Steve Pavey | 26/10/2017 19:39:22 |
369 forum posts 41 photos | Found in the bottom of a box of bits I bought at a car boot sale: Edited By Steve Pavey on 26/10/2017 19:57:24 |
Gray62 | 26/10/2017 20:00:50 |
1058 forum posts 16 photos | They look like the tools we used to make for removing the pointer from pressure gauges, could also be a watchmakers tool for pulling clock hands from a taper shaft. |
John Reese | 26/10/2017 20:20:23 |
![]() 1071 forum posts | The one on the right looks like a hand jack for pulling the hands off pressure gauges. The point on the screw looks buggered. The one on the left is a clamp for wire on some type of electrical equipment. |
John Slaven | 26/10/2017 21:07:54 |
![]() 27 forum posts 17 photos | Hi Steve, Definitely a pointer puller for pressure gauges or clock hands. Used one almost every day to pull pressure gauge pointers off for calibration. Check out the link here.**LINK**
Cheers the Noo John |
Oldiron | 26/10/2017 21:44:56 |
1193 forum posts 59 photos | The one on the left looks to be the clamp section of an earth tag. The earthing strip is slipped through the groove, wrapped around a copper water pipe or ground stake and passed through the groove again then the screw tightens it all up. |
Steve Pavey | 26/10/2017 23:33:23 |
369 forum posts 41 photos | I wondered if the one on the left was electrical. I would never have guessed the pressure gauge pointer puller though. Thanks very much to all.
John McNamara | 26/10/2017 23:58:13 |
![]() 1377 forum posts 133 photos | Given the length of screw travel I wonder if the larger one is a small chain breaker. |
Joseph Noci 1 | 27/10/2017 04:27:49 |
1323 forum posts 1431 photos | Chain breakers tend to be open ended with some sort of slotted guide to align the chain..
Edited By Joseph Noci 1 on 27/10/2017 04:28:53 |
john carruthers | 27/10/2017 09:07:50 |
![]() 617 forum posts 180 photos | I made a similar gadget to the one on the right for pulling the pinions from stepper motor shafts on telescope mounts. |
Ian S C | 27/10/2017 12:10:42 |
![]() 7468 forum posts 230 photos | An advantage when photographing these sort of things is to place them next to something for reference to size. Ian S C |
