Insane bolts giving us runaround
Rik Shaw09/08/2017 11:32:18
1494 forum posts
403 photos
Not model engineering I know but still relevant I hope.
A friend and his men recently did me a good favour by moving and positioning my new lathe and I would like to repay the favour. In the course of his business he has to remove large bits of machinery from factories and the like. This invariably leaves redundant anchoring studs/bolts sticking out of the concrete floor. Up to now they have gas cut the studs of but increasingly the elfs will not allow the showers of sparks this involves (think food factory/refineries). The same also applies to angle grinding. So an alternative – non spark/flame - method - needs to be found.
Up to now they have been using a length of thick walled tubing and snapping the smaller diameters of but even this often leaves some sticking out of the ground. The larger diameters of course pose even more of a problem. He has asked if I could come up with an idea and make something to do the job. So, given that two (or more) heads are better than one I am looking for suggestions.
The solution needs to be as cheap and cheerful as possible. Any bright ideas?
Rik
Martin Kyte09/08/2017 11:43:49
3445 forum posts
62 photos
Really big side cutters. Failing that, shaped demolition charges.
These would do M10.
or the old fallback of the good old fashioned cold chisel.
regards Martin
JasonB09/08/2017 11:46:33
Not the cheapest but have had it done on contracts was involved with.
Diamond core drill with full water control (minimal mess) drill bit larger than the anchor and drill out a core of concrete complete with anchor still in the middle. Fill hole with epoxy floor repair concrete.
Another way depending on the anchor sysyem used and how much stud you have poking up a hydralic puller can be used if force exceeds the grip of the anchor out it comes
JasonB09/08/2017 11:52:01
Another thought chip up a bit of the floor around the fixing then use a reciprocating saw to cut off below floor level
John Haine09/08/2017 11:58:44
5563 forum posts
322 photos
Flush cut circular saw with TCT metal cutting blade. Try Google.
Bazyle09/08/2017 12:36:26
6956 forum posts
229 photos
Alligator saw to cut down to about 1/2" or less above floor. Then drill down length of bolt to reduce volume to cut through. Finally cutting flush with floor with a hacksaw modified as you do manually with your thumbs pressing on one side of the blade so it scrapes along the floor.
Andy Carruthers09/08/2017 12:47:47
317 forum posts
23 photos
Cut-off tool with shroud to prevent grinding material showering the area?
Mount the cut-off tool on an arc to cater for varying size floor bolts?
Mike Poole09/08/2017 13:07:05
3676 forum posts
82 photos
It was common practice in our factory to over drill the holes for fixing bolts so they could be hammered into the floor when no longer required, it might be worth a bash before having to cut off the studs. Another way is to just knock the stud backwards and forwards with a hammer until it snaps, can damage the hole a bit but works well upto 12mm studs. Grinding and gas axe needed a hot work permit so anything else was quicker.
John McNamara09/08/2017 13:12:20
1377 forum posts
133 photos
Hi
I Googled "concrete edge grinder water vacuum"
I have seen these in action on projects with the right wheel they will work, some have a wet vaccum to clean up the mess.
They can also be used to knock down any grouting.
vintagengineer09/08/2017 14:13:59
469 forum posts
6 photos
Enerpac hollow jack and jack them out.
vintagengineer09/08/2017 14:15:14
469 forum posts
6 photos
Oh, the good old Pikey keys, will open anything!
Posted by Martin Kyte on 09/08/2017 11:43:49:
These would do M10.
regards Martin
richardandtracy09/08/2017 14:45:18
943 forum posts
10 photos
Most sensible thing to do: Exterminate the Elfs. Then you'll be able to go back to easy, quick & efficient bolt removal methods .
Richard.
David Standing 109/08/2017 14:48:52
1297 forum posts
50 photos
Posted by richardandtracy on 09/08/2017 14:45:18:
Richard.
Lateral thinking. I like that wink 2
Ady109/08/2017 15:01:33
6137 forum posts
893 photos
Drill through the bolt turning it into a tube then use your snapper-offer tool or a cold chisel
RRMBK09/08/2017 15:04:17
159 forum posts
18 photos
Hand or power operated hydraulic cutters can be had that will cut virtually flat up to the cutting face . not cheap but very effective . used by fire and emergency services etc . **LINK**
Martin Cargill09/08/2017 18:19:24
203 forum posts
Big cold chisel to notch either side of the bolt then either hammer from side to side or the thick walled tube. Then hammer any stub down (assuming the bolts are not chemical type)
Martin
Speedy Builder509/08/2017 18:47:47
2878 forum posts
248 photos
Oscillating power saw, no sparks, swarf limited to immediate area, cuts flush with the floor, yours for 70 smackers or less. Job done,
BobH
Flying Fifer09/08/2017 19:43:06
180 forum posts
Padsaw handle with a hacksaw blade. Keep the blade flush with the surface with your fingers and go for it. I removed the remains of 6 x 1 inch dia studs & 6 x 1/2 inch studs this way yesterday.
Alan
John McNamara10/08/2017 01:40:16
1377 forum posts
133 photos
A reciprocating saw would work also **LINK**
Very handy for demolition.
Working against concrete the flexible blades will take a pounding but they are not that expensive, they could be regarded as a consumable.
Hopper10/08/2017 04:50:07
7881 forum posts
397 photos
Posted by Mike Poole on 09/08/2017 13:07:05:
Hot Work Permit? Every time I hear of some elfincobblers like this I am glad I don't have to leave my home workshop anymore.
How on earth did we manufacture anything throughout the 19th and 20th centuries with factories constantly burning to the ground left right and centre due to the absence of Hot Work Permits?
