12 Speed Bench Drill
Alfie Peacock25/07/2017 00:36:44
55 forum posts
With limited space and headroom in my shed I am looking for a 12 speed Bench Drill. The drills that I have found on the internet all seem to high for my shed, as it has a slope my maximum height is 850mm for a drill. There are several that are 850mm but when changing speeds the pulley guard needs to be lifted so will increase the height. Is it possible to cut a few inches of the top of the column on these type of drills. Or any suggestions of makes of drills 12 speed that are as small as the standard 5 speed .
Nick_G25/07/2017 01:19:30
1808 forum posts
744 photos
Do you actually need the gearing.? (for torque reasons)
What I am trying to say is how about a 6 speed with a 3 phase motor fitted and driven via a VFD to slot into speeds between gears.
Nick
Alfie Peacock25/07/2017 02:25:57
55 forum posts
Thanks for your reply Nick, but a VFD going to be a bit expensive for my needs. I have a 5 speed drill at the moment but its only a cheap one and its getting play on the spindle and its to fast one the lowest setting for 12mm drill. Has anyone got a Bosch PBD 40, they are a small drill with a 710 watt motor, reviews on these seem ok, but would like to have a feed back if any members has one.
John C25/07/2017 05:42:53
273 forum posts
95 photos
Hi Alfie,
I have sent you a PM. Check the envelope icon 'INBOX' on the very top line of the page.
Rgds,
Neil Wyatt25/07/2017 15:41:55
19226 forum posts
749 photos
86 articles
Posted by Alfie Peacock on 25/07/2017 00:36:44:
My workshop has a sloping roof, leaving only two possible locations for my drill (or on the floor...)
The limitation on dropping the head is the ring at the top of the rack, so for mine I think you could drop the head by 4", maybe 5", by cutting the pillar.
Speedy Builder525/07/2017 16:00:24
2878 forum posts
248 photos
Alter the pulley guard? Was it the Tauco drill which only had a cover for the front pulley ?
I have a mill/drill with the back of the cover cut off as it runs in a restricted headroom space.
BobH
IanT25/07/2017 16:15:18
2147 forum posts
222 photos
Alfie,
Dare I admit that I rarely change the drill speed on my Warco 12B....although I also don't often use really large bits in it (over 10mm) and for smaller holes (>2mm) I would probably use the Cowells instead. I can open the lid but need a chair to do so - so somehow it doesn't normally happen and it still seems to work OK generally...probably not good practice but there you go. Why don't you try it for a short while before you hack your drill about?
Most of my 'holes' seem to be in the 3-8mm range. Just be sure to use a sharp drill, cutting oil and clear the swarf away regularly...
IanT
Clive Foster25/07/2017 18:07:29
3630 forum posts
128 photos
There are various ways of re-engineering, or re-making, the cover to need less clearance above the drill for it to open. Best to make a prototype or mock up before operating on yours tho'. I'd probably make from scratch, especially as I feel that a simple front pulley shield is fine in a personal workshop.
1) Arrange things so it slides off forwards rather than hinges up. Will need to operate on the back so it clears the motor pulley and arrange some sort of rail or rod for it to slide on which doesn't sound intrinsically impossible. Hafta remember to move the quill down a bit when opening or the sticky up end of the spindle will get in t'way.
2) Fit a simple, fixed, curved shield on the front similar the that on the Tauco linked to by Speedy Builder5. So long as the belt is adequately above hair height a front shield is pretty much as safe as a full cover. Especially if you run it round further to go past the side and partially over the top of the front pulleys in a similar manner to the Meddings Pacera L1 **LINK** (pictures about halfway down the page). Various Atlas models **LINK** were similarly arranged with a rather shorter shield.
3) The simple shield idea can easily be extended into a half or three quarters cover if you don't mind removing it to adjust the belts. Three slots, one at the front and one each side, with wing-nuts or wing bolts should be sufficient to hold it in place. Over centre catches and other fully engineered devices may be snazzier but I never feel the extra effort to get them installed properly is worth it for this sort of job.
4) At least one maker used a two part cover split lengthways with hinges on each side considerably reducing the overhead space needed for opening. I've seen one like this but unfortunately cant recall the brand.
Clive.
David Hughes 325/07/2017 19:01:00
8 forum posts
Had the same problem with my drill Warco 2B12 and had to cut a couple of inches off the top of the column,
SteveW25/07/2017 21:27:35
140 forum posts
11 photos
When I bought my Warco drill second-hand it had a lower height home made stand. I didn't really like the idea and I did raise it a couple of inches. Now I think it's a good thing; you look down on the drill and the belt cover is more accessible.
Howard Lewis26/07/2017 12:50:13
7227 forum posts
21 photos
Could you mount the drill press a little lower? Six inches would probably allow the belt cover to open.
Could it be sited in the area of maximum height?
richardandtracy26/07/2017 13:30:01
943 forum posts
10 photos
Another thought, which in retrospect isn't that bad - sink the base of the drill into the bench top by the depth of the foot casting. That will give 2" extra headroom (leave the pulley cover off & bypass the 'nanny' switch) and then you will have enough room to change the belts and have the top of the foot casting level with the bench. I always find it a pain having the foot standing on the top of the bench.
Richard.
SteveW26/07/2017 15:51:43
140 forum posts
11 photos
img_0347.jpgThought a couple of pictures would help show what I have. Brings working height of the drill table roughly same as lathe cross slide. It's 11 inches lower than the lathe bench and suits me!mimg_0345.jpg
Alfie Peacock27/07/2017 16:56:48
55 forum posts
I have brought a new 12 speed bench drill and cut 30mm of the pillar and now fits perfect on the bench,
I can recommend Kendal Tools for the purchase, it was a unbelievable price with next day free delivery, and £60 cheaper than on e-bay.
All fitted together ok and no play in the spindle,and a 16mm chuck, 220 to 2450 rpm.
Thanks for the advice
