Andrew Tinsley | 14/08/2017 17:30:56 |
1817 forum posts 2 photos | I need to make up some small boring bars in the near future. Looking at various designs I came across the Hemingway kit for the "Dore small boring bars". In the description it states that "Tension induced by the pushrod makes even the smallest tool surprisingly rigid" Now the description infers that the boring rods are drilled out and a pushrod is inserted. Presumably these push rods must be under some serious compression to fulfil the above claim. There doesn't appear to be anything to produce this compression from the photo. What am I missing? Andrew. |
JasonB | 14/08/2017 17:36:33 |
![]() 25215 forum posts 3105 photos 1 articles | You can just see a grub screw poking out t back, that is used to apply pressure to a rod. Whether the tension makes much difference I don't know.
Good video on making similar boring bars below Edited By JasonB on 14/08/2017 17:37:11 |
Muzzer | 14/08/2017 17:37:21 |
![]() 2904 forum posts 448 photos | Sounds like bunkum to me. What material is the push rod said to be made of?? Presumably the push rod is a means of locking the bit in place from the other end of the bar. Perhaps we should drill out all of our boring bars and insert a compression rod just to stiffen them up. I wonder why nobody has thought of that before. In fact, the applications are endless.... Merry |
Andrew Tinsley | 14/08/2017 17:57:13 |
1817 forum posts 2 photos | Thanks Jason, I thought that the "things" poking out of the back were the rods, didn't realise they were grub screws! Memo to self, get your eyes tested! It should be a relatively simple matter to calculate what the effect of internal compression should have on the deflection characteristics of the bar as a whole. My applied maths is getting very rusty, maybe I should try the calculation. Or maybe it is bunkum! I don't fancy trying to drill the bars out to that sort of depth. When people talk of long series drills , I tend to take cover. Andrew. |
SillyOldDuffer | 14/08/2017 18:19:50 |
10668 forum posts 2415 photos | I can't do the maths either so my opinion might well be bunkum too. Is there an expert in the house? My guess is that the effect is akin to pre-stressing concrete or inflating a pneumatic tire. Being in compression means the inner rod of the boring bar will resist any bending force that tries to compress it further. At the same time, the outer part is in tension making it more resistant to any bending forces trying to stretch the metal. So as a result I reckon the bar will be more rigid compared to an unstressed equivalent. As there must be a downside I suppose that a stressed bar is more likely to snap than bend? If no-one knows the answer I might make one and test it. The joy of being retired! Dave
larry Phelan | 14/08/2017 18:29:20 |
![]() 544 forum posts 17 photos | Dont think I,ll worry too much about this one ! I think I,ll just "pass". |
duncan webster | 14/08/2017 19:18:40 |
5307 forum posts 83 photos | It's bunk. The comparison with concrete is not valid. Concrete has very little tensile strength, the purpose of prestressing is to put it in compression when not loaded, so that when it is loaded it doesn't go into tension. Steel is very good in tension, and even better in compression, and has the same modulus of elasticity both ways until you reach its limit of proportionality (near enough yield between friends) |
Swarf, Mostly! | 14/08/2017 19:38:49 |
753 forum posts 80 photos | Hi there, Andrew, If you go ahead with the Dore design, you'll need some of these: I found three of these in my 'stash' some time ago while looking for something else. I posted these pix here asking if anyone recognised them but nobody did. Best regards, Swarf, Mostly! |
JasonB | 14/08/2017 19:40:44 |
![]() 25215 forum posts 3105 photos 1 articles | Probably cheaper to make the holders from a bit of steel or CI bar than buy castings, and then you only really need them if you want to mount direct to the topslide rather than use a toolpost. |
sean logie | 14/08/2017 19:45:24 |
![]() 608 forum posts 7 photos | Would cast iron do for making tool holders for a QC toolpost ? Sean |
JasonB | 14/08/2017 19:51:34 |
![]() 25215 forum posts 3105 photos 1 articles | I think SG iron would be OK but with the Dickson type the tee slot edges may be a bit weak if you used grey iron which is the usual bar you buy though SG is available. Given the fact SG iron is not a lot different to machine than steel you may as well just use steel. |
Andrew Tinsley | 14/08/2017 20:14:20 |
1817 forum posts 2 photos | Hello, I have just done some mathematical scribbling and surprisingly, the bar will bend less for a given deflecting force if the central rod is under compression. I am a CGS man and looking up constants in MKS and even worse, modern units, gave me a headache. So I don't know if the stiffening effect is appreciable at the compressive force applied by a grubscrew, but I suspect it is! Andrew |
Enough! | 14/08/2017 21:52:57 |
1719 forum posts 1 photos | Posted by Andrew Tinsley on 14/08/2017 17:57:13: I don't fancy trying to drill the bars out to that sort of depth. When people talk of long series drills , I tend to take cover.
(I'll go away). |
duncan webster | 14/08/2017 22:01:54 |
5307 forum posts 83 photos | Posted by Andrew Tinsley on 14/08/2017 20:14:20:
Hello, I have just done some mathematical scribbling and surprisingly, the bar will bend less for a given deflecting force if the central rod is under compression. I am a CGS man and looking up constants in MKS and even worse, modern units, gave me a headache. So I don't know if the stiffening effect is appreciable at the compressive force applied by a grubscrew, but I suspect it is! Andrew You'll have to post your scribbling, I can't see how putting the centre under compression and the outside in tension changes the second moment of area, which is the important factor |
ega | 14/08/2017 22:17:32 |
2805 forum posts 219 photos | I have just confirmed my recollection that the earlier (ie Neil Hemingway's) catalogue did not contain the claim that "Tension, induced by the pushrod, makes even the smallest tool surprisingly rigid" (and I have not seen this suggestion in relation to other push rod-based designs). The primary function of the push rod is to secure the cutter, of course, but, instinctively, the claim seems valid; my understanding is that the reverse ie compressing the bar would make it stiffer. Perhaps the OP should ask Kirk Burwell about this. PS presumably the claim could be tested empirically. Edited By ega on 14/08/2017 22:23:52 Edited By ega on 14/08/2017 22:42:51 |
Perko7 | 15/08/2017 05:22:46 |
452 forum posts 35 photos | Not an expert (or even close) in these things but seems to me a bit like a guitar neck, which has a steel truss-rod through the centre which is in tension, thus keeping the timber neck pre-stressed in compression, making the neck much more rigid so that lateral forces need to be a whole lot higher to impact tuning than in an un-stressed neck. |
John Haine | 15/08/2017 06:52:07 |
5563 forum posts 322 photos | The compression rod might well make the boring bit more rigidly held in the bar. But the system must be linear so it is hard to see how applying a constant compression or tension in the bar can increase its rigidity. |
Nige | 15/08/2017 07:34:58 |
![]() 370 forum posts 65 photos | By coincidence I came across this yesterday while reading "Screw Cutting In The Lathe" by Martin Cleeve. No mention of bar tensioning effects or anything other than locking the tool bit in the end of the holder. Hope it's ok to post this picture. INSERTED BIT TOOLS...para refers. |
JasonB | 15/08/2017 08:17:56 |
![]() 25215 forum posts 3105 photos 1 articles | Any F360 users fancy trying out their FEA skills on this? |
ega | 15/08/2017 09:31:49 |
2805 forum posts 219 photos | Has anyone mentioned that the push rod avoids the need for a grub screw at the business end of the bar? Nige: I trust you are enjoying MC's excellent book. |
