Here is a list of all the postings David Hughes 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: VFD Remote start / stop |
26/09/2022 11:40:34 |
Have sent you a PM with a link in it. Dave |
Thread: Boxford VM30 |
17/03/2019 17:46:37 |
Hi Chris What grease did you use. |
Thread: Inverter problem |
02/12/2018 22:35:08 |
There could be a wiring diagram on the inside of the terminal block cover that may tell you the connections for Delta., And the plate on the side of the motor should indicate that it can be used on 415 or 240 Volt. 3 phase. |
Thread: Newcomer to inverters, please advise. |
14/12/2017 18:06:30 |
Have you had a look at the Newton Tesla site, They cover the Tom Senior milling machine with a variable speed control unit, |
Thread: 12 Speed Bench Drill |
25/07/2017 19:01:00 |
Had the same problem with my drill Warco 2B12 and had to cut a couple of inches off the top of the column, Dave |
Thread: which camera? |
28/05/2016 16:21:04 |
Have bought several items from Ffordes secondhand (usual disclaimer) . I purchased for my first starter camera body, a Nikon D70, a great starter camera for less than £80 (used) for the body, and it will accept auto focus lenses with or without built in motors, Good look in your search. Dave |
20/09/2012 01:04:16 |
Thanks for the info,much appreciated, had found an alternative grease but was unsure of the level/weight, as like you I needed to replenish the grease. |
07/09/2012 23:01:25 |
Would anybody know the correct level/weight of grease in the 2 speed g/box of a VM30, not sure if the level that was in it was correct. |
