Neil Wyatt | 12/11/2017 20:21:17 |
![]() 19226 forum posts 749 photos 86 articles | In The Amateurs Lathe is a design for a grinding spindle. As far as I can see if you tighten up the pulley nut it will jam the spindle solid clamping the bearings and the pulley either side of the rear bearing cover, which is screwed into the body of the spindle. Am I misreading the drawings or just the first person to look at them properly? Neil |
JasonB | 12/11/2017 20:36:33 |
![]() 25215 forum posts 3105 photos 1 articles | I wonder if the pulley should have been shown partly threaded then you could use that to adjust preload and lock with the nut. |
Mick B1 | 12/11/2017 20:42:19 |
2444 forum posts 139 photos | Leonardo's tank wouldn't gone anywhere either. |
Carl Wilson 4 | 12/11/2017 21:23:02 |
![]() 670 forum posts 53 photos | It's on p84 in my copy. I can't see where the driving feature is between the pulley and the shaft. Also agree that if tightened the nut will just nip the bearings up. If partially threaded the pulley would not set endfloat on the taper plain bearing because it would still just pull the shoulder up against the front of the forward most roller bearing. As drawn, unless I'm missing something, it won't do anything. Edited By Carl Wilson 4 on 12/11/2017 21:23:54 Edited By Carl Wilson 4 on 12/11/2017 21:24:36 Edited By Carl Wilson 4 on 12/11/2017 21:25:34 Edited By Carl Wilson 4 on 12/11/2017 21:28:39 |
Neil Wyatt | 12/11/2017 21:29:45 |
![]() 19226 forum posts 749 photos 86 articles | Maybe, but that would mean the pulley was running against the inside of detail 7, it would really need a thrust bearing before the pulley. I think detail 7 (the end plug) should be bored 0.750 right through so the pulley can directly bear on the inner race of the bearings giving positive location in both directions. If 7 is the part at top left of fig. 201, this might be right? Neil |
Andrew Moyes 1 | 12/11/2017 21:35:15 |
158 forum posts 22 photos | The photo on p177 of my hardback copy shows the bore of the rear bearing to be larger than that of the front bearing i.e. different to the drawing. I think it's a drawing error and the pulley should clamp up against the inner race. Andrew |
Carl Wilson 4 | 12/11/2017 21:41:35 |
![]() 670 forum posts 53 photos | That aside, how does the pulley drive the shaft? There is no key or driving feature. |
Mike Poole | 12/11/2017 21:57:29 |
![]() 3676 forum posts 82 photos | If that's the first time it's been noticed then that's 69 years, in the photo of the parts it looks as though it is bored through at the 0.750" diameter which would make sense to axially locate the shaft with the ball races by tightening the pulley against the bearings with the nut. I still think it is a great book though. Every dog is allowed one bite. Mike Should have refreshed before posting the same observations as others. Edited By Mike Poole on 12/11/2017 22:01:00 |
Robbo | 12/11/2017 23:14:11 |
1504 forum posts 142 photos | Neil Tomorrow I'll send you a pdf of the original article on the grinding attachment, from "The Model Mechanic" which may help. Published August 1946. You probably remember that Lawrence Sparey was the Editor, though the article was credited to "F.Williams" - probably a nom de plume.
Edited By Robbo on 12/11/2017 23:16:11 |
Carl Wilson 4 | 12/11/2017 23:37:58 |
![]() 670 forum posts 53 photos | Neil if you solve the mystery you could write it up for Mew!? |
Neil Wyatt | 13/11/2017 00:28:38 |
![]() 19226 forum posts 749 photos 86 articles | Well if Robbo's PDF solves it, I will share! |
Ian S C | 13/11/2017 09:34:04 |
![]() 7468 forum posts 230 photos | What is the "slight undercut" indicated on the RH end of the shaft, it doesn't appear to be for run out of the thread. On the drawing in my book the assembled diagram looks as though the groove appears filled with metal of the pulley? Ian S C |
Ady1 | 13/11/2017 09:38:47 |
![]() 6137 forum posts 893 photos | Curious, I was thinking about this kinda thing this morning If you want a simple reliable strong "headstock type system" then have bearings in the middle for the shaft to run on and put a needle/roller bearing on each end to handle the thrust loading requirements Preload lightly edit: The ease with which we can get bearings nowadays makes things much simpler edit 2: The original article probbly expected you to use a basic common sense 1946 system like a thrust washer Edited By Ady1 on 13/11/2017 09:56:42 |
Carl Wilson 4 | 13/11/2017 11:34:13 |
![]() 670 forum posts 53 photos | I've been looking at that photo in the book and thanks for posting it so others can see. There is no positive driving feature on the shaft.
I agree with Ian in the drawing in my book it looks like the little undercut has the pulley metal in it. Can't be right. Edited By Carl Wilson 4 on 13/11/2017 11:35:58 |
Clive Foster | 13/11/2017 11:46:39 |
3630 forum posts 128 photos | Looking at my 1960, third edition, of the Amateurs lathe there are considerable discrepancies between the drawings and the pictures of Mr Spareys' personal version which are the same as in the previous post from Ady1. In particular the pulley on his has a fairly long stand off between it and the cap, part no 7 on the drawings, whilst the drawings show the pulley pulled back very close to the body with the stand off inside the cap. Looking at the cap in the pictures it appears to have a recess for, presumably, a deep felt washer to help keep grit out whilst the one in the drawings has a groove for a much shallower one. As drawn part 7 will jam up the bearings nicely and the pulley will come up tight against the cap both inside and outside too if everything is made exact to size. Looks like the pulley and end cap drawings have been somewhat codged up during an attempt to make the device simpler for the home shop man to make. Perhaps the intention was to make the two felt dust excluder rings the same thickness. The screw on rather than integral wheel carrier taper might also be considered an appropriate simplification, but thats something that I'd disagree with. On deeper investigation the whole design is, to put it bluntly, crap for the assumed target audience. Complex in the wrong places. At the original 1948 printing date there is pretty much no way any ordinary Model Engineer would have a hope of making the thing to a sufficiently good standard with the sort of lathe typical of the time. A Southbend or Atlas would perhaps be up for it but Drummond, Portass, Zyto et al. Ferrgedditt. Heck would Home Shop Guy even have a micrometer then. Even by 1960 when Myford 7, Boxford et were making some penetration it wouldn't be a straightforward job. There are some fairly obvious simplifications that would make life much easier. Looking at the pictures the original is actually easier to do. As for making a small grinding wheel from a broken bigger one as suggested on page 180. Even for less safety conscious era thats flat out irresponsible. Maybe Experienced Man can repurpose a broken wheel. But Home Shop Harry taking on a bit cadged off mate in t'pub! Um. I suspect the reason that no-one has noticed the error is that no-one ever built the thing. Which does raise the question of what percentage of the lovingly crafted drawings pictured in the ME / HSM books and publications over the years actually ever get made. I certainly have never made anything to drawing. Read the articles, nicked ideas and filed off the serial numbers so folk think "gosh, he's clever" (how wrong can you be!). Yup. But make to drawing. Nope. Clive. Edited By Clive Foster on 13/11/2017 11:57:32 Edited By Clive Foster on 13/11/2017 11:58:57 |
Carl Wilson 4 | 13/11/2017 11:55:54 |
![]() 670 forum posts 53 photos | Glad someone said it. It's a great book full of sage wisdom. But that drawing is nonsense. |
Bazyle | 13/11/2017 12:34:24 |
![]() 6956 forum posts 229 photos | What's the fat tube in the middle of the picture. Looks like a bearing spacer to me - setting the gap between the two inner faces of the smaller part of the bearing. Same on some car wheels except they have pick off shims to adjust the endfloat. A model engineer would test and turn a tad off. |
Tim Stevens | 13/11/2017 12:37:47 |
![]() 1779 forum posts 1 photos | Surely you are not saying that someone actually goes out and makes all those wonderful complex models in ME? Tim |
Clive Foster | 13/11/2017 12:57:10 |
3630 forum posts 128 photos | Bazyle Fat tube is a classic taper adjustable double plain bearing. In the photo you can't readily see the adjustment slits which let it compress slightly when pushed down the taper so setting exactly the right clearance. Just visible if you know they are there. Lord knows how Home Shop Harry is supposed to get the adjustment taper in the body concentric with the ball bearing recesses. Not to mention getting the bearing bore and external taper similarly concentric. Talking sub tenths thou tolerances here if its all gonna go together and turn. I'm a fair machinist on a good day, and my Smart & Brown 1024 is very accurate, but I'm none to sure if I could turn that lot out to drawings and have it work on assembly. Usual practice in that era would to use a "magneto" bearing, i.e. separate cup cone and ball race, at each end in simple bored tube. Fit an appropriate spacer to keep the cups apart. Use a nice fat shaft to minimise whirl and call it good. For this sort of device grinding loads are small so no need for mega bearings and accuracy on a lathe cross slide a couple of tenths at best. Clive. Edited By Clive Foster on 13/11/2017 13:07:24 |
Bazyle | 13/11/2017 13:03:52 |
![]() 6956 forum posts 229 photos | Bah lost my post. start again. Ignore parts of my previous post. The ring top left in the photo is a locking ring for the front end cap as seen in the completed unit. The rear bearing is pushed home against the seating that I assume is in the body and locked with the endcap. The inner fat tube is made to drawing length and assembled with pulley etc locked hard with the end nut. No lock nut needed as it is just tightened fully. The inner assembly is fixed length not adjustable. The spindle is turned between centres on your round bed Drummond and used as a mandrel for getting the ends of the spacer true. If your 3 jaw is a bit unsteady for getting the bores in the body parallel to one another do the final bore with a between centres boring bar. After finishing one end you switch the bar on its centres end for end so the second end is exactly the same bore. Actually it is a better design in this respect to the Quorn.
