Setting Zero Mitutoyo 293-795-30 0-25mm digital micometer
Emgee | 08/09/2017 15:16:08 |
2610 forum posts 312 photos | Help please to reset a Mitutoyo 25mm digital mic. After replacing the battery all my attempts have failed to remove the flashing P (print) from the display. Fitted a new battery, closed anvil to stop, pressed Origin once, pressed Origin for a second time. P still flashing. If Origin button held down after about 8 seconds an E--o3 message is displayed. The same message is displayed if the Zero/ABS button is pressed. I do not have original instructions but have followed procedure as described on the Mitutoyo site. Any help appreciated. Emgee |
Michael Gilligan | 08/09/2017 15:27:52 |
![]() 23121 forum posts 1360 photos | Maybe you have seen this page already, but here's a good collection of manuals from Mitutoyo: https://www.mitutoyo.co.jp/eng/support/service/manual/001.html MichaelG. |
Emgee | 08/09/2017 16:29:46 |
2610 forum posts 312 photos | Yes Michael, got details as in my request from there but Search for the model number 293-795-30 gives nothing. Emgee |
Michael Gilligan | 08/09/2017 16:45:01 |
![]() 23121 forum posts 1360 photos | Sorry ... I failed to notice the model number in your thread sub-title. MichaelG. |
Brian Sweeting | 08/09/2017 16:45:13 |
453 forum posts 1 photos | You say that you have closed the mic, should you not be using the calibration block to set the origin? |
SillyOldDuffer | 08/09/2017 16:52:07 |
10668 forum posts 2415 photos | I've got a height gauge that has a nervous breakdown every time I change the battery. I think it's because the gauge remembers previous settings for several minutes whilst the cell is being swapped over. If the volts are already too low when the change is made, the memory is garbled. That causes chaos when the gauge powers up on the new cell. For me the cure is to wait about 20 minutes after taking the old cell out before putting the new one in. I guess letting the gauge discharge completely before putting in a new battery forces a full reset, restoring sensible factory defaults. May not solve your problem but easy enough to try. Dave |
Simon Williams 3 | 08/09/2017 16:58:56 |
728 forum posts 90 photos | If I remember right, the P isn't print it's to indicate that the origin has been lost. Remove battery, leave for a few minutes. Replace battery, display shows zero's and flashing P. Display shows zeros even if you move the thimble. Close anvil and spindle for true zero. Press origin (from memory, check instruction). Now flashing P is off, and display responds to thimble position. If not it's sicky poorly |
Phil super7 | 08/09/2017 17:01:56 |
24 forum posts | When the "p" is flashing press the Origin Button once do not hold Phil |
Raymond Anderson | 08/09/2017 17:07:49 |
![]() 785 forum posts 152 photos | Looked all through the Mit catalogue and 293 is certainly part of the product family but the range does not appear to go up as far as the next 3 numbers ie 795. Do you have the numbers correct ? as it is easy to err on that. [ I've been there ] Also is it one of the "Digimatic " ones. as not all the Digital models are "Digimatic " |
Raymond Anderson | 08/09/2017 17:39:00 |
![]() 785 forum posts 152 photos | Just removed the battery from one of me Mit's [ 293331] once I set the origin the P will flash and as Phil mentioned press it [ Origin ] again and it will [ should ] vanish. Not sure about the E--03 code, Possibly a faulty battery. Just tried putting in the number of my mit 25-50mm Digimatic [ 293331] and even it comes up with "no results " so it is obviously not a current model, looks like the same for Emgee's one.
Neil Wyatt | 08/09/2017 17:59:07 |
![]() 19226 forum posts 749 photos 86 articles | One way to clear the confused memory of a caliper or micrometer is to briefly short the battery terminals, this is enough to discharge the on board capacitance and clear the memory. Neil |
Michael Gilligan | 08/09/2017 18:02:00 |
![]() 23121 forum posts 1360 photos | At the risk of embarassing myself further: This may help: **LINK** https://www.mitutoyo.co.jp/eng/support/service/manual/pdf/99MAB025M4.pdf MichaelG. . P.S. ... The part number looks valid, albeit 'discontinued' http://uk.rs-online.com/web/p/micrometers/0431426/ Edited By Michael Gilligan on 08/09/2017 18:05:20 |
Nick_G | 08/09/2017 18:05:57 |
![]() 1808 forum posts 744 photos | Posted by Neil Wyatt on 08/09/2017 17:59:07:
is to briefly short the battery terminals, Neil . When the battery has been removed of course. Nick |
Emgee | 08/09/2017 21:50:23 |
2610 forum posts 312 photos | Thanks for all the tips, will try them one by one tomorrow, probably starting with shorting the battery compartment terminals out to discharge any voltage present. Emgee |
Emgee | 09/09/2017 11:03:34 |
2610 forum posts 312 photos | Still no change, the Origin button now toggles the display between P flashing and the E--o5 mesage. (Not 03 as stated incorrectly earlier unless the fault has changed) At rest and at frequent intervals the display momentarily shows 666.000 and not 0.000. (mm mode selected) Does anyone know or have used an instrument repairer with a good outcome ? Emgee |
jimmy b | 09/09/2017 12:01:25 |
![]() 857 forum posts 45 photos | E-05 makes more sense!
I dropped a Mitutoyo QuantuMike at work and got the same error. Tried all sorts of things, in the end the inspector had to strip it down. Turns out the encoder had shifted.
Jim |
Simon Williams 3 | 09/09/2017 12:43:09 |
728 forum posts 90 photos | Just before you give up and start taking things to bits, I've seen the E-05 message cured by fitting a new battery. It's worth trying a new new battery |
Raymond Anderson | 09/09/2017 13:09:27 |
![]() 785 forum posts 152 photos | Error code E-05 is an overspeed error for Digimatic calipers The overspeed/ electrical noise error code for Digimatic mic's is E-oS.. Certainly would try a known good battery. Failing that, a call to Mitutoyo would be in order. I certainly would not attempt to take any of mine to pieces.
Michael Gilligan | 09/09/2017 13:40:19 |
![]() 23121 forum posts 1360 photos | Posted by Emgee on 09/09/2017 11:03:34:
At rest and at frequent intervals the display momentarily shows 666.000 and not 0.000. (mm mode selected) . You may need the services of an Exorcist MichaelG. . But seriously: Post #6 on this thread refers: http://www.practicalmachinist.com/vb/metrology/help-mitutoyo-electronic-digital-micrometer-200909/ Edited By Michael Gilligan on 09/09/2017 13:59:45 |
Emgee | 09/09/2017 19:29:41 |
2610 forum posts 312 photos | Hi Michael, thanks for the link, interesting reading but no access to the pictures, really sounds like it is past the use date unless an instrument repairer can be found. In the meantime back to the conventional mic !!! Emgee |
