Picking up edges with a coaxial indicator.
Andy Pugh | 30/10/2017 20:28:45 |
67 forum posts 1 photos | I have a touch-probe that fits my vertical head, but not the horizontal. I have a coaxial indicator that fits both, but that's no good for picking up edges. I had a brainwave at the weekend, and used the square "Stevensons Collet Blocks" from arc-eurotrade. This turns out to be 40mm square with a nice ground and tapered hole. SO once the dial was running true I knew I was 20mm above the table and 20mm from the edge of the part being machined. As a bonus, the fact that the bore is tapered means that the dial shows oval if you are out of square too.
Thor 🇳🇴 | 31/10/2017 05:50:41 |
![]() 1766 forum posts 46 photos | Hi Andy Thanks for sharing. Thor |
thaiguzzi | 31/10/2017 07:31:21 |
![]() 704 forum posts 131 photos | Smart. Like it. |
Michael Gilligan | 31/10/2017 08:10:55 |
![]() 23121 forum posts 1360 photos | The 'oval' test is a particularly nice bonus. ... Good thinking MichaelG.
Brian Wood | 31/10/2017 09:22:16 |
2742 forum posts 39 photos | Inspired thinking Andy, especially the rotational alignment indication. I think John would have issued his expression 'job's a good un' in recognition. Thank you for sharing it Regards Brian |
John Reese | 31/10/2017 21:12:46 |
![]() 1071 forum posts | It is not often I learn something new. Thanks. BTW, this should work with a normal dial test indivator as well as the Blake. |
Ian Skeldon 2 | 31/10/2017 21:25:23 |
543 forum posts 54 photos | Like it. |
DMB | 31/10/2017 21:40:10 |
1585 forum posts 1 photos | Well done Andy. Brilliant idea. Will use this in future, since I have the sq. and hex blocks.
Russ B | 07/11/2017 05:24:53 |
635 forum posts 34 photos | +1 Andy, great idea! I've just got my ER40 Sq.+Hex set! I've bought things in the past that I thought was going to be handy..... and it really just didn't fulfil that expectation. The more I do and see people doing with the these blocks, the more I like it! I've added a pair of 20-40-80 + 10-20-40 Stevenson’s blocks to my Xmas list as I've always fancied a set and they'll prove invaluable for a couple of checks I want to make on my lathe next year. Edited By Russ B on 07/11/2017 05:25:14 |
Bazyle | 07/11/2017 08:46:35 |
![]() 6956 forum posts 229 photos | It must work on 5C blocks too - Just need a coaxial indicator. |
