Speed of 4jaw chucks
larry Phelan09/08/2017 16:57:32
544 forum posts
17 photos
Came across an post recently regarding the safe speed for a 10" 4 jaw chuck or a 10" faceplate,so I decided to check to see if there were any markings on mine [ex Chester ]. Needless to say,there are none [no surprise there],so it seems to be a case of using that rare gift,common sense.
On the other hand,you can buy a saw blade in Lidle,s for 7 Euro with it,s max speed clearly stated Nuff said !
Ian S C09/08/2017 17:42:54
7468 forum posts
230 photos
Normally the speed of the chuck is limited by the maximum design speed of the lathe it was made for, this of course doesn't allow for electronic speed control modifications to old lathes that can increase the speed.
Ian S C
Nick_G09/08/2017 17:47:01
1808 forum posts
744 photos
High on the list of maximum speed must surly be how well balanced the setup contained in the jaws is.
Nick
HOWARDT09/08/2017 18:46:55
1081 forum posts
39 photos
You need to look at original manufacturers data for the chuck. You might be surprised how low some max speeds are.
larry Phelan09/08/2017 19:12:00
544 forum posts
17 photos
I might do that,if there was any data to go by,as I said there is nothing,so I just use common sense and start with a low speed and see how it goes. The danger is that someone with no experience will not know any different and just lash away. Chucks supplied with lathes come with no directions of any kind,I think they assume that you know what you are doing,which is all too often,far from the case. A simple stamp would be a great help.
I remember Sparey mentioned that you might be surprised how often you have to use back gear. How right he was !
JasonB09/08/2017 19:32:52
Posted by larry Phelan on 09/08/2017 19:12:00:
Bit of a sweeping statement, my chucks have max rpm stamped on them, even the imports.
J
Mikelkie09/08/2017 19:55:04
135 forum posts
13 photos
i worked on a Antonio Anselmi lathe with a 18in. 4 jaw, and on the machine is a warning notice "max speed on the 4 jaw chuck 270 rpm"
Howard Lewis10/08/2017 20:32:19
7227 forum posts
21 photos
Probably the limiting speed is not that at which the chuck body shatters, but the speed at which the jaws become detached. After all there is, comparatively, very little metal holding each jaw in place. Just a fork on the back of the jaw engaging in the adjusting screw.
To shatter a 18 inch cast iron chuck body, it would have to be rotated at several thousand rpm.
Automotive Products near Leamington Spa had a rig for burst testing things like Flywheels. It needed a 6 cylinder Jaguar engine, with a step up belt drive, to wind things upto bursting speed. The bang was quite dramatic (No one allowed in the test cell, with the item on test in an iron pot set into the floor) and even after the time needed to unbolt the cover, the remnants were still too hot to touch!
HOWARDT10/08/2017 20:51:05
1081 forum posts
39 photos
I think maximum speed is to do with deformation due to centrifugal forces as well as material strength. Watched a YouTube video recently, can't remember what chuck company it was, it showed the loss of holding force as the speed increased with a hydraulic power chuck. Also I remember ARC recalling chucks recently that had deformed due I suppose bad design/material.
MW10/08/2017 21:33:18
2052 forum posts
56 photos
Posted by JasonB on 09/08/2017 19:32:52:
J
It is unfortunately, I don't have one on my 8" import. I reckon I wouldn't want to take it very fast anyway. The off balance nature of what you normally put it one makes it quite risky.
Michael W
Michael Briggs10/08/2017 21:59:47
221 forum posts
12 photos
Counter balance weights, simples.
