Clarke drill press
Harry Wilkes10/08/2017 22:04:11
1613 forum posts
72 photos
I have a Clarke drill press Clarke CDP5DD for what I paid for it, it's served me well, however I need to replace the motor but I cannot find what the motor frame size is ! Would anyone know or any advice on how to establish the frame size ?
Cheers
H
not done it yet10/08/2017 23:09:00
7517 forum posts
20 photos
Have you removed said motor and compared foot dimensions with a list like on engineeringtoolboxdotcom?
Neil Wyatt11/08/2017 09:13:39
19226 forum posts
749 photos
86 articles
When I was looking for a motor once, I discovered it would have been cheaper to buy one of those pillar drills, remove the motor and throw the bits in the scrap bin.
Prices have risen since, but it may be cheapest to replace the whole thing.
Compare:
Drill press at £80
Slightly more powerful motor at £83
<edit> if it hasn't burnt out, you probably only need to replace the start/run cap[acitor under a shroud on the side of the motor. Bargains! Much cheapness!
Edited By Neil Wyatt on 11/08/2017 09:14:43
martin perman11/08/2017 09:33:10
2095 forum posts
75 photos
Harry,
Go to this link https://www.machinemart.co.uk/ on the bottom right of the screen is "expert advice and Parts and service support" I've used it and found the response very helpful.
Martin P
larry Phelan11/08/2017 09:35:47
544 forum posts
17 photos
Agree with Neil ! Check out the capacitor first. Electric motors seem to go on for ever,I have some still running well after 50 years of workshop use. Capacitors are cheap.
Ian S C11/08/2017 10:45:26
7468 forum posts
230 photos
We've just retired one(still going strong) on the blower on the church pipe organ, made in 1917.
Ian S C
Harry Wilkes11/08/2017 12:26:45
1613 forum posts
72 photos
Thanks for all replies
Not Done It Yet Intend to remove motor asap but just had minor surgery on left hand for carpal tunnel sad
Neil Same thought had crossed my mind
Martin Have seen the link so after your comment will give it a go
Thanks H
Grizzly bear11/08/2017 20:55:44
337 forum posts
8 photos
Metalworker Drill press, capacitor failed. Got one from RS Components, approx. £6 post free,
The new capacitor wouldn't fit inside the box, so strapped it to the motor. Perfect!
Regards, Bear..
Harry Wilkes12/08/2017 15:28:50
1613 forum posts
72 photos
Single handed 'pun intended' had a closer look a the motor it looks like it's a special the mounting bracket is spot welded to the motor case and the shaft has been turned down for 0.625 to 14mm ! A quick check on the website 'not done it yet' suggested put's the motor at frame 56, I was looking to uprate the motor but as Neil pointed out a motor is nearly the cost of a new drill press so for now when hand allows I think I'll look at changing the bearings.
H
Mike12/08/2017 17:21:25
713 forum posts
6 photos
I did just what Neil did when I wanted an electric motor. Cheaper by some considerable margin than buying just the motor, and I got a no-volt switch and a cheap but surprisingly accurate chuck into the bargain. I'm still trying to work out what to make out of the left-over bits.
