HSS...Do these look like it, how would I tell?
Nige31/07/2017 20:42:13
370 forum posts
65 photos
In the collection of lathe tools I inherited there are some that are clearly marked HSS. The photo below shows tools of a steel that look identical to the marked ones. Is it safe to assume they are HSS and is there a way I can tell please? They are sized from 3/16" to 3/8".
John Haine31/07/2017 20:46:43
5563 forum posts
322 photos
Yes. And the ones that aren't, won't cut very well and/or for very long! You can also try a file on them, won't make much of a mark if HSS.
NJH31/07/2017 20:51:03
2314 forum posts
139 photos
Hard to tell just by looking but easy with the help of your bench grinder. Just look up " spark test for HSS " and you should get a drawing of the type of spark to expect.
Norman
Edited By NJH on 31/07/2017 20:51:42
SillyOldDuffer31/07/2017 20:57:11
10668 forum posts
2415 photos
The sparks produced by a grinding wheel can be used to identify ferrous metals
It may be harder than it looks - I've not tried it myself.
Edit Must learn to type faster - Norman got in first!
Edited By SillyOldDuffer on 31/07/2017 20:58:12
Nige31/07/2017 21:09:11
370 forum posts
65 photos
Thank you guys. I will look up the spark test and try it out
Brian Oldford31/07/2017 21:49:44
686 forum posts
18 photos
Posted by John Haine on 31/07/2017 20:46:43:
You'll also risk wrecking you good files.
Niels Abildgaard01/08/2017 07:58:45
470 forum posts
177 photos
Try with a magnet.If not attracted it can be stellite.
JohnF01/08/2017 08:47:43
1243 forum posts
202 photos
Nige, spark test is by far the easiest and best way and probably the most reliable for home use, best way to learn is to try some known steels on your grinder. HSS will have a shower of dull nonebussting sparks, check this against a carbon steel and you will see larger shower of bright busting sparks. This will of course not tell you the precise type of steel but gives a good indication. Cheers John
larry Phelan01/08/2017 11:36:10
544 forum posts
17 photos
Hi Dave,
Do you type with one finger,like me ? I tried using two but the result was gibberish . Oh to be young again [well not too young ].
Vic01/08/2017 12:14:00
3453 forum posts
23 photos
I got a lot of bits like that when I bought my first old lathe. Only a few pieces had any markings on them but they were all HSS of one sort or another judging by how well they cut and held an edge.
Phil Boyland03/08/2017 07:53:24
49 forum posts
13 photos
I use an electron microscope in work and can identify the % of elements in alloys so if you really want to know I am happy to help.
