lathe needs some tlc! |
peak4 | 17/11/2017 10:42:36 |
![]() 2207 forum posts 210 photos | I'm using something similar to these on my Warco copy in the new workshop **LINK** which allow for the uneven concrete floor. Beware, the Myford is a bit top heavy, with a tendency towards the rear. I've only used adjustable feet in the short term, as I'm not sure where the lathe will finally be sited when its bigger cousin arrives. In the other workshop in Sheffield, my original genuine Myford is rawlbolted to the floor with appropriate shims. My Dore Westbury mill is on an angle iron cabinet, with a couple of further horizontal lengths of angle iron at floor level. These carry 4 heavy duty castors, with another set of these adjustable feet outboard of them. It means I can move the mill round, and then wind down the feet for stability.
Bill |
Andy Beckett | 17/11/2017 11:46:18 |
21 forum posts | Terrific advice guys, I've ordered four of the feet Peak4 directed me to. All I need now is some additional bits such as steadies and a bigger chuck and I'll be there. Thanks again. |
Cornish Jack | 17/11/2017 14:20:46 |
1228 forum posts 172 photos | "Lathe needs some tlc!" Could be, but then, so might you if you'd been through this...
this ... and this ... and then had 2 1/2 years in grotty storage while the house was rebuilt!!! But as long as it looks pristine, it's bound to work much better? John S might have generated some more apt phrases - miss him more and more Bill |
thaiguzzi | 18/11/2017 08:00:18 |
![]() 704 forum posts 131 photos | Posted by Cornish Jack on 17/11/2017 14:20:46:
this ... and this ... and then had 2 1/2 years in grotty storage while the house was rebuilt!!! But as long as it looks pristine, it's bound to work much better? John S might have generated some more apt phrases - miss him more and more Bill Bacton or Sea Palling? |
Bazyle | 18/11/2017 08:52:10 |
![]() 6956 forum posts 229 photos | Solid packing is always to be preferred. Slate is very good as you can split it to make various different thicknesses. If you have ended up using bolts keep the projection down to 1/4 in or less and fit a locknut. |
Clive Hartland | 18/11/2017 09:04:25 |
![]() 2929 forum posts 41 photos | Andy, I see much cheaper and suitable rubber floor mounts on the Bay. Clive |
Cornish Jack | 18/11/2017 23:19:46 |
1228 forum posts 172 photos | thaiguzzi - Bacton ... you a Norfolk boy?? - I'm not (obviously!! but worked for 2 1/2 years in Bangkok) rgds Bill |
thaiguzzi | 19/11/2017 07:18:19 |
![]() 704 forum posts 131 photos | Posted by Cornish Jack on 18/11/2017 23:19:46:
thaiguzzi - Bacton ... you a Norfolk boy?? - I'm not (obviously!! but worked for 2 1/2 years in Bangkok) rgds Bill Moit be, moit be. Hey, got a light boi? Lived in Bacton as a kid in the 60's for a couple of years. As a teenager in North Walsham, grew up drinking in Aylsham, Stalham and NW. Moved around a bit inc Germany, settled back in Norfolk, ended up having a MC engineering business near Wroxham for 15 years and a house in Norwich. Sold up and moved here in '03. |
Cornish Jack | 19/11/2017 15:25:30 |
1228 forum posts 172 photos | thaiguzzi - you have a PM |
Mark Rand | 19/11/2017 20:05:32 |
1505 forum posts 56 photos | Allan Smethurst deserved better
Lived in Lynn (Gaywood and South Wootton) as a child. |
Stephen Follows | 19/11/2017 23:30:27 |
![]() 119 forum posts 3 photos | I fitted mine cabinet to slope towards the drain and levelled the lathe on the raising blocks. Best of both worlds! |
thaiguzzi | 20/11/2017 03:58:23 |
![]() 704 forum posts 131 photos | Posted by Cornish Jack on 19/11/2017 15:25:30:
thaiguzzi - you have a PM Received, and replied, ta Bill. Regards, Mike. |
