Lee Goulding | 17/06/2017 00:09:05 |
123 forum posts 19 photos | Hi All I'm trying to install a Mitsubishi E500 inverter with pendant to a Boxford 280 3 phase motor and I know I need to wire the motor to Delta but what wire should I use to connect the Inverter to the motor Thanks |
Ian Parkin | 17/06/2017 06:40:18 |
![]() 1174 forum posts 303 photos | Theoretically you should use a screened cable connected at Both ends to earth or just the inverter end connected lots of discussion about that practice and which way is correct But I have found in practice no problem in just using 4 core flex cable...I,m now up to 19 inverter driven machines in my workshops |
not done it yet | 17/06/2017 06:54:07 |
7517 forum posts 20 photos | Three core and earth of about the same rating, per core, as the incoming 230V single phase supply. No need for a screened cable if it is short lead, I believe. Details will be in the manual.... somewhere!
If you don't know, it would perhaps be better to get the job done by an electrician. |
Michael Gilligan | 17/06/2017 07:21:49 |
![]() 23121 forum posts 1360 photos | The supplier of my VFD recommended 'SY' cable, like this: https://www.ebay.co.uk/itm/391433134625 [choose an appropriate diameter to suit the current] ... It's screened; and tough; and not expensive. MichaelG. |
David Jupp | 17/06/2017 08:10:45 |
978 forum posts 26 photos | 'CY' cable would be expected to be superior to 'SY' with regard to minimising radio frequency interference. CY is likely to cost a little more and won't offer quite as much mechanical protection as SY. The differences could be important in a sensitive environment. |
Lee Goulding | 17/06/2017 08:53:01 |
Thanks guys for the cable advice Would any of you also know if I need to add an isolation switch or breaker as it's already on and RCD from my house supply to the garage Once again thanks |
Martin Cargill | 17/06/2017 09:08:36 |
203 forum posts |
When using screened cable only connect ONE end to earth. That way the screening works and does not lead to the possibility of circulating currents in the screen.
Edited By Martin Cargill on 17/06/2017 09:09:00 |
Lee Goulding | 17/06/2017 09:18:20 |
123 forum posts 19 photos | Ok Thanks Martin |
David Jupp | 17/06/2017 09:44:05 |
978 forum posts 26 photos | The 'one end of screen earthed' applies to signal cables - the ones to the pendant. It is generally recommended to earth the screen at both ends for the cable connecting VFD to motor. Best advice is to follow VFD manufacturer's guidance. VFD to motor you are trying to prevent/reduce generation of RFI (conducted or radiated). Signal cables you are trying to reduce susceptibility to RFI and induced currents form elsewhere. |
SillyOldDuffer | 17/06/2017 10:11:50 |
10668 forum posts 2415 photos | Posted by Martin Cargill on 17/06/2017 09:08:36:
Edited By Martin Cargill on 17/06/2017 09:09:00 Despite much contrary advice floating about I believe that's right. The purpose of the screen is to reduce electromagnetic radiation caused by Radio Frequency currents which are a VFD by-product. What's significant at Radio Frequency is negligible at 50Hz and in this context it's unwise to assume AC and RF are similar. In particular a loop can be an efficient radiator. Look at a TV antenna. I can't find the reference but the most convincing of my books says:
I think the reason advice varies is because much depends on individual circumstances. The length of the wires, the frequencies being produced, the quality of the power earth, and the type of filter fitted all have an effect. Compounding the confusion, unless you have a wide spectrum receiver you can't tell if there's an RFI problem or not. Domestic TVs and Radios are far from ideal as test equipment. Apologies for complicating Lee's question: don't over-think it! If I were Lee I'd use 1.5mm SY cable with the shield earthed at the VFD end only. Dave |
SillyOldDuffer | 17/06/2017 10:19:05 |
10668 forum posts 2415 photos | Posted by David Jupp on 17/06/2017 09:44:05:
The 'one end of screen earthed' applies to signal cables - ...
Quick comment as I'm out the door in a minute, but my point is that a power cable with RF on it is best treated as a signal cable. On control wiring shielding is needed to keep muck out, on a power cable the shield is to keep muck in. In both cases a loop in the shield is more likely (at RF) to cause trouble than not. Good point about following the VFD manufacturers advice though; it might be evidence based whereas I'm armchair bound. Dave |
Stuart Bridger | 17/06/2017 10:28:13 |
566 forum posts 31 photos | Haven't we been around this loop before??? |
Muzzer | 17/06/2017 13:58:47 |
![]() 2904 forum posts 448 photos | (Yawn) - yes, it seems to be an old chestnut here. Some manufacturers recommend connecting both ends of a screened cable, some recommend only the VFD end. But there are lots of experts here who feel there can be only one right answer. Do whatever is convenient and if you have a problem with interference (on your radio most likely), perhaps there will be an expert who can then help you to resolve it. Murray |
John Stevenson | 17/06/2017 14:05:34 |
![]() 5068 forum posts 3 photos | Yup We are not short of experts 😀 |
David Jupp | 17/06/2017 15:34:33 |
978 forum posts 26 photos | Mitsubishi's EMC guidelines for VFDs may be useful - **LINK** |
Lee Goulding | 17/06/2017 16:11:53 |
123 forum posts 19 photos | Thanks everyone for the great replies |
Michael Gilligan | 17/06/2017 16:12:27 |
![]() 23121 forum posts 1360 photos | Posted by David Jupp on 17/06/2017 15:34:33:
Mitsubishi's EMC guidelines for VFDs may be useful - **LINK** . That's very impressive, David ... Thanks ... and I do like the fact that they offer the option to choose your own name for the download That's classy MichaelG.
Neil Wyatt | 17/06/2017 22:08:02 |
![]() 19226 forum posts 749 photos 86 articles | I'm not going to say anything... <retires hurt> Neil |
Ian P | 17/06/2017 22:41:25 |
![]() 2747 forum posts 123 photos | Posted by Michael Gilligan on 17/06/2017 16:12:27:
I beg to differ. If you pick you own name for a downloaded file the odds are that when you come to use it you will never remember its name! I used to rename downloaded data sheets etc so its name matched say, the IC it referred to because the IC manufacturers often had their own cryptic filenaming system. Nowadays I put all the PDFs in one download folder using the manufacturers/originators name. I then make shortcuts to them with sensible names. IanP
Michael Gilligan | 17/06/2017 22:59:02 |
![]() 23121 forum posts 1360 photos | Feel free to differ, Ian ... I was only expressing an opinion. The website offered the rather cryptic name of < 061000.pdf > I chose < MitsubishiVFD_061000.pdf > and exported that to 'GoodReader' on the iPad MichaelG. |
