Rainbows | 27/07/2017 00:33:50 |
658 forum posts 236 photos | After failing to buy an Elliott shaper and having a strongly pent up desire to make flat things I impulse spent £300 for a mill, 30 cutters and a 100 mile round trip delivery drive from the seller. Not sure if I over paid for it. The search for milling machines hasn't turned up anything better in the past and I can't get an X0 micro mill with table for that money so I don't think I will regret it strongly. Any way here are the seller pics
Can anyone recognise the make? On the side view I can see a sort of celtic knot (I think thats the right word) but aside from that no numbering or lettering. |
Ady1 | 27/07/2017 01:11:35 |
![]() 6137 forum posts 893 photos | If you do this game for long enough there's pretty much nothing you regret buying Looks neat and chunky, but not too big, the vice may be slightly overspecced... Edited By Ady1 on 27/07/2017 01:13:35 Edited By Ady1 on 27/07/2017 01:14:32 |
TrevorK | 27/07/2017 01:31:16 |
45 forum posts 4 photos | The Celtic knot symbol is that of the Denbigh Engineering Co. You’ll find some info about them on lathes.co.uk where there is currently a Denbigh Miller for sale. I’m currently restoring a Denbigh mechanical hacksaw.
peak4 | 27/07/2017 09:09:41 |
![]() 2207 forum posts 210 photos | Posted by TrevorK on 27/07/2017 01:31:16:
...... I’m currently restoring a Denbigh mechanical hacksaw.
A fine beast, I've just finished putting one on the road myself. Had me fooled for a while as I didn't realise it should cut on the push stroke.
Bill |
NIALL HORN | 27/07/2017 09:13:47 |
![]() 49 forum posts 18 photos | It's a Stafford knot - see Wikepedia. It also used to be the logo of the Bourne and Hollingsworth department stores - but only senior members will remember them. The Southampton branch used to have a good tea shop! |
Neil Wyatt | 27/07/2017 10:02:39 |
![]() 19226 forum posts 749 photos 86 articles | Indeed that's the Staffordshire Knot! Neil (In Staffordshire!) |
Adrian Johnstone | 27/07/2017 10:27:55 |
![]() 34 forum posts | See also the Wiki page on the North Staffs Railway which was called the Knotty, and has knots on its crest. Adrian |
Clive Foster | 27/07/2017 13:27:07 |
3630 forum posts 128 photos | Looks to be a Debnigh H4 auto. One piece cast overarm assembly rather than the two part rod and bracket type shown in the picture near the bottom of this page **LINK** suggests its an older, pre war one. Almost brutally simple, all the essential bits and nowt more. Tough, durable and decently made, albeit aimed at the less prosperous end of the market. Will do what it says on the tin. Maybe a bit slower than a more modern machine but it will get there. Assuming no serious wear in the slides thats a good buy. Simple engineering means you can make replacements for pretty much anything thats worn. Clive. |
Rainbows | 27/07/2017 21:19:22 |
658 forum posts 236 photos | 88mm of Y travel seems a tad small, an X1 has 145mm. X and Z are fairly similar between the two.
Out of curiosity what are the missing features that a more up market horizontal mill would have? I have a surface level understanding of how they are used but beyond that don't really have a clue on the finer points. Edited By Rainbows on 27/07/2017 21:20:29 |
Clive Foster | 27/07/2017 22:30:06 |
3630 forum posts 128 photos | Horizontal mill doesn't need much Y travel as all the work is done on the X-axis and cut positions are largely set by the width of the cutter(s) and their position(s) on the arbor. Y-axis is more to bring the work to the correct position under the cutter(s) than for making a succession of cuts each suitably offset from the last. You can do such if needful but its not the way the machine is intended to be used. Vertical mills need decent Y-travel because the the cutter needs to cover most of the table area. Which is what makes them so versatile. Horizontal mills are fundamentally production devices which is why so many of the smaller breed have lever operated slides. In many ways the ideal is to do the job in a single pass. Big, powerful horizontals are chip generators par excellent and can pretty much bury you in very short order given the right sort of job. Clive. |
not done it yet | 27/07/2017 22:47:14 |
7517 forum posts 20 photos |
88mm of Y travel seems a tad small, an X1 has 145mm. It'a horizontal, so comparing with a vertical mill is not too fair. You can only drill by 88mm, but you can flat (really flat!) a workpiece with a 150mm wide slab cutter in one go, which you cannot do so easily with a flycutter on the vertical (or this one either) without very careful tramming. Cross travel on the vertical is the vertical travel on the horizontal. Vertical mills became more popular because they are easier for more manipulations, but you can't put six different cutters on a vertical mill at the same time, like you could on a horizontal. It looks robust and could be driven by a VFD for extra speed control. Motor will likely outlast quite a few on the chinese offering. Does the table feed work? An extra, if available, on an X1.
If those cutters are sharp, you have done very well. It will last longer than an X1. Centecs have the option of fitting a vertical head, so a bit of a leap ahead - but the downside would be finding a good vertical head for what you paid for the job lot.
Rainbows | 28/07/2017 18:40:39 |
658 forum posts 236 photos | Have my eye on a fairly big slab cutter on ebay. Using all these old imperial cutters is gonna give my metric minded rain an aneurysm though. I have an old lathe headstock which I might butcher into a vertical head with some chinese bevel gears. Imagine hoisting a paint can full of coolant and a hose might be good for a cheap suds.
I have a 1/3 HP 3 ph motor spare and a bunch of VFDs up to 1.5kw. Didn't check the current motor power though it is single phase. What sort of power should I be aiming for? |
Rainbows | 18/08/2017 14:59:09 |
658 forum posts 236 photos | Quick question, what sort of cut should this be able to take? Attempted to use a slab mill on a 90mm wide cast iron piece. Can't take any depth of cut without either the belt slipping or the motor stalling. Its a 1" belt on a 2 1/4" wide pulley and the tension pivot is really gummy so I guess a new belt is first port of call, failing that a new motor and poly vee pulleys |
not done it yet | 18/08/2017 18:05:05 |
7517 forum posts 20 photos | Never a quick answer unless the detail is present in the question. Trying to cut full width? Arbor rpm? Feed rate? Diameter of cutter? How many teeth? Condition of cutter? Motor power? All relevant, I would suspect. Even the material will make a difference. Why not try with something a little (no, a lot) narrower, as a starting point? A stalling motor will not be cured with different belts. Edited By not done it yet on 18/08/2017 18:07:14 |
Martin Whittle | 18/08/2017 18:35:48 |
102 forum posts 12 photos | Agree absolutely with NDIY. You refer above to a 150mm width slab cutter - I take it that you are not trying to drive anything like with this mill. I question whether it would fit, but whatever motor power you have on this mill, it would be insufficient. |
Bazyle | 18/08/2017 18:59:31 |
![]() 6956 forum posts 229 photos | Imagine the set up inverted as it were. A 3 in dia cutter 1/4 wide cutting 10 thou deep is the equivalent of turning a 3 in bar on a lathe and taking a 10 thou cut at a feed of 1/4in per rev or 1/4 in deep at 10 thou feed per rev. Would a 1/3hp motor handle that? |
Rainbows | 18/08/2017 19:11:25 |
658 forum posts 236 photos | Will try a narrower cutter on Monday. There isn't actually any data plate on the motor so everything is by guess and feel which being new to the mill isn't easy.
The cutter is a 4" long, 3" dia cutter. Might have overestimated the ability of the miller just a tad Bazyle, thats actually a very nice way to think of it. Would the amount of cutter teeth divide the load compared to a lathe though? Either way that helps a lot. Edited By Rainbows on 18/08/2017 19:17:16 |
Clive Foster | 18/08/2017 19:17:36 |
3630 forum posts 128 photos | Wet finger in the wind estimate for power needed to machine cast iron is 1 cubic inch per minute per horsepower. More likely a little less. Table in the middle of this page :- **LINK** looks to be a useful quick summary. That assumes you are operating the cutter at an appropriate speed and feed. Hopefully someone here has a good reference for HSS slab and side and face cutters when used on smaller machines. I'd guess that it was intended to put around 1 HP through the spindle in normal factory service. Have no doubt that Mr Oppress the Workers Capitalist boss would put as much power on the input side as he could. Despite which Penelope Piecework would probably stall the poor thing on regular basis. Clive. |
Dave Halford | 18/08/2017 19:28:12 |
2536 forum posts 24 photos | I have run a 3 "wide 21/2" dia slab mill on a Centec 2a with 1/2 hp motor. I only tried a light 3" cut of 2thou on alloy. Shavings got thrown everywhere.
That said the slab is sharp and the shafts are free running. Its surprising how much stiff counter shafts and tensioner wheels soak up the power. Is the cast iron machineable or are you trying to cut a hard spot You may have blunted the cutter. Steel would be a better first choice to try. BTW I have a T&LM lathe that took a 1" flat belt - the pulleys are about 1/16 wider than the belt so as your 1" looks lost on those pulleys it is too weedy to drive the mill, bit like your motor |
Rainbows | 10/09/2017 19:13:29 |
658 forum posts 236 photos | This has the potential to be its own thread but what for not taking over the forum will just turn this into Denbigh Mill Questions General. I'm installing a bigger motor with VFD to the mill and want to overhaul the countershaft while I am at it. For speeds of 504,300, 178, 84, 50 and 30 RPM on the spindle I need to make the spindle go at either 300 or 50 RPM. The fast 3 for small cutters and endmills and the slower range for the bulk of the horizontal milling tools. As is the spindle is too fast for most horizontal cutters. The motor which I got is a 1.5kw 1420RPM model. The overkill power is to let the VFD turn down the speed without running out of power. Issue is that the ratio from motor to countershaft is 4.7:1 (not too bad) and 28.4:1 (uh oh). Making a 6:1 then 1:4 compound pulley would be a pain for switching between speeds. My current idea is to make something like the back gear of a lathe on the countershaft. Have the 4.7:1 ratio by pulley then a back gear of 6:1. Would rather not have to buy 4 gears and make an eccentric shaft though. Can anyone recommend a different solution? |
