Unknown contraption in Victorian flat
JimmieS27/07/2017 16:58:18
310 forum posts
Anyone able to identify this heavily painted over contraption behind the outer door of our daughter's Victorian flat in Glasgow.
Many thanks
Jim
David Colwill27/07/2017 17:09:14
782 forum posts
40 photos
At a guess it is part of a cable operated bell system for summoning the servants. They often had handles in the main rooms (the doorbell was similar but outside). These led back to the servants quarters where there were a number of bells on springs. Upon hearing the bell the servant would be able to see which room had rung. the spring kept the bell moving for a considerable time.
Many thanks.
David.
JimmieS27/07/2017 17:25:14
310 forum posts
Thanks David for you suggestion Should have added that she had a water leak recently and the plumber was unable to find the stop cock for her flat so had to turn the supply off for the whole building which went down well!. Could this be it although it would be unlikely being some 4 feet up from the floor.
Jim
mechman4827/07/2017 18:41:31
2947 forum posts
468 photos
Clean it off & see if there are any markings on it or the surround...face 22
Steven Vine27/07/2017 19:27:03
340 forum posts
30 photos
Ok, a big stab in the dark here. The round thingy in the middle of the flat bar looks like some sort of pulley. Maybe a cable entered the housing through the hole at 12oclock, went round the pulley thingy, and exited the housing through the hole at 3 oclock.
I've seen quite a few 'dead' housings (made from plaster or wood)similar to that in the old houses I've worked on over the years, but no idea of the function.
Steve
mechman4827/07/2017 21:34:02
2947 forum posts
468 photos
On closer looking at I would tend to agree with Steve that it does look like some sort of single pulley arrangement so could possibly be a form of front door / servants call bell arrangement.
George.
Hopper27/07/2017 23:40:05
7881 forum posts
397 photos
Pull the handle and see if the servants come running.
Bazyle28/07/2017 01:04:08
6956 forum posts
229 photos
Check the other houses in the street - one may be better preserved.
Geoff Theasby28/07/2017 01:38:30
615 forum posts
21 photos
"Off the wall" suggestion... I've seen things like this which give access to a chimney flue, for inspection or cleaning purposes. A removable panel a few inches square.
Geoff
I.M. OUTAHERE28/07/2017 07:05:44
1468 forum posts
Flip the lever and see if scotch flows out of the hole , whiskey bubbler pehaps 👍
Edited By XD 351 on 28/07/2017 07:06:25
Edited By XD 351 on 28/07/2017 07:07:07
Martin Shaw 128/07/2017 22:36:47
185 forum posts
59 photos
Jimmie
It's still fairly unusual to find individual stopcocks for tenement flats. When they were built the cold supply from the street runs under the close floor, branches into two and then runs up the kitchen wall to the attic. Each kitchen had a cold tap fed fron this, the attic cistern was typically built from 6" by 3" timber half lapped at the joints and then lead lined, about a 1000 gallons. A supply from this went down the building, each flat tapping off for bathroom cold and hot water cold feed, which is part of the reason why bathrooms were often at the front of buildings. What's the betting that your daughters bathroom is long and thin, and not really big enough for a bath.
I have been to one or two tenements where this cistern arrangement was still in use, but I wouldn't want to live under a 1000 gallons of water contained in a 130 or so year old tank. Didn't really want to go in the attic either, feet deep in pigeon guano at best. More recently when lead pipe removal attracted grants, flats were often repiped and everything connected to mains water, but a lot depended on the factors inclination. Your picture is most definitely not the stopcock but is the remains of a mechanical door bell.
Martin (in Glasgow)
Ady129/07/2017 00:23:45
6137 forum posts
893 photos
They used to just go into the loft, stick an arm into the tank and bung the hole that went to your flat
Not so simple with mains pressure systems
JimmieS29/07/2017 16:42:18
310 forum posts
Many thanks to all posters especially Martin for his local knowledge. Our daughter is in a main door flat which, should an attic tank leak, will be the last to suffer. If that happens lets hope there are enough fully carpeted flats above to absorb most of the flood!
Jim
