"Makers Plates" rivets?
Andrew Tinsley24/10/2017 10:39:47
1817 forum posts
I have several items where the makers plate / specification are coming adrift. These plates are held on by some kind of rivet.
I assume these rivets are made to dead length and after they are inserted into a hole of a critical depth, one gives them a good tap to expand them.
I am not sure about this as it means the depth of the holes and plate thickness are critical. If hole is too deep then the rivet cannot expand radially and if too shallow then the plate will be loose.
So how do they work and can they be purchased? They are a bit on the small side to turn. It would mean getting my watchmakers lathe sorted!
Andrew.
Michael Gilligan24/10/2017 10:44:09
23121 forum posts
1360 photos
Andrew,
These are often 'Hammer-Drive" rivets [or some such] and they are hard steel, with a multi-start 'slow' thread.
Readily available, but the very devil to remove if they were fitted properly in the first place !!
Clive Brown 124/10/2017 10:44:34
1050 forum posts
56 photos
In a recent post, I mentioned hammer drive rivets. AFAIK, they can be purchased on-line. They are steel r/h rivets ad have a helix on their shank. They can be driven into a correctly sized blind hole. Might suit your need.
Chris Evans 624/10/2017 10:44:48
2156 forum posts
We used to use "Hammertite" screws/rivets to affix makers names to our mould tools. A rivet with a sort of spiral thread form that twisted in the hole as it was tapped in.
Journeyman24/10/2017 10:47:36
1257 forum posts
264 photos
Drive Rivet
D Hanna24/10/2017 12:07:33
45 forum posts
6 photos
What diameter/length do you need Andrew. I have a heap of 1/8"x 5/16" here if they will suit.
Clive Foster24/10/2017 13:27:17
3630 forum posts
128 photos
Have you tried reseating the rivets using a punch with suitably shaped hollow head. Never done it myself but I recall the idea being mentioned during tea break many years ago. Don't remember the topic coming up again so I assume it worked. Either the by the rivet going in a bit deeper or by the head deforming to take up the slack.
Brian G24/10/2017 14:04:34
912 forum posts
40 photos
If it is a new installation you could always cheat and use slotless round head screws (threaded rivets) like these **LINK** into a tapped hole.
Neil Wyatt24/10/2017 14:37:31
19226 forum posts
749 photos
86 articles
Superglue
>ducks<
Andrew Tinsley24/10/2017 15:11:49
1817 forum posts
Hello,
Thanks everyone for enlightening me. I do seem to remember this type of "rivet" from the distant past. It took everyone here, to get that surfacing in the brain!
I have no idea what size the originals were, so some judicious measuring is needed! Thanks for the offer Dallas, I will get back to you once I have measured up the holes!
Super gluing sounds a good way to cheat, but the rivets have disappeared long ago before I got the items, so no go with that idea.
Probably be accused of being finicky, but a makers plate hanging on one fixing does annoy me! I suppose I have more than enough to do without fiddling about with such things. But it would remove a constant niggle!
Thanks everyone for being so helpful!
Andrew.
Roderick Jenkins24/10/2017 16:34:35
2376 forum posts
800 photos
On my little Pultra I used copper rivets and Loctite. I sheared off the old rivets with a cold chisel. Fortunately the holes were much deeper than they needed to be so I could drive the old shaft deeper in, leaving 1/8" to hold the new rivet.
HTH,
Rod
not done it yet24/10/2017 16:42:58
7517 forum posts
20 photos
Posted by Brian G on 24/10/2017 14:04:34:
Are they not designed to have nuts fitted on the 'hidden' face, so drilled right through?
Andrew Tinsley24/10/2017 17:54:32
1817 forum posts
I had a nasty suspicion that I might have some of these fixings somewhere. Not realising what they were, a quick search in the odds and sods cupboard revealed two packets of said fixings. Job now done, very worrying that I had to ask here, when the solution was in the damn cupboard.
I claim a very senior moment, the alternative is ......... now what was I going to say? Forgotten already!
Thanks everyone,
Andrew,
Jeff Dayman24/10/2017 18:30:31
2356 forum posts
47 photos
Just FYI these fasteners are called type U metallic drive screws in north America. Link below to dimensions of ANSI std ones in case anyone is still awake and interested.
https://www.hpaulin.com/media/wysiwyg/Round_Head_Type_U_Metallic_Screws.pdf
