Insulating mats
Neil Wyatt06/07/2017 15:01:33
19226 forum posts
749 photos
86 articles
I'm having a real job finding a source of fireproof heat insulating mats. I'm wanting something about 5-6mm thick I can cut to fit under the bed of the 3D printer or wrap around my extruder's hot end.
I want to reduce the wasted heat in this hot weather!
A rigid plate (such as skamolex) isn't really suitable.
JasonB06/07/2017 15:04:27
Plumbers merchants will have 300x300 soldering mats
CUP also do a sheet wool product that can be used as insulation when silver soildering
KAOwool is sold by several ME suppliers to insulate boilers, comes in 1mm or 1/4" sheets which can be doubled up. product details. This is easy to cut and unlike the plumbers mats does not fray at the edges it is more like low density a felt
Edited By JasonB on 06/07/2017 15:07:43
Edited By JasonB on 06/07/2017 15:13:47
David Standing 106/07/2017 15:05:14
1297 forum posts
50 photos
have you looked at plumbers' soldering heat mats?
(Other retailers are available wink 2
David Standing 106/07/2017 15:06:06
1297 forum posts
50 photos
Snap, Jason posted whilst I was finding a linked example wink 2
Simon Williams 306/07/2017 15:06:32
728 forum posts
90 photos
Fibre glass mat sold as a plumber's heat insulating mat foe soldering in awkward spaces?
I've got one about 6 ins by 8 ins, comes with a sewn border to stop it unravelling. I bought from my local builders merchant
(edit - several people type faster 'n me!)
Edited By Simon Williams 3 on 06/07/2017 15:07:57
SillyOldDuffer06/07/2017 15:09:47
10668 forum posts
2415 photos
How about some fibre blanket like wot potters use?
Neil Wyatt06/07/2017 15:37:33
19226 forum posts
749 photos
86 articles
Thanks all, a plumber's mat was in mind as a last resort. The 'ceramic fibre blanket'/kaowool is exactly what I was trying to find.
I should have searched for 'blanket' not 'sheet'!
I've ordered a 'blanket' of half-inch will will fit neatly between the bed and its aluminium carrier, which is about a 12mm gap.
richardandtracy06/07/2017 15:47:14
943 forum posts
10 photos
Bit crispy, but is flame proof & can be cut to size.
I've melted glass soldering mats when plumbing - in an emergency I had to deal with a CH system & couldn't completely close the stop-cock. Ended up using high power on the torch to boil off the dripping water as it came through & in doing so melted the glass mat, nearly setting the skirting alight.
Richard
Zebethyal06/07/2017 15:59:45
198 forum posts
I use a themally reflective sheet under my heated bed, as suggested on the Richrap blog
About £1.00 for 3 x 35 x 20cm sheets
Edited By Zebethyal on 06/07/2017 16:03:43
David Standing 106/07/2017 16:01:57
1297 forum posts
50 photos
Posted by Zebethyal on 06/07/2017 15:59:45:
Please don't, the next thing we know Neil will be trying to print a Full English smile
Russell Eberhardt06/07/2017 16:47:58
2785 forum posts
87 photos
You don't need high temperature resistance so fireproof blankets are a bit OTT. I use a couple of layers of aluminised bubblewrap that came free as packing for something. It has good insulating and reflecting properties and doesn't melt.
I also add a sheet of it on the top of the bed while it's heating up. It roughly halves the heat up time.
Russell.
Simon Williams 306/07/2017 17:08:38
728 forum posts
90 photos
Aluminised mylar blanket as used against hypo-thermia by the emergency services?
mark costello 106/07/2017 17:58:30
800 forum posts
16 photos
British equivalent of Harbor freight has welding blankets, leaving extra for other uses.
Neil Wyatt06/07/2017 20:19:40
19226 forum posts
749 photos
86 articles
I don't want to risk something flammable, plus I can wrap it round the hot end.
Neil Wyatt11/07/2017 20:04:37
19226 forum posts
749 photos
86 articles
Well the aluminium silicate blanket works a treat
Good news - the bed heats up much faster
Bad news, it cools down slower
Getting bored, had better unclip the glass build plate!
Shugs11/07/2017 21:20:08
10 forum posts
Could this be what you may be looking for,
Shugs
Hopper12/07/2017 00:05:40
7881 forum posts
397 photos
Last time I was at the supermarket the kitchenware department had some heatproof silicone oven mats about that size. No idea what they are used for in the kitchen but I thought at the time they might be a handy workshop item.
Neil Wyatt12/07/2017 08:02:52
19226 forum posts
749 photos
86 articles
Posted by Shugs on 11/07/2017 21:20:08:
Shugs
For the nozzle, yes, but now I can make my own by cutting down the blanket and wrapping in kapton tape.
